* * * * * 2 votes
Ford 8.8 IRS swap v2.0
  • Please log in to reply
88 replies to this topic
#21 bramagedained
bramagedained
    Always Here
  • Members
  • PipPipPipPip
  • 122 posts
  • LocationMN
Posted 21 September 2016 - 12:42 PM
FWIW, Will's kit has gone in 240/260/280s so they must all be very close, at least between the mustache bar mounts and the welded nuts for the front mount.
#22 yellowoctupus
yellowoctupus
    Member
  • Donating Members
  • PipPipPipPip
  • 323 posts
  • LocationSilverdale, WA
Posted 21 September 2016 - 03:29 PM
And I dont like that it requires buying a new rear cover.
Yeah, but you should be able to run basically any 8.8 cover; steel, cast Al, whatever.  I guess with a steel cover, you'd have to run some 5mm spacers between the mount and the cover, to account for the steel cover being thin, which would throw the front diff to body mounting holes out of alignment.
The issue with doing a 'sandwiched' plate as you mentioned earlier is you have additional sealing surfaces to maintain. (So the whole plate will have to be very flat (±0.005"??) Are you thinking gaskets, or RTV here or what?
th_280z8.jpg?t=1288666770
Phil - 1978 280z + 4.6L SOHC DOHC Ford, just a 300hp Lincoln Engine Folks, nothing to see here....
#23 Ryan Merrill
Ryan Merrill
    Always Here
  • Members
  • PipPipPipPip
  • 364 posts
  • LocationNewcastle Ontario
Posted 28 September 2016 - 06:56 PM
Subbing. Hopefully this gets built. Many of us need that upgrade, including myself
#24 Nelsonian
Nelsonian
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 757 posts
  • LocationSan Diego, CA
Posted 06 December 2016 - 08:59 PM
Just bumping this to see if anything new has occurred.
Nelsonian, San Diego, CA.
#25 buff_n3rd
buff_n3rd
    Newbie
  • Members
  • Pip
  • 5 posts
  • LocationSacramento, CA
Posted 10 January 2017 - 03:36 PM
Anything new with this?
#26 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 119 posts
  • LocationDayton Ohio
Posted 11 January 2017 - 07:17 AM
Sorry all, I'm extremely slow with remodeling my home at the same time.
GOOD NEWS, EVERYONE
teamzmotorsports in Michigan has my designs as of this week and are working on on the fabrication work.
1971/2 Datsun 240z, Currently swapping in a mild-built carb'd LS1.
Daily Driver: '09 Jetta Sportwagen TDI - Malone Tuned,  45+mpg
#27 DeathByNissan55
DeathByNissan55
    Moving Up
  • Members
  • PipPip
  • 30 posts
  • LocationMilwaukee, wi
Posted 11 January 2017 - 07:24 AM
spitsnaugle - when you do have the time, could you give an overview of what you plan to provide in this kit, along with a list of items you plan on keeping standardized - like bushings, nuts, bolts, etc.
Also, have you come up with a plan for axles yet, so far the cheapest sounds like to use the explorer axles, have them cut down, then resplined for z31 outer joints (may be wrong about the specifics on that, just trying to give an example).
Would love to hear some ideas.
I dont remember if I said this anywhere but I'm very interested in coming up or helping with a design that will make it nice and cheap and easy for S30 people to get this done....and, ya know, to be able to handle lots o torque.
#28 Nelsonian
Nelsonian
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 757 posts
Posted 11 January 2017 - 07:31 AM
I'm certainly watching and looking forward to what will come of it.
#29 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 119 posts
Posted 11 January 2017 - 07:46 AM
Due to slight differences in the Inner CV mounts between Cobra and Explorers -- I'm only looking at providing the mounting hardware.
Axels, etc. is all up to you guys. I'll provide lengths based on what I use once I get my parts back from teamZmotors and can mount everything.
