* * * * * 3 votes
73Fairlady's 240z Build *heavy pics*
  • Please log in to reply
101 replies to this topic
#21 Zetsaz
Zetsaz
    Always Here
  • Members
  • PipPipPipPip
  • 259 posts
  • LocationLogan, Utah and Seattle Area
Posted 06 November 2015 - 11:01 PM
Is that 3M undercoat just a spray on product? That's the only ones I've been able to find. Fortunately that means it's easy to apply. I assume you bought the regular undercoating and not rubberized?
#22 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationSeattle, Wa
Posted 07 November 2015 - 10:13 AM
Yes it's just the regular spray on can with the green label. Who knows how it will end up holding up but I guess I'll find out. but I sure like the way it looks
#23 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 09 November 2015 - 05:23 AM
made a threaded block plug for the crank case vent. I wanted to be able to just screw in a fitting for a line to the catch can, so i went to lowes and ended up finding a brass fitting that was threaded on both sides. I milled down the outer threads just enough to press it into the block. Its solid enough for my use, ill be running a line to a vented catch can along with the valve cover vent.
8BFF1CA0-7BC7-478A-BABD-B720F4EAD2DC_zps530EE2B2-2DEB-46F0-8400-7C3852A3B7A5_zps
Also finaly got my super sweet gold heat reflective film, and got the heat sheild in.
3E554FA7-EBE0-490D-8805-EA0E1FFB6C61_zps725F9E9D-D8A6-47B2-980E-CA4779288C65_zpsF2581464-DB3F-4364-9E14-C3B363A02831_zpsD4F38524-466A-4AF2-B2C5-98BD893D1E30_zps
#24 abdi
abdi
    Newbie
  • Members
  • Pip
  • 7 posts
  • Locationoregon
Posted 09 November 2015 - 05:19 PM
Fellow nw guy here. Looks awesome you definitely done as much work ad I've done to my Z except it's taken me 6 years lol. Married kids..you know the deal.
So I just finished rebuilding a junkyard 83zx 5 speed and installed that.
Today I just finished installing a front differential out of a nissan 720 4x4. Took it all apart to swap the buttons out of the side gears so my stub axles will bolt on. Looks like it's barely even used. It's a 4.38 ratio so it's bound to make hole shots real fun.
How was the floor instal? My passage needs it real bad. I got a set of zed findings floors and rails, I'm just a little scared cutting into the body. I'm a mechanic not a body dude.
#25 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 10 November 2015 - 05:20 AM
4.38 wow let me know how that thing is to drive, I’m interested.
The floors were defiantly time consuming and a royal pita, but other than that it’s not that difficult. Just don’t cut too much until you know where it’s going to sit, don’t want to make a bunch of small patch panels to fit it.
#26 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 19 November 2015 - 05:52 AM
few updates, I fixed the clearance problem with the front wheels. I swapped the RCA with NCRCA and everything cleared just fine. Thankfully I was able to pull just about all camber out with the top plates so i still have full camber adjustment as well.
4635AEF7-4B20-4FE7-84DD-1AF6BDCA1584_zps
6C9A3FF4-76EC-4221-B92F-42E294CE106A_zps
9928109F-B506-4FD8-8852-9314E079B31A_zps57B32954-9A26-4B6A-A817-F198CBB9E95C_zps
D34E1F8F-1809-4C14-A764-BA4771E17CBD_zps
0E67C0FC-8877-48A6-AC0F-BED86997C824_zps
#27 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 19 November 2015 - 05:54 AM
I also got a few new things from T3, i got the tri strut bar and the shiny new velocity stacks.
B8EC3723-73F4-46F6-961D-B40592448035_zps5E466CF2-498F-42BC-859F-F365ADB30422_zps45F75A3C-6F68-4718-A275-22FD828B9E06_zps23DCE96A-2345-4A95-A407-0C24D2532AD4_zps690CE25C-3AB1-4512-8ED5-909DF41381BB_zps
#28 chris_rav
chris_rav
    Newbie
  • Members
  • Pip
  • 1 posts
  • LocationJersey
Posted 19 November 2015 - 08:53 AM
This build is looking awesome!!! So many shiny parts  :wub:
#29 Cbb
Cbb
    Always Here
  • Members
  • PipPipPipPip
  • 118 posts
  • LocationPleasant Hill, CA
Posted 20 November 2015 - 07:09 AM
I could finally follow your build, aside from IG :)
Lookin' pretty good! Those T3 stacks look the business
My 240z Thread - Warning: May induce facepalming.
