Early (rusted out) 260Z part out.
  • Please log in to reply
119 replies to this topic
#41 beaniam
beaniam
  • LocationNJ
Posted 31 May 2015 - 05:08 PM
still have the rear strut mount isolators? are they tall like 280z?
76 280z, CAI, 240sx TB, 6-2-1, 2+2 flywheel/clutch, 81zx 5spd, 4.11, 15.07 et. sold 2006.
78 280z 5spd parted out
75 280z 2+2 parted out
77 280z, 82 zxt swap, t5, megasquirt, intercooled rb25 turbo, ARP studs, 440cc, pallnet rail, walbro pump, 60mm TB, 3" turbo back with electric cutout, welded r200 3.54. Current project.
#42 NW240Z
NW240Z
  • LocationWashington State
Posted 31 May 2015 - 06:02 PM
I do still have them, I saw your wanted post recently. My 260 is in the first 60000 VIN and I understand that to mean most of the parts are more 240 related. After 60001 they switched to more 280 related parts. Mine is 20xxx
Regardless, if I lay the isolator on a flat surface the top of the main body is 2 7/8 inches and 3 1/4 to the top of the stud.
In my opinion they are the shorter 240 style.
#43 beaniam
beaniam
  • LocationNJ
Posted 01 June 2015 - 02:06 AM
http://atlanticz.ca/...ng tech tip.jpg comparison
#44 NW240Z
NW240Z
Posted 01 June 2015 - 03:36 AM
Mine are definitely the shorter ones.
Best of luck in your search, wish I could have helped you out beaniam.
#45 beaniam
beaniam
  • LocationNJ
Posted 01 June 2015 - 06:33 AM
ok thanks anyway
#46 McDoogle
McDoogle
  • LocationUnited States, California
Posted 01 June 2015 - 10:38 PM
do you have the gas cap?
#47 Roanz
Roanz
  • LocationRaleigh
Posted 02 June 2015 - 03:49 AM
Hello. How much for the bumpers and bumpers and brackets? Also for the two rubber boots between the AFM and air cleaner and manifold (if still pliable and in good shape) shipped to 27608. Thanks.
#48 NW240Z
NW240Z
Posted 02 June 2015 - 03:38 PM
I do but it was pretty rusty. I bead blasted it and wire wheeled it as well. I cleaned up the rust but it is pitted badly.
I have some pics if you even want to see it.
#49 NW240Z
NW240Z
Posted 02 June 2015 - 03:42 PM
The bumpers are pretty shot. I think there was a pic pack in the post somewhere of the front one. The brackets are pretty rusted out too.
This car had the flat tops, no Air Flow Meter. I am not sure about the other boots you are referring to were you thinking this car had FI?
#50 NW240Z
NW240Z
Posted 08 June 2015 - 05:20 PM
Sold list :
Driveshaft
Steering wheel
HDLT and TS switches
front turn signals
Headlight scoops
Hood latch (3 pc)
1) front hub
#51 Craig76z
Craig76z
  • LocationWillow Grove, PA
Posted 09 June 2015 - 11:03 AM
Mustache bar?
#52 NW240Z
NW240Z
Posted 10 June 2015 - 03:12 AM
Mustache bar?
Still available. $30 +shipping.
PM sent
Edited by NW240Z, 10 June 2015 - 05:12 PM.
#53 Z Guy KY
Z Guy KY
  • LocationLouisville , Ky
Posted 10 June 2015 - 04:07 AM
Do you have a good trim piece for cheap - the luggage riser trim.
Its black plastic that sits right in front of the rear deck carpet directly behind the seats.
Steve
My Time Machine:  03/70 240Z #2472 - 919 Yellow - owned since 1980
Enjoying The Ride B)
https://www.youtube....d&v=L8QKK5IDSXE
#54 NW240Z
NW240Z
Posted 10 June 2015 - 05:12 PM
Steve
Mine was cracked, Looks like you found one so all for the better.
#55 InsomniacZ32
InsomniacZ32
  • LocationVA/Vegas
Posted 10 June 2015 - 08:52 PM
How's the gas tank?
#56 NW240Z
NW240Z
Posted 11 June 2015 - 01:55 PM
How's the gas tank?
Dented & rusty inside and out,  it was holding old fuel though.
#57 Jerry Harris
Jerry Harris
  • LocationLongmont, Co
Posted 18 June 2015 - 10:45 AM
I need drivers side door panel if still available?
#58 NW240Z
NW240Z
Posted 18 June 2015 - 04:38 PM
Sorry Jerry, the door panels were disintegrated when I got the car.
I only have door panels for the 240's
#59 88dangerdan
88dangerdan
  • LocationStockton Ca
Posted 18 June 2015 - 05:25 PM
What color and condition are the 240 door panels?
#60 NW240Z
NW240Z
Posted 18 June 2015 - 06:23 PM
Dan,
One set has been recovered with some carpet and vinyl. Not the best job, but not horrible either, nice backing with no rust on the metal top, black.
The other set is stock butterscotch, some usual scuffs small surface rust on metal, but solid backs as well.
One passenger side stock panel in good shape, black
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
