280zedxt
s30 blower motor upgrade w/pictures
Good day all.
Not sure if i read this here on hybrid or not, but i have pictures
I found reference to a different blower motor upgrade for our beloved s30's
Using the motor from a 1999 kia sportage (and yes it comes with the fan cage/hamster wheel, if bought new) and very minor trimming to the metal motor housing,
It fits with no rubbing, also unlike the original, it flush mounts to the housing so no spacers and you can reuse the original screws.
 I'm not taking credit, just sharing something i stumbled across on the web, which i did myself and now i'm sharing.
And yes I it moves lots of air
20150219_123008.jpg20150219_123030.jpg20150219_123058.jpg20150219_123845.jpg20150219_124830.jpg
Share this post
Link to post
Good day all.
I don't know much about these swaps, but how thick is the stock fan spacer. Just so you know, it's pretty critical that the clearance between the cage and the bottom of the fan box is not too large. I'd say you want it under 1/4". The fan needs to draw air in and throw it down the outlet. If there is too big a gap it will be sucking it self. Tough to explain, but just curious as to the stock spacer width as in your first picture there is a 1" depth difference from flanges to bottom of cage.
Share this post
Link to post
... but just curious as to the stock spacer width as in your first picture there is a 1" depth difference from flanges to bottom of cage.
The Kia "squirrel cage" fits the blower box well when you remove the stock spacers - no rubbing anywhere.
As you can see, It's also quite a bit larger and has more fins than either the stock fan OR the Honda fan.  (that's why I chose it initially...  While at the P-N-P years ago, I had a Honda blower in my hand (looked kinda wimpy to me...) and came across the Kia (it's also not just the Sportage that uses this blower) - there was just no comparison between the two blowers.  The only downside is the modification to the blower box to get the larger cage through the hole.
It moves a lot of air - definately a huge improvement over stock. If the S30 vent configuration wasn't so stupid, it would blow you out of the cabin.  As it stands it overcomes many weaknesses of the ventilation design through sheer force...
Don't forget to seal up the spaces between vent parts with new foam strips and check the hoses & tubing for leaks behind the dash - get all that air blowing out the vents not lost behind the dash!
Share this post
Link to post
@cgsheen- do you have a/c in your car? I have a/c and the additional airflow would be perfect to actually keep the cabin cool in warmer weather. The vent temps are low, just not enough air flow.
Since that day in 2009 when I put this car back on the road!  B)   This IS Arizona after all...  I was lucky that this frame had factory A/C - the interior stuff was all here & all I had to find was engine bay parts to get it working.  The stock fan always sucked and the squirrel cage plastic only lasted a few seasons before the thing cracked and came apart.  Best thing that ever happened - made me go look for a replacement...  ;)
edit:  Besides this, be sure to check the grommets in your firewall - seal up all the ways hot engine bay and/or outside air can penetrate the interior.  (shift boot, weatherstrip, etc.)  You always want some cabin air exchange, but after all these years most Z's "leak" way more than they need to...
Edited by cgsheen
Share this post
Link to post
@cgsheen
THank you! I also have a factory A/C equipped model, it's not bad on decent days if I am moving and have a window cracked just a little to get more air moving inside. But this is LA, where we have plenty of stop and go.Cabin leaks aren't too bad, the transmitted heat from the tunnel, floor, windows and roof are a problem. Time to do this upgrade!
Share this post
Link to post
my 280z was already upgraded with the honda blower, but the larger kia blower is significantly better at moving air.  if anyone is considering an upgrade from stock i highly suggest going straight to the kia unit, it's a better fan at a more affordable price(i picked one up on ebay brand new for half the cost of a used honda one).
Share this post
Link to post
This is  interesting...
There are lots of KIAs in the junkyards (duh...) so these should be easier to find than the  1988-91 Civics.
BUT....  if you want to order one that's new, you need to know which model of Sportage,  such as LX, EX...  Autoparts store kids only know  what their computer will show-  IF they know what to put into the computer entry screen in the first place.
Share this post
Link to post
I looked at an Optima fan while looking for Sportages.  It "looked" similar to the Datsun fan, IIRC, but you'd have to take it out to see for sure.
Anyway, the mounting holes from the KIA fan (mine is from a 2007 Sportage) were not the same, but I think you just need to egg-out the holes slightly to make it work.
Otherwise, the fan assembly was larger than the Datsun one, about an inch in overall diameter.  How much of the fan box can you grind away?  You gotta take the glovebox out to have enough room back there.
BTW-
While you're behind the glove box, I'd suggest you pull off  all those firewall connector and treat the terminals to a good dose of Deoxit 100...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
