My 240Z with supercharged BMW engine
240z bmw bmw engine m50b25 bc-racing coilovers
  • Please log in to reply
74 replies to this topic
#41 1969honda
1969honda
    Always Here
  • Donating Members
  • PipPipPipPip
  • 334 posts
  • LocationNear: Logan, Utah, United States
Posted 23 January 2016 - 10:49 AM
Awesome! Watch out once the boost bug bites you'll always want a little more.
#42 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 24 January 2016 - 10:19 PM
Lets hope that won´t happen. :)
First plywood mockup of that SC bracket.
Feel free to comment if you find some faults with this. This is my first supercharger build so all help would be appreciated.
#43 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 26 January 2016 - 09:38 PM
Well that didn´t work...There is no room for boost pipes. Only way compressor can be rotated is when boost pipe is directly up, and then it hits to hood.
I think I need to relocate alternator so I can mount that charger lower.
Edited by TeemuM, 26 January 2016 - 09:48 PM.
#44 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 02 February 2016 - 11:48 PM
Here is final design of these brackets. These are going to be laser cutted from 10mm steel.
Also ordered larger pulley to lower boost litte bit. However there seems to be some problems. That new pulley hits to that flange that is in front face of charger. In rotrex techinal drawing that flange height is 5mm and I have 8mm. So maybe this charger is older design, etc. However I think I need to machine 3mm off that flange to get enogh clearance.
#45 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 15 February 2016 - 11:03 AM
Now that engine work is done I had time to modify fuel tank. I wanted to use in-tank fuel pump, so needed to cut hole and weld that plate in place. Also made that bracket for Walbro 450 E85 fuel pump.
That fuel pump bracket is going to be zink plated and inside of tank is going to be covered with Por15 fuel tank sealer.
#46 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 18 March 2016 - 10:24 PM
Fuel tank is now ready to be assembled. I did Por15 tank sealer treatment inside so hopefully it wont rust anymore. Pump is Walbro 450 E85 and I am using AEM high flow fuel filter.
#47 ehren
ehren
    Regular
  • Members
  • PipPipPip
  • 61 posts
  • LocationIdahooooooo
Posted 19 March 2016 - 03:32 PM
amazing work! love it
#48 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 15 April 2016 - 09:54 PM
I drove about 200km with NA engine and then it was time for oil change and installing supercharger. Still lots of small thing to be done but at least it is now drivable.
Small video of first start with Rotrex.
http://teemum.kuvat...._kaynnistys.mp4
#49 Sirpent
Sirpent
    Always Here
  • Members
  • PipPipPipPip
  • 192 posts
  • LocationMelbourne Australia
Posted 16 April 2016 - 05:53 AM
Very cool build and congratulations on the start up  ^_^
"Das Drehkraftmonster RS32 AMG !"
Powered by AMG
RS30-005067 Restoration Melbourne Australia
Full Pictorial @ https://www.flickr.com/photos/134020799@N04/albums
#50 1969honda
1969honda
    Always Here
  • Donating Members
  • PipPipPipPip
  • 334 posts
Posted 16 April 2016 - 08:17 AM
That's sweet, motor really torques to one side under load, gotta be a blast to run around in.
#51 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 17 April 2016 - 08:19 AM
Thanks!  :)
I quess my calculations were off because this only boosts about 0.5bar. I calculated that with this pulley boost pressure would be about 1 bar. Because pressure is so moderate there is not so big difference compared to NA engine. Well I can always change smaller pulley... ;)
#52 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 28 April 2016 - 06:38 AM
Went to dyno yesterday. There was 360hp/420nm and that was only with 0.4bar. I am quite happy with results as boost pressure was so low. So there is much improvement available with smaller charger pulley. Also that 2.5" exhaust is too small so I need to do it again.
Small video.
https://www.instagra...aken-by=teemume
Edited by TeemuM, 28 April 2016 - 06:39 AM.
#53 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 23 May 2016 - 03:35 AM
I made small modification to exhaust pipe. Previously I had chambered single outlet muffler and I changed it to twin tip straight-through muffler. Like looks and sound with this one!
#54 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 25 October 2016 - 11:17 PM
I ended driving season this week. Drove little bit over 5000km in this summer and not a single problem. Attended few drag racing events and best time was 12.99@178kmh. Those were at airfield so traction was not so good.
For next summer there is not going to be much changes. Little bit more boost, better intercooler and larger exhaust. For outside I bought original mirror to replace that plastic one and Euro-style front spoiler.
27053848430_9d3bbb7104_o.jpg?img=img1280
Few driving videos.
http://teemum.kuvat....a/kiihdytys.mp4
http://teemum.kuvat....sta/Elokuva.mp4
Edited by TeemuM, 25 October 2016 - 11:21 PM.
#55 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 19 December 2016 - 11:15 AM
I got this aluminium radiator to replace original. I also put Spal electric fan so original fan shroud would not fit. I modeled new shroud, machined mold and used carbon fiber to made new one. Still needs few layers of clear coat and it´s ready!
#56 rturbo 930
rturbo 930
    Porschephile
  • Donating Members
  • PipPipPipPipPipPip
  • 1598 posts
  • LocationNJ
Posted 19 December 2016 - 01:10 PM
That's some very nice work!
Owen | 1976 280Z | 1986 Jetta | 1953 CJ3B
A car is a hole in the air, suspended there by four rubber doughnuts which you can not eat.
Into this hole, you throw money, which you will never see again.
Buy my stuff: CLICK HERE
#57 DomiNATE
DomiNATE
    Newbie
  • Members
  • Pip
  • 6 posts
  • LocationMaryland
Posted 21 December 2016 - 10:30 AM
Great job looks awesome.  Just found you on Instagram.
Somewhere between Baltimore and DC. 1975 280z, LS1 motor, 4L60E trans.
#58 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 21 December 2016 - 10:46 PM
Thanks guys!
DomiNATE: I update that IG litte bit more often than here.
#59 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 31 December 2016 - 11:53 AM
I fabricated new exhaust that replaces current 2.5". Its now 3" with two Dynamax mufflers.
Also mounted larger intercooler and oil cooler for Rotrex. IC is treadstone and oil cooler is Setrab.
#60 TeemuM
TeemuM
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationFinland
Posted 18 February 2017 - 10:45 AM
Finally found time to finish fan shroud so radiator is ready to be installed. I cured that part in sauna. It made quite a bit difference to part stiffness. After that is was clear coated.
I modified Nismo-style front spoiler. Now it fits quite well and atleast in my opinion it looks better. Now I need to make mold from it and manufacture new part.
Also tagged with one or more of these keywords: 240z, bmw, bmw engine, m50b25, bc-racing coilovers
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
