Building an L28 (NA)
l28 build na
  • Please log in to reply
136 replies to this topic
#21 Lazeum
Lazeum
    Member
  • Members
  • PipPipPipPipPip
  • 757 posts
  • LocationParis, France
Posted 18 May 2014 - 11:34 PM
I bought mine at Clark's Discount
The owner is very nice and very fast.
- Matt -
'72 240 - L28, P79, Rebello cam, 3xDCOE, Megajolt + Edis ign., etc.
#22 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
  • LocationCalifornia, US.
Posted 19 May 2014 - 11:05 AM
Cool, thanks gents!
Thanks for the link, Lazeum! I found that last night when I was looking around. Seems like a few others around the forum have had great results from Clark's, too.
Thanks again for all the help!
Now I can order in the pistons and the crank bearings :)
#23 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 23 June 2014 - 01:17 PM
06/22/2014
UPDATE
Block still getting bored.
According to OZDAT, my setup will leave me with 9.1 compression, which sounds good to me for an NA motor.
The build has been running a bit slower than usual due to financial reasons, but I hope it picks up soon.
#24 Mack
Mack
    Member
  • Members
  • PipPipPipPipPip
  • 771 posts
  • LocationMinneapolis, MN
Posted 27 June 2014 - 01:41 AM
What are you having done with your head?
I would look into a P79, P90 (both at 53.6 CC combustion chamber) or MN47 (a maxima N47 which has about a 40cc combustion chamber) as they have a much better closed combustion chamber that resembles SBC aftermarket heads and many people feel work better with flat top set ups.
I run an MN47 on my bone stock L28 F54 flat top set up  which produces about 11.5:1 compression!  yeah, its high, but it also produces a LOT of torque because of the compression ratio but also because the MN47 has 42mm intake valves as opposed to 45mm on the L28 stuff.  LOTS of velocity.
I have not installed an aftermarket cam on this yet, and I do have to pull a bit of timing, but I am running megasquirt controlling fuel and spark, so my situation is a bit different than running carbs and a regular distributor.  I feel an aftermarket cam with more duration could be the hot ticket with this set-up.
hey, check my website for pics of my free 280zx.
#25 madkaw
madkaw
    HybridZ Supporter
  • Members
  • PipPipPipPipPipPip
  • 1797 posts
  • LocationBloomington, Indiana
Posted 27 June 2014 - 04:23 AM
Mack- do you have a build thread? I'm heading your direction eventually with MS controlled high compression NA.
Steve,
9/71 240z. 2.4 -.40 over, balanced. E-88 Bigger SS valves, stage 2, 6x2 header, true dual exhaust. BW t-5 , STI LSD 3.90- Megasquirt 3 , N42 intake , 60mm TB , 270cc injectors
#26 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 28 June 2014 - 11:21 AM
Actually, madkaw sent me a link to a very thorough. P79 build page. I suppose I can go with a P90, as well. At this point, it's whatever ends up in the garage. I've had many people recommend those heads, but when I spoke to Dave Rebello, he seemed pretty confident in the N42's operation, even though I specifically addressed my compression goals and fuel octane resources. So that stepped me back a bit. From what I've gathered, however, there seems to be a lot more non-pinging P90/P79 high compression L28's than N42/N47's, so I won't be trying to re-invent the wheel.
So to put the project up to date.
Got the crank polished and the block bored .20
I ordered a pair of flat top pistons, but they happen to be out of stock....tried purchasing from Clark's discounts. I figured I'd get them from ebay, so that's not too much of a worry. I also got new bearings when I got my crank back.
My bottom end is where I want it, for now. At this point, I'm trying to do my research and find a head and go with it.
#27 Mack
Mack
    Member
  • Members
  • PipPipPipPipPip
  • 771 posts
Posted 28 June 2014 - 03:40 PM
If high compression with maximum ping resistance is what you are after, look into a maxima N47  It is a completely different animal than the Z N47.  they were available in the 1981 to 1984 datsun 810/maximas that came with an L24E engine.
MADKAW  you have a PM as I didn't want to thread jack.
#28 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 28 June 2014 - 04:24 PM
Hmm, interesting.
