Mikuni PHH - accelerator pump nozzle alignment
Samurai7one
Moving this here from the L-6 engine forum to hopefully get some input:
I had taken my triples off a couple weeks ago and wanted to check the accelerator pumps for consistency. Noticed a strange pattern on two of my carbs. One carb shot straight out as you would expect but the other two shot out to the side at least at a 45 degree angle. Definitely not in a direction that would be shot down the intake, but would get squirted onto the side of the intake probably about an inch away from the carbs. The angle of the streams from the barrels were parallel, both to the right.
Any way to adjust this? Any ideas on cause?
Thanks!
