Z8A1966
Z8A1964
Z8A1982
Z8A1971
Continued work on the rear hatch area...which was rust (like everything else so far)...I have a replacement part for this but the current goal was just to stop the rusting.
Also pictures it some braces I made for the tunnel...there was some flex there...ugly weld as they appear in the picture but they hold...and you won't see them anyway as they are under the carpet.
Pictures Taken October 2015
Few More at: http://www.doitinadatsun.com/yoak/2016/02/240z-hatchtunnel-repair/
Share this post
Link to post
Another semi boring update...here are some pictures of my spacers I made for the 350Z brackets.
I did not take pictures of how they look in the seats (I will on next seat), but basically I welded a thick flat piece on both sides: One directly to connect to the 350Z rails, and on the other side which formed a box. The end result was a bit overkill, but more surface areas was welded to the original frame and I got some additional needed clearance for the custom mounts I am making in the car.
Z8A2032
Z8A2040
Z8A2044
Z8A2086
Z8A2045
Pictures Taken Oct, 2015
More on my site, but meh not much to look at: http://www.doitinadatsun.com/yoak/2016/03/240z-350z-bracket-spacers/
Share this post
Link to post
Z8A2201
Z8A2221
Z8A2233
Z8A2241
I can’t remember for certain but I believe this was the second time assembling the head (which is why it is a bit messier) as I managed to strip out a cam tower bolt because of a wrong torque spec in the How to Rebuild Your Datun OHC Engine book. Ironically I had been cross referencing everything up to the point with the FSM but obviously did not on this one as there is a huge difference in torque (10 vs 25 iirc without looking). So I had to tear everything down and retap and helicoil the towers bolt holes (some others were damaged and did not want to take a chance). To add to the difficulty I even managed to break my helicoil tap off in one of the holes. Thankfully, I was able to extract it by using a Dremel and a sand strong bit. Eventually after sanding the center down I was able to use a screw driver to reverse it out without and additional damage.  After all of this I had to do some extensive cleaning and then put things back together again.
Same Stuff on my site...not had much time to post updates
http://www.doitinadatsun.com/yoak/2016/04/280zx-p90-turbo-head-rebuild-iii/
Pictures Taken December 2015
Share this post
Link to post
So as I am writing this my pictures are about 5 months back...I am going to try and get them caught up as I am about to drop my engine into this car this weekend (hopefully).
Z8A2335
Z8A2345
Z8A2349
Z8A2362
Z8A2373
Z8A2403
Z8A2411
Z8A2423
Z8A2428
Several day progress on the engine including the Kameari timing chain tensioner install. Note that I had to grind down the head (pictures 4-5) to get the full travel. Also note, do not use a thick gasket between the blue piece and the block as it will cause the chain to bind on the lower gear.
More Pictures: http://www.doitinadatsun.com/yoak/2016/05/blockkameari-engine-works-timing-chain/
Share this post
Link to post
Z8A2435
Z8A2437
Z8A2439
Z8A2448
Z8A2461
Z8A2459
Z8A2538
Z8A2552
Z8A2887
Z8A2890
Quite a bit going on in this post and it spans a few months of winter.
Pictures 1-2: Another View of the modified oil pan
Pictures 3-4: Modified Oil pickup
Pictures: 5-6: My Intake prior to sending it out to Lonewolf performance to get it welded up again. I had removed the unneeded provisions as I am going to a MeagaSquirt Setup. Note: I do have it back and it came out nicely.
Remaining Pictures: The other pictures cover the pulley and new key install (mine was damaged).
Pictures Taken Late 2015/Early 2016
\http://www.doitinadatsun.com/yoak/2016/06/280zx-misc-engine-work/
Share this post
Link to post
Thanks, I am glad to know people are enjoying the pictures :)
I haven't been taking quite as many as of late as I am trying to get the car up and driving. As a note...as of this moment in time the engine is in the car - I am working on the intercooler/Megasquirt wiring this weekend :) Just shows you how far behind I am on these.
Share this post
Link to post
Z8A2907
Z8A2910
Z8A2916
IZ8A3652
IZ8A3642
IZ8A3673
Various Images from a few stages of the project.
Completed Intake, Subaru R180 Differential shafts, and TTT S130 front brakes for the new TTT suspension.
Note: Car Engine cranked today, did not start but got the oil pressure established!
Pictures Taken: March/April
Share this post
Link to post
IZ8A3749
IZ8A3741
IZ8A3754
IZ8A3762
IZ8A3770
IZ8A3783
IZ8A3788
A bit of a random assortment of pictures from the project.
Pictures 1-2: Old Fuel Pump vs new
Picture 3: Old Flywheel
Pictures 4-5: New Engine/Flywheel
Pictures 6-7: Subaru R180 with new Stub Axles and aftermarket cover
Pictures Taken April-May 2016
Same stuff at link this time just higher resolution: http://www.doitinadatsun.com/yoak/2016/07/2678/
Share this post
Link to post
IZ8A3601
IZ8A3606
IZ8A3608
IZ8A3609
IZ8A3614
IZ8A3622
IZ8A3629
IZ8A3811
IZ8A3813
I haven't had time to post much lately, but I am doing to try and get this current over the next few days.
The First few pictures are of modifications I made to the original Radiator for the electric fans. I had to weld this up as they lost the original support they had. The head was off the engine prior to removal as I believed it was damaged (which does not appear to be). The engine will be likely used in the upcoming 240 with different pistons. The pictures are from me removing the original AFM bracket...with it in place it was making routing of the intercooler much more difficult and wasn't needed anymore now anyway.
