* * * * * 2 votes
BC Racing coilovers for S30 *** Now offering extreme low kits ***
  • Please log in to reply
551 replies to this topic
#1 JPN_Garage
JPN_Garage
  • LocationOrlando FL
Posted 11 March 2014 - 01:51 PM
Now on sale
http://www.jpngarage...-69-74-240Z.htm
I was at the BC racing coilovers factory today speaking with the production managers and I volunteered my 260Z for a full bolt on S30 BC Racing coilover kit.
The car will be dropped of this week and it will take from 30 to 45 days to produce a product for our 240, 260 and 280Z's.
There will be 1 options.
1) Bottom weld on coilovers with bolt on camber plates.
I have always had BC coilovers on my Subarus and they are amazing so im very happy about this.
Prices are subject to change.
Option:
1) Full coilovers weld on kit  with Camber plates included $1195
2) Add swift springs to your order for $325
3) Camber plates separate $195 for 2 plates
BC S30 kit Spring Diameters:
Front length is 180 mm
Rear length is 220 mm
Inner diameter is 62 mm
Shock Body length:
Regular kit Front 230mm body 110mm stroke
Rear 290mm body and 140mm stroke
Extreme kit:
Front 210mm body and 100mm stroke
Rear 270mm body and 130mm stroke
We are now offering an extreme low kit and extended camber bolt plates as a free upgrade.
The regular kit offeres 1 to 3 inch drop.
The Extreme low kit  2 to 4 inches.
If you need more low then this I can always put in a custom order to BC.
Datsun S30 BC Coilovers options:
1) 1970 240Z to early 74 260Z  (50mm shock body)
2) 1974.5 260Z to 1978 280Z   (55mm shock body)
Camber plate options: (No Cutting Required)
*The first style of camber plate is the direct bolt on style which offers a 3 bolt design that bolts into the strut tower with no cutting or welding required.
*The second option for camber plates is a 4 bolt design that allows for more extreme camber (both positive & negative).
 The 4-bolt design utilizes two of the factory holes but still requires two new holes be drilled.
 You''l notice the dropped style camber plates which allow you to be able to adjust the camber and maintain stock mounting points.
Specs:
BC's coilovers has a patented concave lower locking rings that are a part of these new coilovers.
These rings insure that all adjustments made stay locked tight in place to keep suspension geometry precise.
Ride height is adjusted independent from the struts like in most of  BC's other coilover applications.
Dampening adjustments are easily accessed through the center of the strut tower mount.
All BC coilovers come with a 30 levels of dampening force for compression and rebound.
Edited by JPN_Garage, 18 June 2015 - 10:56 AM.
www.jpngarage.com
#2 seattlejester
seattlejester
  • LocationBellevue, WASHINGTON
Posted 11 March 2014 - 03:38 PM
Depends on the price point, but I will be shopping around for coil overs this summer.
#3 helghast7
helghast7
  • Locationnew jersey
Posted 11 March 2014 - 04:31 PM
^What he said.
#4 winstonusmc
winstonusmc
  • LocationHavelock, NC
Posted 11 March 2014 - 05:04 PM
Thats good for the front, but bolt on rears would seem to be very complicated. If the price is competitive with the McKinny Megan racing kit, then im in.
'72 240z w/ RB25DE ITB MS3/MS3X
http://forums.hybrid...40z-rb25de-itb/
#5 helghast7
helghast7
Posted 11 March 2014 - 06:28 PM
Can't be any more complex then how TTT does it unless I am understanding things wrong.
#6 1vicissitude
1vicissitude
  • LocationAnaheim Hills, CA
Posted 11 March 2014 - 06:43 PM
Interested, but I have a 240z.
Aren't the spindles/hubs different between the 240z and 280z? Like different diameter strut tubes or something if i recall correctly...
Might want to look into that.
Would be a shame to think they were developing a product for all gens when in fact it only fits the 280z. This is an issue with the d2/ksports supposedly.
I'd take BC over Megan anyday, they offer spring choice and re-valving as well. Nothing against Mckinnly, but paying $1200+ for megan streets kind of hurts. I understand why the extra cost is there, I just hate the idea of spending that much on megans... Other platforms they are generally considered the junk of the world. Not that BC is anything mind blowingly spectacular haha. I'm just glad to see another possible option, and the bolt-in parts sounds interesting.
Edited by 1vicissitude, 11 March 2014 - 06:49 PM.
#7 benmac
benmac
  • LocationNew Zealand
Posted 11 March 2014 - 07:02 PM
Yes I would be keen. In NZ though, happy to pay if postage is not excessive.
