Anyone running a top mount turbo on their SR?
sr20det topmount turbo manifold
  • Please log in to reply
5 replies to this topic
#1 jparker893
jparker893
    Moving Up
  • Members
  • PipPip
  • 28 posts
  • LocationSacramento
Posted 27 November 2015 - 01:10 PM
Blew my turbo on the way back from SoCal. Rather than buy a replacement turbo, I figured it's time for an upgrade.
So I did some research and bought the ISR(formerly know as ISIS) Performance RS3871.
I'm planning on doing a top mount set up and haven't seen any info on what will and what
won't work fitment wise. Is it their any issues that I need to worry about?
I've seen photos of top mount set ups on the interwebs so I am just
hoping is super easy and all I have to do is buy the top mount manifold
and the supporting mods.
BTW: these are the turbo specs
Compressor side 3" inlet
Exhaust side 0.64 A/R turbine housing, Results:
This turbo is rated up to ~380hp.
#2 speedtech
speedtech
    Junior Member
  • Members
  • Pip
  • 4 posts
  • Locationedmonton AB canada
Posted 10 December 2015 - 05:52 PM
i have a top mount turbo set up on my sr 260z. the only issue i had was the external wastegate placement against the steering. i had to space up the motor a bit
#3 jparker893
jparker893
    Moving Up
  • Members
  • PipPip
  • 28 posts
Posted 15 December 2015 - 03:23 PM
@speedtech what do you mean by "space up the motor a bit"?
#4 Big Ben
Big Ben
    Moving Up
  • Members
  • PipPip
  • 44 posts
  • LocationMadison, WI
Posted 06 January 2016 - 05:14 AM
I have this same Terrorist Turbo on mine as well.
11 Maxima
72 240z
#5 BluDestiny
BluDestiny
    Member
  • Members
  • PipPipPipPipPipPipPip
  • 2287 posts
  • LocationCedar Rapids, IA
Posted 07 January 2016 - 07:08 AM
He means the motor had to physically be raised due to wastegate interference with the steering column. I ran into the same issue with a sr20 bottom mount setup. The steering column was going directly through where the turbo sits. So I had to go top mount Everything else is being fabbed up, so it'll be a custom fit for me.
Posted Image
We race from 120MPH rolls...
Moderatio est figmentum
Le mieux est l'ennemi du bien
#6 Nv_s30
Nv_s30
    Regular
  • Members
  • PipPipPip
  • 67 posts
  • LocationNevada
Posted 05 February 2016 - 02:05 PM
I am running a top mount but I am about to switch to a front mount turbo right in front of the steering rack
Also tagged with one or more of these keywords: sr20det, topmount, turbo, manifold
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