Pictures Taken April 2016 (pictures are out of sequence with previous posts)
Same thing at link just higher rez:
http://www.doitinadatsun.com/yoak/2016/09/280zx-engine-pull-modified-radiator-etc/
Edited by Yoak
Share this post
Link to post
IZ8A3839
IZ8A3848
IZ8A3863
IZ8A4564
IZ8A3872
IZ8A4572
IZ8A4581
IZ8A4574
So I had to cut into the ZX to do the intercooler installation, I did not take many pictures of the process but I did try to give ample room on each side and keep them even. While it is not obvious in the pictures they came out pretty close.
All of the brackets I had to fabricate myself, my kit was missing (I later found them after project was done) some brackets and I did not like how it was going to mount anyway. I made to "sandwich" brackets to give the core support better support the adjustable "L" brackets  I had made earlier. I just did not like the idea of it hanging the way it was without some re-enforcement.
I then drilled holes on the lower area of the support for the longer threaded rods that are on the lower section of the intercooler. I then used a rubber grommet to cover the bottom nub to give the intercooler something to sit on and slightly wedge it so it would not move back and forth.
Not the new radiator, the process was the same as the old one to make the fans work so I do not really re-document this process.
I also had to cut the piping a bit shorter near the coupler in front of the engine for the newer throttle body + spacer I was running.
Pictures are slightly out of sequence but posted this way to make more sense to the context of the post. Pictures taken July /September 2016
More images: http://www.doitinadatsun.com/yoak/2016/09/280zx-intercooler-new-radiator/
Share this post
Link to post
IZ8A3821
IZ8A4499
IZ8A4514
IZ8A4511
IZ8A4515
Slightly out of sequence pictures again, but it was easier to show the process this way as I did not take many pictures of the CV install.
The difference is a torsion out of a Subaru WRX STI (R180) Torsion type (3.54). The CV/Flanges are the Wolf Creek Racing kit, I was told when I did this I was the first person to try this in a 280ZX. The only difference was I had to use 240z bolts on one side and 280ZX on the other (wheel side) to make the new CV's work.
The Exhaust is 3 inches all the way back. I am still trying to source a flange for the 280ZX Stock turbo so I can remove the cast piece.
Pictures Taken May/August 2016
More Images: http://www.doitinadatsun.com/yoak/2016/09/280zx-exhaust-cv-axles/
Share this post
Link to post
Wow, it's been about a year without an update!
The project (280ZX) is still ongoing and the 240Z is still on hold- and I have some pictures altough for various reasons I haven't been able to take/post as many as I would like.
Brief update as of today (pictures in a future post)
  • MS3 - Installed, Car has 700ish miles on it in the year that I rebuilt it
  • Front end had to come out for an oil leak and "modification" of the DP racing fan to clear the steering rack mounts
  • Rear End is out again, camber/caster issues & TTT rear end coil over install
  • Installed the 240Z roll cage in the ZX because it was taking up to much room in the garage
  • Upgraded Alternator (GM) for the new electric fans.
  • Rewired a good chunk of the original harness/upgraded grounds and charging cables.
The Following Pictures were taken in January of 2017:  I replaced the CX racing Fans with PERMA COOL fans and had to cut the original fan shroud brackets. These fans barely fit, and required some rewiring and an upgraded alternator to give me some breathing room as the original was dying anyway. I did not take as many pictures of the fans while installing them as I would have liked but you will get the idea.
http://www.doitinadatsun.com/yoak/2017/09/280zx-radiator-modificationnew-fans/
large.IZ8A5019.jpg.b686529625d7bcbcf544dc06c5c5f68d.jpglarge.IZ8A5022.jpg.49e5c52ff00f9d0c1cb536b1662822c7.jpglarge.IZ8A5023.jpg.c10a5f4e04acb31b37554b1e2287de98.jpglarge.IZ8A5024.jpg.895c8af6e35acf14c306c10bc8cab782.jpg
Share this post
Link to post
Several oil leaks appeared fairly quickly around the classic areas of the new oil pan so I had to finally pull it after attempts to stop the leak had failed. Additionally I needed to "modify" the rear of the pan with a hammer as it was kissing the cross member. The job is generally a pain with a stock pan but with the additional size of the custom pan I was forced to pull out the front cross member to ease re-installation and it needed repainted anyway.
large.IZ8A6155.jpg.3ecf6f5365e6889a7f913065f11d9c74.jpglarge.IZ8A6172.jpg.9eb9de3dc3cd281ca6a33a1685b9c7a2.jpglarge.IZ8A6206.jpg.b9f78f39ebb9dc7be2fed5bf41a257ff.jpglarge.IZ8A6209.jpg.c4ba1ec8954ea2a629be10a640cde641.jpglarge.IZ8A6226.jpg.bff2250923d5d7a8ef16cda4c765dffe.jpglarge.IZ8A6228.jpg.360a3aa0dedd1914aa23922ef2ad8887.jpglarge.IZ8A6232.jpg.0990a997531bf064bda0f7c841cb0f49.jpglarge.IZ8A6233.jpg.dd0c982f4fd12451834b09bc0ace85c8.jpglarge.IZ8A6234.jpg.fecc3a30643dd24c3a6ba852542c9124.jpg
Pictures Taken in June/Early July 2017
Few Additional Images: http://www.doitinadatsun.com/yoak/2017/09/oil-pancross-member-280zx/
Edited by Yoak
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
