Torque converter capacity
BlueStag
Guys,
I am moving ahead on my project: replace broken flex plate.
While I was at it, I replaced the main front seal.   Oddly, the two small bolts holding the third pulley to the balancer were 1/4"-20s, and not metric.    Go figure.
When I pulled the trans off the engine, I wanted to pull the torque converter off the trans shaft, just to see if it had been obviously damaged, which it was not.
I drained the torque converter into my oil slop bucket to be recycled.
And now I cannot find a spec on how much to precharge the torque converter before I slide it back onto the trans input shaft.
I seem to remember seeing 2 1/2 qts, but that seems rather a lot.
Now, this trans is off a Nissan Maxima, but I imagine the torque converter is essentially the same as a Z torque converter.
I cannot find the reference in my shop manual....
Anyone know what's up?
It's over a gallon...but you can't put that in there and mount it...
You fill halfway, run it through D.N.R a few times, check the oil and top off...usually adding 2 or 3 more quarts.
Remember to have it level, and in the proper gear as stated in the FSM when checking. Overfilling makes a terrible frothy mess underneath...but keeps you safer from road salt I suppose!
