71 240z rb20det fully fun slow project named candy build
rb20det swap 240z 1971 rusty
  • Please log in to reply
51 replies to this topic
#41 Wizzurp
Wizzurp
    Always Here
  • Members
  • PipPipPipPip
  • 112 posts
  • LocationTexas
Posted 11 February 2017 - 07:15 AM
My 280z speed sender never really worked. I swapped the skyline one in and it just reads low but it's consistent.
#42 mtnickel
mtnickel
    Member
  • Donating Members
  • PipPipPipPip
  • 282 posts
  • LocationSurrey, BC, CANADA
Posted 12 February 2017 - 10:43 PM
not sure about the RB20 trans, but the RB25 requires a Navara/D21/Nissan hardbody truck sender. Depending your ratio, you can swap the RB20 skyline gear onto it with a little fab work. Details are on this site. Good luck with the build! I love my RB-Z and will never let it go
#43 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
  • Locationsilver spring.md
Posted 15 February 2017 - 02:51 PM
Thanks bro I was able to slid the speed gear in the rb20det trans with a little grinding to put the lock bolts thing on!
I cant wait to drive this car! I know the rb25det has electronic speed sensor and the rb20det has the mechanical one. I swapped it on the stock one with a littkle fab just like you said.
I had time to play around with the 280z tank some more
#44 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
Posted 27 February 2017 - 03:54 PM
Back at it! Got the walbro 255lph mounted up. All I did was mount the pump to some sheet metal I had laying around then mounted the it to some threaded holes(maybe for a optional stock efi pump?) and secured it down with some bolts a had laying around. Datsun/nissan really made this conversion pretty simple.The wiring for (green pos? and blk for ground) it is right there too! Here are some pics and a video. It took like 3 hours.
Attached File  datsun99.jpg   137.22KB   0 downloads Attached File  datsun100.jpg   78.05KB   0 downloads
#45 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
Posted 02 March 2017 - 08:36 AM
I installed the gas tank. I was able to reuse the 240z straps and filler neck. I bought new hoses and j bolts from lowes.
#46 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
Posted 20 March 2017 - 10:50 AM
I installed the shift knob, now to complete the rest of my interior lol its such a mess.
Attached File  datsun101.jpg   126.85KB   0 downloads
#47 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
Posted 28 March 2017 - 02:53 PM
I used those an tube adapter fittings on the hard lines for the feed and return. There is a video on how I did it.
I was trying to tie up some loose ends on the fuel system but found a cracked up vapor tank lol. Here's another video.
#48 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
Posted 29 March 2017 - 08:01 AM
Hey guys hope you are enjoying the videos, I installed the turbo back on the motor with new studs and cometic gasket!
#49 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
Posted 30 March 2017 - 01:44 PM
Installed these LED headlights! I tested them before I installed them. They are bright! I don't recommend the ones with the box on the harness because it didn't it into my headlight housings.
#50 calZ
calZ
    Regular
  • Members
  • PipPipPip
  • 99 posts
  • LocationCalifornia
Posted 30 March 2017 - 03:52 PM
Those looks more like flood lights than a headlight with a proper reflected housing. What does the light pattern look like?
#51 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
Posted 31 March 2017 - 10:44 AM
Here is the link to exactly what I bought. Just the middle lights turn on with low beam, pattern unknown yet its been raining everyday since.
http://www.ebay.com/...UdXuqR9&vxp=mtr
I had purchased a half radiator and installed it using stock body bolt holes! This car is so mod friendly! Its a 2 core honda radiator with a shroud and fan. Evo and honda guys swear by them. I sourced info from here and pulled the trigger to try it out for the rb20det weekend warrior/garage queen.
http://www.evolution...e-radiator.html
I will document temps and conditions as well. I just couldn't spend 350+ for custom rad + shroud +fan yet. 85 bucks later its installed.
#52 bestlowrida
bestlowrida
    Always Here
  • Members
  • PipPipPipPip
  • 107 posts
Posted 02 April 2017 - 06:38 PM
Did a quick led headlight review
Also installed the intercooler!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
