Need help to get l28 running
crosseyedrob
Hello, I'm struggling to get my l28 running properly. Cranks and warms up well, but once at operating temp it stumbles under load almost like in a limp mode or something. Recently replaced injectors, injector plugs, rebuilt distributor, coil, coolant temp switch, fuel rail. Connections all appear to be secure. Removed coolant bypass system. Played with timing seemed to help at first but once at operating temp makes no difference, will rev but under load it stumbles and struggles. Any help would be great, thanks in advance
Many old L28 EFI systems are lean.  For whatever reason, old electronics, or today's fuel, adding resistance to the coolant temperature circuit can fix the problem.  Actually, it seems that Nissan might have set the EFI tune on the edge initially, especially for the ZX's, for mileage or emissions reasons maybe and now it's too lean.  It's not uncommon to find a resistor in the coolant circuit wiring on an old ZX.
Many people add a potentiometer to tune on the fly.  Search for BRAAP's EFI tips in the L Series FAQ's and you'll see it described.
If you're new to the old Z EFI system, the fastest way to get them running well, ironically, is to spend the time to go through all of the tests in the Engine Fuel chapter, or the Fuel Injection Guidebook, and give it a Tuneup to spec., before playing with anything.  The playing usually just screws things up.  The hunt and peck method never works.  All of the components and their connections need to be in proper working order.  Once you have fixed them all and know they're right, then you can make the minor tweaks to compensate for old parts, or modern fuel.
  • Like 1
Been out of town, finally tried some stuff. Coolant switch unplug did not change anything, new fuel system everything. Did fsm ecu plug test and afm pins 6-8, 6-27, 8-7 didn't ohm out, I assumed afm may be bad. ran afm resistance test off the car and on the car, and all ohm numbers are good. Checked individual wires for continuity and all checked good.Is the afm bad?
Edited by crosseyedrob