#8 PMG
PMG
  • LocationChicago
Posted 11 March 2014 - 07:26 PM
I'm in for the price and will be looking this summer/fall.
Full bolt in setup.
Edited by PMG, 21 March 2014 - 12:32 PM.
#9 RB26powered74zcar
RB26powered74zcar
  • LocationLouisiana, 70601
Posted 11 March 2014 - 07:36 PM
Depends on the price   :confused:
RB26dettZ pics
th_April_2012006.jpg ®
#10 Poundz9oh9
Poundz9oh9
  • LocationFayetteville, NC
Posted 12 March 2014 - 04:34 AM
I'd be in. I had some on my old Cobalt SS and was impressed for the price. I can't attest to their longevity or durability but for the street driving I did they were adequate. My Z is already on a fresh set of GC coilovers with illuminas but I wouldn't mind having a spare set due to the availability of the struts on that setup.
---Marcus---
77 280Z The typical "Work in Progress" for this site :)
#11 m1ghtymaxXx
m1ghtymaxXx
  • LocationSt. John's, Newfoundland, Canada
Posted 12 March 2014 - 04:50 AM
Strut tube diameter is different, and 280Z rears are taller, but that's nothing that prevents them being interchangeable between all years of S30. Biggest potential issue would be limited ride height adjustability on the rear.
#12 Dat260Z
Dat260Z
  • Locationsavannah,ga
Posted 12 March 2014 - 05:10 AM
Put me down as interested..depending on price
Late 74' 260z L28/p90 with round top SU's daily driver for 3 years. Pulled drivetrain recently for paint , delete everything in engine bay/wire tuck for L28et with SDS EM4-6F. Suspension consists of: TTT front and rear control arms, TC rods , Ron Tyler diff mount, TTT coilvers (soon to be sectioned strut tubes with new inserts), z32 30mm front brakes with 11.6" vented rotors. Rear brakes are JSK rotor hats, 12.2" vented rotors with 4 piston C2P aluminum racing calipers. Stainless brake lines on all 4 corners . R200 3:90 open rear end at the moment, hopefully upgrading to an LSD unit after the turbo swap is complete
#13 AdreView
AdreView
  • LocationChicago
Posted 12 March 2014 - 09:34 AM
Interested depending on price and application for a '78 280Z.
1978 2+2 under deconstruction
#14 hwvigo
hwvigo
  • LocationBroken Arrow OK
Posted 12 March 2014 - 01:41 PM
I would be instreted as long as the price point is reasonable.
Sometimes in life rolling with the punches is the only way to get through it. The same goes for us lovers of old cars. We take what comes at us and try to make the best out of it.
#15 1vicissitude
1vicissitude
Posted 12 March 2014 - 05:10 PM
If it were a weld on kit like the mckinnley the diameter of the tube will effect the ability to have a tight fit on the sleeve that is welded to the hub. Mckinnley offers 280z and 240z versions for this reason.
I see your point about the bolt on though, if it were like the t3 or tein kits with all four hubs included this would be a non-issue.
#16 miky360
miky360
  • LocationToronto
Posted 12 March 2014 - 08:23 PM
In 100% as long as its no more than $1800 anymore then i might as well get the TTT. luckily I saw this, was ready to pull the trigger on the TTT coils LOL
#17 LLave
LLave
  • LocationRohnert Park, CA
Posted 13 March 2014 - 10:18 AM
Like everyone else said, its hard to say without pricing. If the price is right I may be interested.
#18 alex.cecil89
alex.cecil89
Posted 13 March 2014 - 11:23 AM
im trying to plan out my suspension setup as of now, whether i piece it together with adjustable weld in plates with eibach/ground control welded onto some tokico illumina adjustable shocks, or it be a s13 coilover conversion with mounting tubes. If we can get a group buy goin on and get the price around 1k, id be down in about a month when im ready to go through the suspension, after I get some rubber for these wheels I just bought. Im sure the bc kit would be 10x better than any pieced together kit I could make, not sure why BC hasnt got in the game earlier. Any good coilover manufacterer could take over the game if they made a reasonably priced bolt on kit for the guys with no garages and welders immediately available...
#19 JPN_Garage
JPN_Garage
Posted 13 March 2014 - 07:57 PM
Price list updated on first post.
www.jpngarage.com
#20 JPN_Garage
JPN_Garage
Posted 13 March 2014 - 07:58 PM
Thats what were doing  :icon10:
www.jpngarage.com
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