Haven't heard of that head before. Also, not sure if this relevant, but I my motor is carburated. I wanted to eventually go with Triple Webers, but that's once I'm more experienced. Are there any issues involved with high compression/different head combos with the use of SU Carbs?
According to OZDAT, I'll be sitting at around 10:1 (about)
I've heard that is a safe number for P79's and P90's to dish out. Of course the cam and all other aspects come into play, as well.
I'll be doing some research on the MN47, but as far as you know, is there a major cost-performance difference between the turbo heads and the MN47?
I figure that every dollar I save will contribute to a different aspect of the motor. If it's a night/day difference, then it sounds like a no brainer.
Thanks a lot for the input. I'll have some more homework to do tonight! (Never thought I'd say that with enthusiasm)
#29 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 29 June 2014 - 01:52 PM
Got my current (stock) L28 on the dyno. Not bad for the ol' Fairlady!
148rwhp @ 5,200
161ft/lbs @ 4,000
Edited by TheCrazySwede, 29 June 2014 - 09:32 PM.
#30 Tony D
Tony D
    Wiki D
  • Donating Members
  • PipPipPipPipPipPipPipPipPip
  • 9973 posts
  • LocationReno NV & Lucena Quezon, Philippines
Posted 29 June 2014 - 09:42 PM
That's a good baseline for an L28.
Misanthropic Anthroparion Class 5 Hoarder, aspiring to posthumous fame as my containers are cut open and the market floods with crap I've squirrelled away over the years! I endeavour to persevere...
#31 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 30 June 2014 - 02:05 PM
I've baby'ed this motor since I've owned it, so I'm glad to see that it's still going strong.
Once my new motor is up and going and I'm satisfied with it after a while, I'll use the old one for something else. The possibilities are endless! :D
#32 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 07 July 2014 - 02:11 PM
So, I had another Juan-on-Juan with Dave, and (again) didn't recommend flat-tops with the P90 head, due to deck height issues.
Mr. Rebello is either an L-Series wizard or extremely well at selling a product, because I am (at this point) on the edge of getting my motor built by his shop. I always thought his builds run close to the $10k mark, but he wrote me up an estimate for around $5k.
At this point, I'm still doing my research. I'm not really in a hurry, so I'll take my time with it all.
#33 Xnke
Xnke
    Member
  • Members
  • 2005 posts
  • LocationBowling Green KY
Posted 07 July 2014 - 03:21 PM
I don't see why not, since you're running the combustion chamber as it was designed to run...I honestly think the P90 chamber with dished pistons was a kludge on Nissan's Parts Department's perogetive...it would have been "better" to run them with a dish that matched the chamber shape, but I guess it was not enough of a problem to be bothered to produce a special piston. It may come down to piston pricing and availability.
#34 NewZed
NewZed
    Clandestine Moderator
  • Members
  • 5359 posts
  • LocationWashington County, Oregon
Posted 07 July 2014 - 04:02 PM
So the P90 is not just the P79 design with no-liner square exhaust ports?  I thought the combustion chambers were the same size.  Assumed that the chamber shapes were the same.  The valve sizes appear to be the same size also.
If they're the same, then the comments apply to the factory stock NA P79 head engines with flat-top pistons.  Deck height is a block measurement and relates to how close the pistons get to the head, so it sounds like he's saying the "quench" is wrong for a P90 with flat-tops.  Seems like it would then be wrong for the P79 too.
#35 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 07 July 2014 - 04:12 PM
Forgot to mention it, but Dave said the same thing about the P79, so yes you are correct.
He mentioned that they've built hundreds of NA builds running on N42's and pump gas with no issues whatsoever.
Edited by TheCrazySwede, 07 July 2014 - 04:13 PM.
#36 Tony D
Tony D
    Wiki D
  • Donating Members
  • 9973 posts
Posted 07 July 2014 - 04:39 PM
I'm glad that was clarified as something appeared lost in the translation.
You can spend $10K there, but unless your making a turnkey complete package tested race motor, you won't get close to $10K.
What you posted is in-line with what others have paid, and is not much more than for a competently-built stock rebuild with a similar warranty support package would have.
