NW240Z
Early (rusted out) 260Z part out.
RLS30-020428 for part out, Yes, it is pretty rusted and most any parts will need to be cleaned up. Still some good pieces here.
I have already removed most of the interior. Auto Trans. car.
I will take and post pictures of anything requested rather than pics of every little piece. Willing to cut up body parts as well although they are pretty rusty.
Pricing is CHEAP, make offers! Shipping is how ever you want, from 98579 USPS or UPS or local pick up.
I do still have some 240 parts from a 70 and 72.
So far I am keeping the radiator and the door glass and some small trim.
Thanks for looking.
Edited by NW240Z
Share this post
Link to post
Oil pressure sender and water temp sender please.
The oil pressure sender does not look like an original, water looks right, both of them Not sure if they work, but expect they would.  $5 + ship   post-48790-0-18414400-1431797131_thumb.jpost-48790-0-61948400-1431797210_thumb.j
Key lock set,air filter housing,thermostat housing to 85308
The hatch lock is busted I have ign. and door locks but no key.  Ignition has some rust. Air filter has rust but complete, Thermostat housing is no good. It broke coming off as the bolts were rusted into the mounting holes.  $20 for A/C $5 for locks + ship                       post-48790-0-05127300-1431797546_thumb.j
post-48790-0-34128000-1431797550_thumb.jpost-48790-0-92768800-1431797554_thumb.jpost-48790-0-63889700-1431797559_thumb.jpost-48790-0-86490600-1431797564_thumb.j
is the oil cap the "elephant oil" kind? still available? lmk. thanks!
It in not the Elephant Cap just a OIL cap and it is cracked. $0.00
Do you have the longer or shorter variant of choke cables?
They are about 6 feet long but have some cracks and missing parts of the outer cover. Action is stiff but might free up with some lube.  $ 5 + shipping     post-48790-0-64679100-1431797271_thumb.jpost-48790-0-17239700-1431797275_thumb.jpost-48790-0-27520400-1431797279_thumb.j
Share this post
Link to post
I would like the front lower control arms please, cheapo shipping to 17268.
Just got the front end torn down a little, good timing.
Standard post is $24  Priority flat rate is $11.30  $2.00 for paypal
$33.30  Shipped with bolts.
Share this post
Link to post
Window regulator both sides, how much?
The drivers side was rusted beyond use.
I still have the passenger side that is intact and moves up and down with some surface rust.
It should clean up nicely.
$35.00 + shipping & PP fee.
Share this post
Link to post
How much for the hood latch and a front tension rod?
might also be looking for the rear control arms.
Like all the other parts on this car the latch is corroded, but I was able to clean one up in my media blaster. From there you can Tin Zinc it or powder coat or paint it
or chrome it or whatever. Thats you to each person.
So are you looking for the 1 or 2 female pieces on the car body flange? or do you need the male end on the hood?
The control arms are still on the rear, they look about as rusted as the fronts I posted a picture of earlier in this thread. The tension rods look about the same
useable but need to be blasted and POR'ed or powder coated.
I can add pictures later this afternoon when I get home from work. let me know if you want to see the parts.
I am thinking $5.00 per piece for the hood latch parts as is. $10.00 per T rod as is. + shipping
Share this post
Link to post
Some pics of the latch and the threaded portion of the arms would help a lot.
The latch parts move freely, just corroded like I said.
The thread ends of the TC rods look fine the nuts screw right on by hand. just the shaft has the rust but it looks like it would clean up.
Share this post
Link to post
What kind of shape is the front crossmember in?
The cross member looks decent, about the same rust as these other pictures. It is still holding up the motor right now though.
I do have one off of a 240 that is already removed, it had about the same rust as the 260.
Edited by NW240Z
Share this post
Link to post
I need the small top "L" shaped passenger side corner piece of the stainless trim on the rear hatch glass.
Thanks
Dennis
Hey Dennis,
All the trim had been sanded and painted black at some point which is now mostly peeled off.
It all came off the seal complete, although not restoration quality or anything.
I'm am thinking I would like to try and sell it all as a set first, before breaking it up in separate pieces.
Share this post
Link to post
Hey Dennis,
OK, thanks for clarification.  Makes sense to sell it as a complete unit if you can.  The search continues.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
