Sign in to follow this
seattlejester
240z suspension bits and R200 4.11 diff
240z suspension parts, less then about 1000 miles or so on them.
Would rather keep the units intact and would rather deal locally unless buyer wants to pay for shipping, I would be hesitant to ship the differential. It weighs nearly 100lbs including the half shafts and would nee a dedicated bin as cardboard will not keep this item intact. I have a few interested parties, but would really prefer to deal locally.
I bought all these parts new and the history can be tracked on my build thread on here. I pulled these because I was tired of setting them back up. After pulling I realized there are plenty of holes on the top and bottom to secure the spring so it doesn't need to be manually set. I have zip ties holding it all together right now, I also have a stack of steel CV boot ties that I can toss in for a more permanent setup.
Front uprights $250:
MSA camber tops
KYB Blue gas shocks
280z tokico springs cut via Johnc's write up
Cleaned, wire brushed, painted
A0223805-202C-432C-9D4C-6C95451B0CCA_zps
Rear uprights+control arms $275:
MSA camber top
KYB gas shocks
Nissan quest studs
Stub axles don't seem to be bad (no visible wobble or excessive noise, one side looks to have potentially been replaced, wrench marks on axle nut)
F65D0911-225B-453D-BDE5-CAD91143CB38_zps
Front control arms SOLD
555 ball joint
Energy Suspension Polyurethane bushing
Welded pivot fork
Sandblasted, painted
F1327DE9-BA7B-4184-BCF7-B13BA394B9ED_zps
Tension arms $25: (pending....)
G-machine ball/socket joint (teflon joint on one side is cracked)
New rubber bushing
3B50762C-28CD-4961-838B-772F2291B3DE_zps
Rear differential SOLD
Longnose
4.11 from a 200sx, opened and checked to confirm
Welded spider gears
Rear cover gasket replaced on reassembly
Half shafts included
Has 70-90w fluid in it.
Doesn't whine or anything
Cleaned, brushed, painted.
Edited by seattlejester
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
