Stock 240Z Fuel System with L28 (F54/N47)
Connor280ZX
Hi.
Just bought my L28 to swap in to my 240Z which has a blown engine. Looking it over, everything seems like it will bolt right up to the S30 bay with no problem, however the fuel pump mounting area doesn't look right. I would think the hollowed out area between the mounting bolts would have been cut through to the inside of the head. Will i have to drill a hole here if i want to use the stock fuel pump?
Electric pump it is. Bought a P11K low PSI pump to fit to the car. Now, hooking it up properly is my concern. Most guys will probably tell me to do that oil pressure saftey switch thing, but for the time being, i just want it to turn on and off as i do with the key. I've heard some rumors about an additional accessory wire taped up in the rear passenger undercarrage that supplies positive voltage. This wire goes live once i tap into the "female T connector" in the radio compartment, and attach the wires together with a fuse in between... Not sure how much truth there is to this, my car is a '71 Series 1. Sounds ideal to me at the moment.
I don't need to drop the tank to install this pump, correct?