Instagram - @c0bangbang
#30 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 22 January 2016 - 07:32 AM
last month or two i havent done a whole lot since its been so cold out. But i did get a few minor things done
I did a little modification to my cheap catch can and added a breather filter and got it mounted
E6C71306-6347-459D-B0F9-0D33584F200B_zpsAB5003A4-5CE6-42D6-B3F4-8034AC925C6D_zps75B8D0B3-E202-435E-80E8-3081511553E1_zps26189B32-0E22-4D86-B676-C3D5602CBE6C_zps
then i started the throttle cable conversion. made a bracket out of 2" angle iron.
4A547B66-49D0-4665-B24E-94F09D1DA8EC_zpsEB074375-B415-45E0-8164-682343E783EC_zps01E2FD79-C6DD-4996-B429-A2D8812D3230_zpsC2F7329C-2D42-4259-8D85-B40494388160_zpsF0483B9D-2E15-4226-AB12-D80FED6B5666_zps339CC567-A37D-4755-A33A-9F64D7E13598_zps
After i adjusted the arm and added the spring
EDC155FB-B0C0-4B7A-AE03-E952900BA80B_zpsB4A28FED-120C-4AB4-BD1E-E6231052892F_zps
#31 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 05 February 2016 - 07:46 AM
got the fuel rail all figured out, only thing is its going to be a real challange if i need to re jet the carbs. Otherwise i really like the location.
8AB84BB2-9732-44B1-9A52-8FE69B3FE48D_zpsA691312C-9935-47C3-AE63-E2D086436C83_zps326F6566-CEC9-4C80-B687-6EAFFFC8544A_zps
#32 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 05 February 2016 - 07:48 AM
I also picked up a 280zx distributor and a MSD coil, have yet to put it in.
1C0DF410-97CB-43B6-8254-03D5B7E8E173_zps5233E74D-E64E-46B0-8481-1895A4CCE0C8_zps
Im also having some trouble figuring out a filter solution to the velocity stacks. The T3 stacks are quite large and dont leave much of any room to slip a filter on. was playing with the idea of a base filter but not sure i like that much. but other then doing a full airbox a sock filter would have to be really thin to work.
something similar to this would be the base filter
Edited by 73Fairlady, 05 February 2016 - 07:52 AM.
#33 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 19 February 2016 - 05:45 AM
drilled and retapped the valve cover breather for 1/2 NPT so i could use AN fittings. came out looking pretty good.
4AFCD30A-BC4C-4098-BB9C-A845ECC53BC6_zps4A4A514E-CFAC-4DD1-A636-D102E6FC95E2_zpsEEE0F2EF-CB64-4BB7-B81A-C109B853DB5C_zps
I have aslo been playing around with how to mount the fuel rail so it does not cover up the jets. i dont want to remove the fuel rail if i need to rejet the carbs. I tried this but its about 1/8" from clearing the tower bar. I ordered this 90 fitting that should give me a 1/4-1/2" more clearance.
989CBC48-A99F-4534-AD0D-3B0411B7600E_zps952B3237-B5BE-4CF1-839F-B8A7BEDCDC51_zps
Edited by 73Fairlady, 19 February 2016 - 05:50 AM.
#34 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 22 February 2016 - 05:17 AM
Got a few other things done this weekend. I got the AN fittings and they clear everything with tons of room and leave access like i wanted. Now that i finally have that done, Ive gone through so many fittings...
5E32623E-8CB5-40DC-9ECF-2A31189F3E47_zps9189B7D2-428B-4315-8BA2-AAB3E238A784_zpsEABE2566-233C-4715-AC6F-25775004CA00_zps7E12FB13-729F-4741-972C-A1B9A8E6FF11_zps
I also got my radiator, ended up going with a Champion 3 row with two 12" fans and shrowd. It is a little bit overkill for the set up but a little overkill never hurt anyone. Clearance is tight but everything fits.
