rjracin240
ZCON 2015
Am I seeing this correctly, that the final date is July 14th week, and NOT July 21 week?  I need to get this set on my calendar, and I found this conflict between the first post in this thread, and the dates that are set in the registration links.  Somebody in authority please confirm.
Share this post
Link to post
This is from memory: roadrace Wed, autocross and drags Thursday, more drag racing Thursday night, TnT not associated with the event. I really dont know how they hope to get two popular events done on one day. I'm planning to trailer over on Tuesday, then trailer home Friday. My car gets no love at shows-its a good 50-footer, except for those awesome door hinges you hooked me up with-I painted them up and they are "show-quality!"
Share this post
Link to post
Here's where I'm gonna call tonight to check availability; these are the motels nearest to the raceway that don't look like I'd get fleas:
Days Inn Motel Millington 901-872-3335
Quality Inn Motel Millington 901-873-2222
Plan is to work Monday and 1/2-day on Tuesday, then drive over to Memphis and get checked into motel and off load my junk, then head over for a beer at the Hilton on my R6s.
Participate in the Wed HPDE, Thurs autocross and drag racing and Thursday night Test-n-Tune at MIR.
Now, the big question:  To attend the Judged Car Show on Friday, or head on home?
Be advised, mapquest kept directing me to the wrong location for the raceway-use Google Maps and enter Millington for the city instead of Memphis.  The raceway is north of downtown near the river in the vicinity of the Naval Yard.
Share this post
Link to post
Here you go Rebekahs a little video to get you fired up about the dragracing
https://www.youtube.com/watch?v=gzya3bG1FrI
Decent video to see the lines around the track
https://www.youtube.com/watch?v=E4hXfTmOvIw
Staying at the ZCON host hotel, will probably stick around and check out the drag racing thursday night and then leave Friday
Edited by rjracin240
Share this post
Link to post
I'm thinking of registering for the Friday show, just to be able to hang out a little. Just to get some lawn chair time....Im pretty worn out from "life." Might be a good chance to charge up. Wonder where I can park a trailer on Beale Street?
Share this post
Link to post
Room is booked at Days Inn Millington for $62 per night with a AAA discount. Arriving Tuesday in the evening. I was just trying to add the Friday show to registration with the plan to drive on home after, but can't figure out how to edit my account. Any pointers?
Edited by RebekahsZ
Share this post
Link to post
Here is some driving tips for the track day event
Memphis Motorsports Park is a 1.8 mile facility with virtually no elevation change. It is located in Northern Memphis along with several other racing venues such as a dirt and paved oval track. The .7 mile front straightaway is also the Drag Strip plus shutdown areas, so cars with good straight line speed traditionally do well here. The pavement has moderate grip, but the 'road course' portion is very bumpy with several patches right in the braking zones. The big bump exiting turn 8 (where the asphalt joins the concrete at the beginning of the drag strip burnout area) is now much smoother and most drivers can just keep the throttle planted coming through there.
If you can set your car up a little loose for qualifying and neutral for the race. Slightly loose if fast here, but will burn up your rear tires quickly.
Memphis was designed to represent a sample of several types of race circuits. Turns 1 & 2 ("the carousel" - actually one long sweeper) are slightly banked. They and the front straight emulate an oval track. Turns 3 and 4 ("the kink" and "the M's"; actually a left - right - left - right - left chicane) are like a traditional road (some say autocross) course. Turns 5 & 6 (the "double 90's") represent an airport course. Turns 7 & 8 ("Grant's Tomb", and "the wall") imitate a street circuit with their concrete walls and sequential 90 degree rights.
Floyd drove a Honda Civic in ITC (4 speed, 4.68 final drive) and Chris drives a fully T1 prepared 2001 Corvette Z06, so the descriptions will reflect that.
Start / Finish is about 1/4 mile into the front straight, so you should be in 4th gear when you go by. This is a great time to check the gauges and the mirrors because when you get into the actual road course part, you are busy! Turn 1 is a lot farther away than it looks (almost 1/2 mi.) so just hammer down and keep it straight. You can either stay in 4th gear and run the rpms up to 7K or shift to 5th and conserve the car more. I tend to stay in 4th and eliminate the shift, but still hit about 150 mph!
Try to stay just left of the center of the track because there is quite a bit of junk near the left wall. The braking zone is reasonably smooth and you can brake quite late. If your rivals brake in a straight line, you can brake at an angle (right) toward turn 1 and take the corner away. If you are by yourself though, you'll want to use all the track so stay left and brake in a straight line. Heel-toe shift to 3rd. Turn 1 is a long, sweeping, banked right turn. There is a lot of rubber build-up at the edge of the corner so I enter it about two-thirds away from the left edge. You can let the car scrub speed if you need to and just use the throttle mostly for steering corrections. Pull it down toward the inside until you get to the apex which is very late. The turn does tighten up quite a bit so experiment with different apex points. Squeeze the throttle, open the wheel and aim toward the patch of "new" asphalt on the outside at the exit. If you do it right, you should be full throttle by the exit. Shift 3-4.
