Sectioned Struts - Need spacer for the shock
I just finished my strut sectioning and since im using shorter shocks in the rear of my 280z I will need a spacer for the bottom of the strut. I been looking everywhere and I cant find anyone that sells them.
So I need you help. Where did you get yours or how did you make one? thanks guys
Which one? - http://dupont.materialdatacenter.com/profiler/7MblW/standard/main/ds
Just kidding.  Kind of.  Most thermoplastic polymers aren't suitable for constant high loads.  They "creep".  The fine threads of the gland nut put a pretty high load on the shock and spacer with any appreciable torque.  If you cut your spacer so that it contacts the shock body via a sharp corner or small area, that area will deform easily.   Add some heat and things get worse.  Just something to be aware of.  Get the design right.
http://www.dupont.com/products-and-services/plastics-polymers-resins/thermoplastics/brands/delrin-acetal-resin.html
Easier to go wrong than right with Delrin, in that application.