3C971DED-53F8-4B9D-BE66-DD7A0FD6C245_zps96FE8F39-DDB4-4566-99B1-E371139C4EC0_zps7E5230DF-7830-41C9-A71D-E68CA216A0E4_zps107FD7F6-08F0-4A7C-9235-D83AD3BC3E1D_zps8661F5EB-40E9-4BF9-A0C2-75C6EAF863FF_zps
The fans came with those tie things to mount to the radiator, I didnt really like that going to the shroud so I hard mounted them with bolts instead.
#35 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 26 February 2016 - 05:18 AM
I had the botom thread strip out on the passanger side water outlet. I tossed around several ideas to fix, but not wanting to take the front cover off eventually found this. Its a M8 to M9 repair stud, was not easy to find. Ended up ordering it from a moped shop in the uk. But it works perfect!
16083CCC-3B01-4C61-B7AC-11EF5B8F7F40_zps12C2BA06-8F17-49FC-8E16-191D9BC181AE_zps62D1FCA7-2514-48A8-BD58-D9567BF564D5_zps1201540D-CFB4-4208-8DCC-2C0BC6E814E8_zps
Also (i know its a crappy picture) I got my skillard door panels in. Have not been able to test fit yet but the finish and quality of these things are top notch!
#36 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 29 February 2016 - 08:30 AM
Got a few things done over the weekend. I got the Misimoto rad hoses in and the distributor in, and got the new ss hard line and braded soft clutch line all run. then i got just a few random shots of how its sitting at the moment.
2CF08FDD-D136-41DF-B8F2-979776F7ADAB_zps5147038B-6F54-42A1-845E-FCFE2DEFC3E5_zps43A0ED68-4BCE-4E24-B398-8BC754719F00_zps3C2DBEC3-9F74-45E0-8FD3-D0C6DD55FD57_zps
Still have some small stuff on the engine/engine bay to take care of. Need to start working on body and interior.
Edited by 73Fairlady, 29 February 2016 - 08:44 AM.
#37 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 03 March 2016 - 08:22 PM
got my new quick release a few days ago. I do not like the tipical ball lock type, I had a bad experiance with one and wont go back. So surcjhing for a spline drive that was quality and wouldnt brake the bank, came accross this on a scca forum. LTB spline type, got it on ebay for $135 shipped. It was listed at $155 on ther site. feels very solid, will see how it holds up, but dont see it having issues.
7299F654-33B0-4CB7-B01D-14F4BB4FA2F8_zpsF97748A3-51F9-4E85-9F13-53CB457E9243_zps39BFE495-D702-43AC-AC75-1A52DD76769C_zps27B4D6B9-4FB7-4A30-9D45-85016CD16444_zps
#38 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 10 March 2016 - 06:22 AM
Got some new parts in the mail, my repo JDM grill and my autopower roll par come in.
16AF2E42-4365-4C70-B549-2833DA4600E5_zps37D61B54-A55E-4799-9F28-9E66AA80B366_zps
And some pictures off progress because there cool looking.
B1B377F1-EF86-4A02-B26E-9257F6465720_zps978338D6-8B53-4E4B-9A69-8155580C79CA_zps63A39A4B-DDD1-4D45-9FFB-E4866F97888A_zps448228BC-8915-4681-A225-E365DE9F7B35_zps
I’m also trying to figure out what to do about the steering wheel. It is too close to the driver with the quick release. Currently I have a Momo hub, from what I’ve found the BOSS hub and NRG hub are about the same. I’m thinking about using a Grant hub with adaptor or make something to work. The Grant hub should only be about an inch vs. 3 inches. Should give enough along with a wheel that’s not as deep to give a comfortable driving position.
#39 LanceVance
LanceVance
    There are some who call me... Tim?
  • Members
  • PipPipPipPipPip
  • 634 posts
  • LocationEl Paso, Texas
Posted 10 March 2016 - 09:50 AM
Assuming this is a harnessed car, you can do like I did and eliminate the crush portion of the MOMO hub. I needed a small spacer (available from NRG) to make enough space for the horn wiring, but you may not even need this.
2011 Subaru Impreza STI Limited Sedan - Daily Driver
1973 Datsun 240z - Running tripples, getting the L28ET!
1975 Datsun 620 Pickup - Future SR20/Ratrod project
#40 73Fairlady
73Fairlady
    Regular
  • Members
  • PipPipPip
  • 72 posts
Posted 10 March 2016 - 11:43 AM
love this idea, Im going to have to tear into this when i get home from work today!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