Keep the wheel slightly turned and that will take you to the apex of turn 2, which is more of a fast right-hand kink than a turn. You should be able to take it flat out! You'll now be going slightly down hill and should try to get to the right quickly for Turn 3. It's imperative you keep your head and eyes up through this entire section - not only for speed and smoothness, but to watch for cars spinning in front you too!!
Turn 3 is just a left-kink and most cars can make it thru there wide open - it just takes some practice, and no small amount of guts. Keep the car turned left and stay on the gas until about 150' before the FIA curbing on the left. Get the car straight and drive the nose into the ground when you brake. Heel-toe shift 4 to 3. Turn 4 (entrance of the esses) is a very sharp, right-hander, and slow - treat it that way. The entry speed is not near as important as the exit! This is a right, left, right, left series of turns and is tricky to get right.
4-B, C, & D is actually the second most important series of turns on the course, and exit speed is critical. Late apex each turn and don't overshoot the deceptive 4-C. The curbing thru here is very high (especially 4C) so stay off - just barely clip them. As soon as you can, ease the throttle on, and clip the apex of 4-C. At this point you can pretty well straighten out 4-D and get on the power. If you did it right, you may well be rewarded with an opportunity to pass someone down the moderate straight before the 90's. The earlier you can get on the power means a better top speed down the little straight.
You can either stay right entering the 90's and brake at just about the f|ag station, or experiment with different approaches. There are two major patches in this area and they are very bumpy. I found that about 4 or 5 ft off the right edge worked best for me. It was smooth enough to still late brake and allowed a decent entrance into turn 5.
Rotate the car slightly and late apex 5, a 90 degree left, then immediately early apex 6, a 90 degree right. Get back on the power early and hammer it toward 7. The apex of 5 and outside of 6 is just artificially limited by cones so you can experiment a little here and try to get the best launch.
Trail-brake entering 7 just enough to settle the front end and stay out of the formidable looking tire barrier directly ahead of you. This is the most important, and dangerous, maneuver at Memphis. Don't enter the corner too late because the track is slick and there are plenty of marbles out there. Experiment with different approaches and find the spot that works best for you. Once you turn, stay right, but watch for cars entering the pits! The plentiful marbles on the left are made of wall magnet material and if you get in them, that's where you'll watch the rest of the race from - the wall! I'm not sure "stay right, but late apex left" makes sense, but that's what you should do. Hold neutral throttle and let the car drift as close as you dare to the left hand wall of "Grant's Tomb" (so named because the Grant brothers, Richard and Milton both hit it in the inaugural Memphis race). Roll the throttle down, then center apex 8, clipping the inside as close as possible on the right. There are tires there protecting you from the wall just in case you try to apex too close. (NOTE: GT & Formula cars tend to make this 2 early apex turns with a short burst of power between 7 & 8. SS, IT, and Production cars mostly drive it as described.)
Since they've smoothed out the big bump at the apex of 8, you should be able to plant your right foot (still in 3d gear) and then hammer down and drift toward the outside wall. Be cautious on the first few runs thru here. Since the track surface changes, it can still be slick especially considering this is where the big nitro burning cars do smoking burnouts!! Also be careful not to get too close to the wall edge because the pavement literally drops off a bit about 8" from the wall, and will literally suck you in if you get too close! You need to carry your best exit speed here as it is the entrance to that long front straight. Once you straighten out here, shift 3-4 (and 5 maybe), and start checking gauges and mirrors again as you approach Start / Finish.
Share this post
Link to post
What is the format for ZCON's track day? What's all this about qualifying? Will it be a no-passing without wave-by? Do drivers get assigned instructors? Free-for-all? I actually wouldn't mind an instructor one bit. I'm kinda scared of my car....
Share this post
Link to post
What is the format for ZCON's track day? What's all this about qualifying? Will it be a no-passing without wave-by? Do drivers get assigned instructors? Free-for-all? I actually wouldn't mind an instructor one bit. I'm kinda scared of my car....and yours too! Sorry for double post-my connection sux.
Edited by RebekahsZ
Share this post
Link to post
rjracing240, thanks for the tutorial!  would you have in car video you could post?  like to put the tutorial along with the video to 'virtually' drive the track a few times prior to the actual track day.
Keith, I've asked Chris Karl a few times about instructing but not really gotten an answer or any further info to address your questions.  I'd like to contact their track day chair and post more info here for us all to benefit.
dp
Share this post
Link to post
Great. My ph# is 256/366-4685. Go ahead and put me in your speed dial so we can all get together. I've decided to stay for the show just to have more hang-out time with you guys. I'm so dang tired, I just plan to park my butt in a lawn chair in the shade and enjoy a day of shooting the bull.
Share this post
Link to post
dp
posted some links to a couple of YouTube videos in earlier post on this thread videos are pretty good and show some lines around the track.
tried to post a copy of the map to the track to follow along the tutorial that also helps quite a bit.
hope that helps
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
