Rich Idle l28et, with injector map.
Meguiars
Hi, i have just got my car up starting 280z with l28et, 240sx TB, non intercooler, walbro gsl392, Denso 456cc see picture. i have some problems by adjusting the idle so it wont run rich as 9.8 -10.1 AFR it wont pass the emmision control here in Norway.
I have tryed to run 2 and 3 squirts simultnouse, but the best result as far as i think is 6 squirts alternating, it felt more snappy on the throttle. Any tips an ideas?
 i only have the original idle valve on the top of intake, do i have to mount Ford PWM IAC valve.
Or can i alter the deadtimes to get leaner idle? This is High imp 11.5 ohm, so i have turned off PW limiting also, right? The deadtime as you see in the picture is 0.616 at 13 volt.
Any ideas guys and girls.
Thanx
