Sign in to follow this
malibud
Turbo stuff
Garrett gt3076r 1.06 A/R exhaust turbine, .60 inlet , T3 bolt pattern, very little shaft play worked great, water/oil cooled $700shipped
Turbo exhaust manifold with welded external waste gate flange. there is a 90 degree tube welded on it with flex pipe, flex pipe has hole that was repaired with JB weld good start for external wastegate. but needs work $120shipped
Tial 38mm wastegate $90shipped
Tial 38mm wastegate KNOCK OFF $35 shipped
Hallman boost controller with in cabin set up ceramic ball $120 (almost new paid 160)
Knock off fuel rail $40 shipped
I can work out a package deal if someone is interested will post pictures later
Edited by malibud
Share this post
Link to post
Sorry forgot . The turbo works great always water cooled the exhaust turbine is 1.3 great for power and mid to high range. I was going to switch the turbine housing but decided to go with an internal wastegate set up. So on a z car this exhaust housing it takes a bit to spool. 1 and 2nd not much spool 3rd -5 hang on ... Just want be honest about why I am selling ... Be good for drag race or freeway driving or change exhaust housing for quick spool. I didn't like the flex pipe on manifold but it would be easy to weld on to the 90 for an external wastegate.
Edited by malibud
Share this post
Link to post
Yes I have the wastegate . The knock off was on the car when bought it. I did not trust it so I got the tial. It has a 1/2 bar spring in it works great. I am going to an internal wastegate Turbo.
Boost controller sold.
Turbo sale pending.
I do have a blitz blow off valve for sale but I will first have to make a block off plate.
Share this post
Link to post
Bump still have tial wastegate, Comes with dump pipe, dump pipe elbow, and gasket 90$ shipped Blitz blow off valve it is mounted in a 2" intercooling pipe if you want different you will have to buy A BASE PLATE  . 90$ shipped
still have fuel rail as well
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
