Is there any difference between 240 and 280 struts
Hello I was wondering if someone could tell me if there was any difference between the 240Z and the 280Z Tokico illumina struts. I know the model numbers were different but didn't know if they were interchangeable. Any help would be appreciated. Thanks.
B) The 280Z struts are wider (bigger shock) and a small amount longer.  The 240Z struts are shorter and smaller in diameter.  I have been told you can cut the tubes off the 280z and weld the 240z tube on the mount and save some weight.  The 280Z springs are longer then the 240Z's.  They are the springs to use if you rally or race offroad.  I have gotten a 240Z with the 280Z springs on it and had to remove them.  They had to put spring clamps on them to bring them down to the 240Z ride height.  If you get most weld on struts like Arizona Z car, they have you cut the strut and weld on another section to replace it.  It is up to you and the way you go with it. ;)
