Anyone wanna help?
Your location says Seattle, the car in Olympia though?
I live near Centralia and could come and help some too.
I ask the same question as Equizyme, when were you planning on doing the swap?
That is a pet peeve, but the last guy I met goes to school in seattle and had his car stored elsewhere.
I noticed that this is your first swap. Do you even have all the parts? I think you need to space the trans cross member, did you already get it modified? You need the engine brackets from the stock motor, you need the T5 drive shaft, possibly shortened, high pressure fuel pump, wiring for fuel pump, both wiring harnesses.