The myth of the slapped together $1,500 stroker persists from people searching 20year old Internet builds (sometimes totally disregarding they seemed to be "rebuilt" every 10,000 miles or so...)
You can spend the money once, or let it bleed you continually over the years. I like the one-payment and drive setup myself! Good luck in the process.
#37 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 07 July 2014 - 04:56 PM
You see, I was always under the impression that Rebello wouldn't even touch your motor if you didn't show up with a bag full of cash, haha.
After talking to some people who are currently undergoing business with the Rebello team, and talking to Dave personally, I got a rough idea of the reality of the situation. Dave even mentioned that he doesn't need a full payment up front. A couple of grand is all he needs to get the ball rolling, and he can even cycle the billing or pay the rest once the motor is ready. Given that I live about an hour away from their shop, I was gonna bring in my L28 and have their talented hands put it together for me.
As of now, I'm doing some research to see where I would go next, given that I do go with the Rebello route. Things I was curious about are things like ignition systems and accessories. I'm sure I can speak with Dave more about it. I've learned that I would need another starter (This one was recommended: http://www.rockauto....partnum=1870137) but I don't know much about anything else. I assume I can use the later modeled oil pump and such. I got plenty of reading to do!
Edited by TheCrazySwede, 07 July 2014 - 04:57 PM.
#38 Tony D
Tony D
    Wiki D
  • Donating Members
  • 9973 posts
Posted 07 July 2014 - 06:50 PM
Get with Dave and get his recommendations... Yeah there's a lot of "talk" out there that guides people, but the reality is the "couple grand up front" pays for the hard parts...and for a shop owner that means money they aren't out so they can keep the lights on! Especially if they're bought through them so they make a little on markup...
I took business from my former employer because they put THE US NAVY on "credit hold"... They needed serious work on two machines, I wrote the stipulation in the service contract that the work would commence upon them buying the parts in advance. They accepted it... Some $60,000 paid to us up front for about $35,000 in our-cost parts. That made life for out little company MUCH easier not having to shell out our ENTIRE cash reserve to buy parts for a job that we wouldn't get paid for four more months or so...
Ended up lots of add-on work was necessary (consisting mostly of labor) which ended up invoiced daily to a CREDIT CARD meaning instant payment to US of $3,000 daily! Everything was "$3,000" at that point. We ended up billing 60k in parts, $24,000 in additional credit card purchases, plus a flat rate labor charge for two men and four weeks labor of $40,000.... With ZERO outlay other than technicians salaries, lodging and living expenses. It really helped the cash flow situation. And that's where you get "the few grand up front." Same as any shop, once the parts are bough and paid for UP FRONT (especially if you have margin on the parts) it's a zero sum game...you have enough money in your kitty for some prelim machine work...and really your final billing is labor...you get paid when it's all done. Since no money is out of your pocket, most guys can wait to get paid...especially if it's not costing them anything!
I digress...
#39 TheCrazySwede
TheCrazySwede
    Regular
  • Members
  • PipPipPip
  • 90 posts
Posted 08 July 2014 - 10:59 AM
I digress...
Yup, true that.
I'm not complaining. The build time usually takes a good 6-8 months, depending on how many times you decide to bug Dave about it. That's more than enough time for me to pay off the motor and have it ready.
As I mentioned in my original post, this is my first motor and my first "real" experience with restoration. I'm giggling like a school girl at the mere thought of a Rebello motor, so I'm obviously very excited! Still reading up on all the things I'll have to do to get the engine ready to run in the car. I'm sure I can ask Dave all the questions I'll have (I doubt I'm the only doofus he has dealt with) but I would rather arrive prepared and not naked...figuratively speaking, of course.
Thanks a lot everyone for all the help and support! I'll keep the thread going with any updates.
#40 miky360
miky360
    Always Here
  • Members
  • PipPipPipPip
  • 157 posts
  • LocationToronto
Posted 23 July 2014 - 02:18 PM
Good to see you're still pulling through with the build. Keep it up!
Carbon Fiber 280z - Almost out of the body shop
IG: miky360
Also tagged with one or more of these keywords: l28, build, na
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
