ZCC JDM Outer tie rod issue
So i have install these heavy duty outer tie rods .....anybody else have them installed?....im having a slight issue with them rubbing the inside of the rim .....mind you i still have it up on jacks .....but from looking at it even when it will be on the ground it looks as if it wil still rub ......did i do something stupid or has anybody else run into this issue?....thanks in advance .
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
I wish I could post pics with my phone but I can't ....I send the photos of the install to Brian who makes these parts and he said the install looks fine I'm still waiting on an answer back as to why it's hitting the rim if the install is ok ?....and to answer your question John yes it appears that the taper is fully seated .
Just not compatible with your rim size? Link to this tie rod end or a pic? I assume it's the tall bump-steer adjustable type?
Edit:  I'm going to assume it's this style:
You should be able to trim some unused length from the threaded shaft.
Edited by m1ghtymaxXx
I don't think it's my rim size ...I'm using 16 inch rims and I've heard of guys using these with 14inch ...but you never know lol
Mine looks exactly like that pictured one but has a spacer over those expose threads ...everytime I turn it to bring it back in it just gives more toe in....I guess I gotta disconnect it and thread it on the rack side first all the way in then hook it up to the steering
Knuckle .....gonna try that tommorow night when I'm free.
Wrong offset on the rims would be my guess. The spacer should go between the steer knuckle and the rod end, and it should be the right size to fix the bumpsteer. If you installed it as shown in the pics on purpose, you might take the car to someone who knows about this stuff and have them figure out the issues.
No that's why I posted the pic I want to make sure I installed it properly ...I'm mocking stuff up and put the rim on the hub and spun and it hits the inside if the rim .....your telling me I installed it wrong but the guy who makes the part says it's installed correctly ? ....I will flip the spacer and see if I still have the issue .
I might just do away with them and go back to stock
My offset is -10 doesn't seem too crazy .
Edited by theatriks
