Fuel pulse damper delete?
Wizzurp
Ok had my fuel outlet line off the pump come apart on me earlier today. Had some spare tubing in my car so I ran it straight from the pump to the feed hard line so I bypassed the fuel pulse damper.
I guess what I want to know is will this have any sort of detrimental effect? Wideband seems to read the same
It can cause driveability problems but a length of rubber EFI fuel hose can have a similar effect as the damper so you might be fine as-is. Generally a return style fuel system is less likely to require a damper but many OEMs included them even when return style fuel systems were the norm.
After I wrote this post I realized my rb20 fuel rail has a damper built onto it along with the fpr on the back end so I think it'll be perfectly fine.
I was curious to see how many people do away with it or keep it and what their reason was though.
Thank you for the reply!
