1975 280z fuel pump/power relay resistor
Help! I can't afford a $130 relay at the moment as I'm currently in college and trying to get my girl on the road to move to Oregon with me. I have a 240z with an L28 and 4 screw carbs, just couldn't get them to function properly so decided to swap the engine back to fuel injected. I bought a "complete" kit from someone off craigslist, the harness had wires cut and was missing a larger return line, ballast resistors and the fuel injection relay. Purchased the resistors, studied the sh*t out of the wiring diagram, more than I study for my classes (mechanical engineering btw) repaired the harness although I do need to buy a harness repair kit because the connectors are crap. But here is my problem, I hope the pictures work, coming from the air flow meter pump contacts there is a resistor, can anyone tell me what resistor I need.
I'm going to guess it's just there for surge protection (flyback?) back through the AFM contacts when the start signal comes through.  But I'm just guessing, no formal training.  Here's a picture of the resistor inside the relay,1976 version (I had a broken one handy).
I'll let you fconfirm the color code, I've forgotten what I never really memorized.  The diagram is from the 1975 FSM Engine Fuel chapter.
Edit - the internet makes things too easy...  Digikey color codes.  About 3 ohms, if my eye reads the colors right.  Not much.
Edited by NewZed
I'll see if I can figure it out but it's a tight fit and I don't have the urge to take things apart right now.  In the meantime, you might just consider getting a typical Bosch relay with the diode already spec'ed and built in.  They're very common.  They even mold or print a diagram on the case, showing either a diode or a resistor or neither.  I'm sure one of those would do the job and save you some time.
http://www.bcae1.com/relays.htm
