Eibach Springs - Front sits high... *pics*
suspension springs lowering
  • Please log in to reply
25 replies to this topic
#21 Mark 240z
Mark 240z
    Newbie
  • Members
  • Pip
  • 1 posts
  • LocationN.C.
Posted 19 May 2015 - 05:29 AM
I used 280 stuck tower mounts in the rear to raise the back up to bring the car level.
#22 jhm
jhm
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 560 posts
  • LocationHampton, VA
Posted 22 May 2015 - 03:53 AM
Sorry for chiming in late, but here's another option for your consideration....
Rather than lifting the rear with the taller strut mounts in the rear, lower the front by replacing the stock strut mounts with camber plates.  Might have to do a little fabrication to get the stock spring hats interfacing correctly with the camber plates.  You wont' be able to take advantage of additional negative camber because your stock spring hats will hit the strut tower, but they should definitely lower the front end a decent amount (1 - 1.5").
Disregard all the above if you're happy with your current setup!  :-)
#23 Driver_X
Driver_X
    Newbie
  • Members
  • Pip
  • 2 posts
  • LocationSouth Jersey
Posted 22 May 2015 - 03:16 PM
You've got the springs installed backwards. Swap them front to back. Had the same issue last year.
#24 pecx
pecx
    Junior Member
  • Members
  • Pip
  • 17 posts
  • LocationHouston
Posted 31 May 2015 - 09:39 AM
So does 001 go to the rear now? I have 001 in the front and it is high.
www.86garage.com
www.jdmwhat.com
#25 PCressey
PCressey
    Newbie
  • Members
  • Pip
  • 9 posts
  • LocationLos Angeles, CA
Posted 31 May 2015 - 10:45 AM
I called Eibach to confirm that 001 goes up front, and 002 goes on the rear. The Eibach tech didn't know why the front lifted... He said they make them special for a distributor (MSA I pressume).
I am rather annoyed, and haven't gone back to that aspect of my car. I will eventually call MSA and ask what the deal is.
1973 Datsun 240Z
Currently under restoration.
#26 DAT240Z
DAT240Z
    Member
  • Members
  • PipPipPipPip
  • 197 posts
  • LocationIndiana
Posted 25 December 2016 - 02:40 AM
Pcressey, have you resolve your spring issue. If so can you please let me know what you did. Im in the market for new springs for my 240z
Thanks
71- 240
2002 LS1
6 SPEED
TOYOTA 4 PISTONS CALIPERS
Tokico lowering springs and struts.
3.70 LSD
My Z Cars
Also tagged with one or more of these keywords: suspension, springs, lowering
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
