240Z with 20 inch Wheels, 370Z calipers, TTT front discs and rear Brake kit
I am an older Norwegian 240Z owner since 1983.. I have had several wheels started with 14" went to 16" then 18" and now to 20" wheels. My old brakes was the toyota/300zx setup and stock in rear.
So this was my winter project, and I just want to show you some different solutions.
The front brake system are 370Z akebono calipers and the front disc's ,5 lug hubs and rear brake kit are from Gabriel at Techno Toy Tuning. He helped me alot with front disc's selection.
The caliper brakets are my own AutoCad design and has an extra front support for more stability as i moved the calipers to the front side of the struts.
Wheels are Work Gnosis HS203 20x9, offset -15mm, senterbore 73,1mm, bolt pattern 5x114,3 mm ordered by Leo at Vivid racing
5 lug Rear hubs are from Edan at Silver Mine Motors. No need for spacers. Tires are Ling Long 235/30-20.
The Calipers from Conceptz Performance. I needed to do some modificatons to fit the calipers to the hub/discs.
This setup are performing very well for street use,
No need for changing the brake master cylinder, my stock works perfect, i have really good pedal.
Most Carbon Fiber parts are from Freddy at Topstage Composites.  Pictures are just from mobile phone so quality are soso..
All this companies and my good car friends really deserve my thanks for all the good help!
Thanks, the ground clearance from the frontspoiler are 150 millimeters and with speed bumps and bad roads i need this.The tire circumference are encreased 2% compared to my old tires,
No coilovers just my old original springs.
I like a little rough ride, but it is almost the same feeling or better than with my old 18 inch wheels.
