530ZX - In progress
  • 3 weeks later...
Stock brake booster and Wilwood CMC came in. Primed and painted in wrinkle black
Rigid Racing CMC adapter and Z32 1" BMC
Finished up the sound deadening removal in the rear and found some Doublemint
  • 3 weeks later...
Z31 brake booster and the Z32 1" BMC
The last few weeks have been all about cooling and power steering in an effort to get everything underhood completed.
Main shipment of power steering parts
More presents
Ended up going another route and will not be using the coolant inline filler pictured
Plug!  Please subscribe on YouTube
Making the PS pressure line with -6AN PTFE
Removing the barbs on the water pump
Derale Fan/shroud came in. Fit and finish are excellent.
Pleasantly surprised to find that the fans are SPAL.  2000 cfm each
Going to have to drop the rad down an inch or so to accommodate the thickness of both the rad and fan shroud
Ebay fuel pressure gauge started leaking oil already, so it will be replaced with this Aeromotive one
Majority of the last shipment came in today.  Waiting on the Canton surge tank, swivel tstat housing and oddball fitting for the tank
Not 530ZX, but also had my Doug Rippie revalved Bilsteins  come in today for the C6Z
Made some drop mounts out of aluminum tube, rubber well nuts with 10-24 threaded inserts, ss all thread, and ss hardware.  Not that it matters, but i didn't have to modify the car at all with these.
First cooling line mock up
Swivel Tstat housing and Canton surge tank came in
Final coolant mockup to determine gaps
Swapping bottom coupler to a 45
Straight 1/2" NPT to 5/8" isn't going to clear.  Will order a 90 degree
Clears the hood...barely
Plenty of room for a turbo
Bam!  Picked up a T56 locally out of a LS1 Fbody
More parts came in
Hey free shirt
Finally weighed the sound deadening and "over panels", and I was pleased with the savings.  Most likely another 5 lbs in the shop vac and a bit more unaccounted for
No more flux core
Replaced the rear seal
Pulled the engine again to get the clutch installed, trans bolted up and final prep on the bay done
Pilot bearing installed
Clutch installed
Heater core ports tapped
I just had my first child a week ago so i haven't gotten much done.  However some of the grandmas came over a couple of days ago, and I did manage to get the clutch slave cylinder fittings swapped over and bolted onto the trans
