Anybody have trouble installing polyurethane bushings?
I bought the polyurethane bushing kit for my 1975 280z http://www.thezstore.com/page/TZS/PROD/23-4100AZ . Besides the tiny tube of lube they include, the kit was great. I got the control arms, rack and pinion, and front sway bar all done. I then started on the tie rods. Removal was easy, but I can't for the life of me get the urethane bushing into that beveled pocket where the old bushing sat. I've urethane lube, dish soap, a rubber mallet, and vice grips. Nothings really doing it, I wonder if I need shave off a little piece of bushing or get it pressed. Any ideas? Heat gun?
Tie rod bushing?  What do you mean by "tie rod"?  Maybe my memory or general knowledge is off, but I don't recall a tie rod bushing.
Post a picture.
Edit - just a guess, but maybe you're trying to use the mustache bar bushings in the tension/compression rod spot.  They're both big and round.  Also note that the T/C rod and its bushings are easiest to replace with the wheels and suspensions weighted.  You can reach everything while laying beside the car.  Almost impossible to get the bolts back in with the wheel hanging.
Edited by NewZed
Post a picture.
wasn't thinking when I was typing haha it's the tension rod bushings. I have the motor out also so no worries on reach. It's bushing on the engine bay side, i'll take a pic
Compare the new bushing diameter to the old rubber bushing diameter.  there's no reason they shouldn't fit., I think that all S30's use the same T/C rods.  Make sure also that you read up on urethane bushings and broken T/C rods too.  Many people run 1/2 rubber, 1/2 urethane.
Is the wheel on the ground and weighted by the car?  Looks like you have the wheel hanging.  The rod might be at an angle.  On the ground makes everything super-easy.  Things are incredibly harder than would seem rational with the wheel hanging.
didn't think to put it back on the ground to straighten things out. Ill give it a try
In the top photo you have the large washer installed backwards - the "cup" should be facing the hub, not the bushing. You should seriously consider NOT using all 4 poly bushings - as was mentioned above. Ask me how I know... I was up in the hills on a tight, twisty, 2-lane road.
Worth noting also that since your engine is out, even with the wheels on the ground the rod may still be at an angle and difficult to put back into position. If thats the case you should just wait and do those bushings last.
I've been doing reading on the subject also and the consensus is to use rubber bushings, or if you must use the poly ones, you can drill holes in them to provide more flex.
what's funny is that that washer was grimed on there so I left it that way assuming is was right haha, thanks for the heads up. I'm guessing things got really tight up on those hills?
No. Just my club which consists of me and my son and two hybrid 240Zs.
you guys should come check out one of their meets. It's a great group of people with a variety of datsuns, they every first friday of month at round table parking lot off sunrise blvd. I think they are caravanning to canby also
I had no problems installing these on the TC... The only place I had a problem was on the steering rack. No matter what I did, I couldnt get the damn things to fit. Everything else went in great.
that's weird my steering rack bushing went in easy, I haven't even attempted the rear yet
This makes me worried. There may be a mix up of rack bushings. 280 racks have a wider bushing area (distance between the flanges that constrain the bushing) on the drivers side than the earlier racks, and there are two different bushings to account for this. Poor AZghost and many others have endless tails of whoa getting the right bushings inplace as they are very very tight. Requires total cleanout, handfulls of lube, gear clamps,copious swearing and bleeding to get the bushings seated well enough to re-assemble. The end result is great, but its not easy as you seem to indicate
The MSA page you linked to shows the differences. Their 23-4151 rack bushings should be right. If you accidently got a 240 bushing, it will fit way too loose and will allow the rack to move left right with steering input. The other side is the same on both racks.   If you have the too-small 240 bushing, it will seem to slip together pretty well and seats 'ok', but the test of putting the wheels on the ground and steering right/left while watching the rack move will tell you the story.  Another diagnostic would be, when on the road you will notice that if you turn left, the wheel will return to center in one place, but if you then turn right, the wheel will re-center to a noticably different spot. Sure sign of the rack shifting with the turns.
Maybe you got lucky, don't worry about it until you take it for a drive.
Edited by z240
I struck out searching for broken T/C rods and poly bushings.  I've them in mine and could you write a line or two summarizing the problem and what to look for?  Thank you very much.  Wouldn't like a T/C rod to break zooming around the hills.  Thank you!
If you grease the steering rack bushings well they will squirm around to fill the gaps when driving. I had about a quarter inch gap I couldn't close but just torqued bolts and drove. They're elastic. They fit perfectly now.
