Wolf creek CV conversion vibration
Ylo73z
Swapped in the wolf creek cv shafts on my 77 280z and now it has a nasty vibration / grinding noise , but only forward loaded , checked it on the jack stands , nothing , backed up , nothing , put it back in drive and accelerated and it vibrates ...I'm sure it's simple ......all cv alignment and adapters looks good when rolling on jack stands
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I actually found that it is rubbing on the right side inner joint on the control arm ....not sure how I'm going to approach this yet but I think I'm going to try and make a washer to shim the mustach bar up to raise the diff up and hopefully keep the inner cv joint off the control arm
Consider ditching the sway bar, it's the simple solution, and it doesn't contribute much to how the car drives and is just dead weight. Interesting that the boot is rubbing the control arm, I didn't have that problem. Pics if it is ever convenient?
Yeah I can take a picture today , I pretty much only straight line my car , so I was thinking about ditching the away bar but I was worried about how the car would plant removing the sway bar , I was also thinking of just getting longer endings to raise the sway bar away from the cv boot
I cleared the control arm by cutting the inner sleeve on the mustache bar bushing then replacing the old lower bushings , cutting the sleeve allowed me to tighten the nuts a 1/4" further before bottoming out , I also hit the control arm with a grinder to make sure it was clear , once I deal with the sway bar I will road test as again and give the results
No I didn't , 4.11s are coming out in exchange for the 4.60s LSD , stock adapter flanges and stub axles are coming out for billet units , then I'll locktight everything , put on the trans brake and see what a r200 can take
I don't understand how you are hitting anything.  Below is a pic of my Wolf Creek CV swap with ST sway bars.  I have great clearance on both sides.  I did shorten the end link (spacer) slightly so I would not hit anything on full droop (when the car is jacked).
