1uz z31 Glitter Greenbean drift mobile
badboyz31
Man I haven't been on here in ages, well I had mostly been enjoying the car, took it out of state a couple of times to Zdayz and Fd atlanta, met cool people, had fun, but now the car is under the knife again and migrating its way to becoming a full track car. Also went to school for welding and actually started a life sometime back doing what I like to do.
List of useless crap I have done
-1uzfe swap(not quite done, just finishing up my oil pan, wiring and odds and ends)
-350z 6speed
-Collins adapter z33 and 240sx trans adapter
-Collins pilot bearing adapter
-lengthened throwout bearing hub(did it myself)
-custom 1uz flywheel
-Southbend clutch and pressure plate rated for 420rwtq
-Custom all aluminum rear sump baffled oil pan(I made)
-working on installing a full cage
-Sparco circuit race seat
-Grip Royal steering wheel with NRG quick release
-S13 rearend swap
-SPL rear control arms(RUCAs, traction, toe)
-z32 rear aluminum uprights with poly bushings
-Mazworx weld in diff plate
-q45 vlsd
-Stance Pro SS-D coils with 12k swift springs
-Extended 40mm FLCAs
-Modded angle knuckles
-3" blast pipe exhaust
-XXR 521 18x10 wheels all around
-custom engine and trans mounts(I made)
-and to top it all off stupid flake bassboat paint job. Im pretty sure im forgetting things but its ok
Few shots of the car before I started the swap
1899482_10203152872974086_10114813880485
10474905_10203116355381169_7499697888171
10329843_10203075885449446_9104414037295
10402699_10204010512774545_2100262364583
10371504_10202920553846253_2657796733326
10356360_10203058748101023_7520814544035
Few shots during swap
10616328_10203779382796440_1476108112256
10659437_10203779383676462_7680165427841
10418375_10204053042477761_6212702486504
10370356_10204053042757768_8717597067611
10352265_10203869818537277_4674809744167
10352738_10203779384756489_4265205651334
I will have more pics soon as I near completion on the car, I really dont have too much left but its getting there. I literally have to finish exhaust, oil pan and wiring and im ready to go
  • 3 weeks later...
