L28et Swap Rewire, Need electrical help!
Scapy
Stock, the Tach signal comes from the "-" coil terminal (blue wire) through the resistor under the glove box to the Tach (260, 280, ZX). If you use the 260-280 stock wire, it tee's off to the stock electronic ignition module so you'll probably need to disconnect it from that.