I used the driveshaftshop's Ford Explorer 8.8 inner CV mount for 108mm or Porsche 930 CV joint. I think it was $500~ for the set. Numbers below:
108-FD-I-31  Ford Cobra to 930 Stub
108-FD-I-31-2  Ford Explorer to 930 Stub
The bushing mounts I'm having made are similar to ArizonaZ, TechnoToyTuning, and Whitehead, I dont know what bushing they use, but mine are based off of Energy Suspension 7.1102G.
Edited by spitsnaugle, 11 January 2017 - 08:32 AM.
#30 Neverdone
Neverdone
    Always Here
  • Donating Members
  • PipPipPipPip
  • 326 posts
  • LocationMilwaukie, OR
Posted 11 January 2017 - 09:55 AM
Good, getting away from Z31 parts is what we need to do. Every year there's less and less of them, so moving onto something else is a great idea. 930 CV's are insanely plentiful and can be found used on all sorts of vehicles.
You wouldn't happen to have a picture of your design would you?
#31 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 119 posts
Posted 11 January 2017 - 10:13 AM
The rear:
6qmnxnZ.png?1
  IufkDPM.png?
#32 DeathByNissan55
DeathByNissan55
    Moving Up
  • Members
  • PipPip
  • 30 posts
Posted 11 January 2017 - 12:47 PM
I understand your wanting to get away from using Z31 joints, but are the 930 joints really that affordable?  I believe the weak point of stock 930 joints are the cages, so if you upgrade those, use explorer inner CV mounts and explorer axle shafts cut to correct length (resplined for 930 joints on inner and whatever widely available nissan joint you use for the outer/whatever hub you're using), wouldnt that be the cheapest route while still maintaining high torque capability?
Please anyone add their experiences as it sounds like spits has the diff mount part of it under control.
Edited by DeathByNissan55, 11 January 2017 - 12:48 PM.
#33 Neverdone
Neverdone
    Always Here
  • Donating Members
  • PipPipPipPip
  • 326 posts
Posted 11 January 2017 - 01:54 PM
Many BMW's use 930 joints in their CV axles. I picked up a set of E23 axles from a pick and pull which has two bolt on 930 CV joints for dirt cheap.
Almost all dune buggies use 930 joints as well, so getting custom axles is actually as easy as it can get.
Loving the design of the bracket! Sandwiching it between the diff cover and the housing would require two gaskets, but you could run any cover you like...I'm a fan.
#34 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 119 posts
Posted 13 January 2017 - 08:07 AM
Hi all, I could use a measurement if anyone has Ford Explorer 8.8 differential from a 2007-2011. (or any others that has two front mounts)
My diff only has the front mount on one side, so I need the measurement of the distance between the two front mounts, (center to center) if anyone has calipers large enough to get that, I'd be super thankful!
#35 NC88
NC88
    Newbie
  • Members
  • Pip
  • 17 posts
  • LocationLe Claire, IA
Posted 13 January 2017 - 08:14 AM
I have an '09, I'll grab some measurements when I get home tonight.
1973 240Z LS3 TR6060
#36 NC88
NC88
    Newbie
  • Members
  • Pip
  • 17 posts
Posted 13 January 2017 - 02:10 PM
166mm center to center.  The mount holes are 12mm diameter.
#37 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 119 posts
Posted 18 January 2017 - 11:06 AM
The rear:
6qmnxnZ.png?1
  IufkDPM.png?
ROUGH drawing of the front mount. Ron Tyler style, extended back, bracket on top to mount an adjustable rod end and separate bracket to tunnel.
Edited by spitsnaugle, 18 January 2017 - 11:10 AM.
#38 Neverdone
Neverdone
    Always Here
  • Donating Members
  • PipPipPipPip
  • 326 posts
Posted 18 January 2017 - 11:48 AM
I'm assuming the mounting holes are going to go on those little tabs on the inside of the main bracket.
Seeing as you'll have to weld them on, could you also weld a gusset to the back of that opening for added strength?
I've attached a MS Paint edited drawing
#39 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 119 posts
Posted 18 January 2017 - 12:10 PM
yes- those will have gusset plates, but just inside, past the mounting holes.
#40 zboi
zboi
    Newbie
  • Members
  • Pip
  • 6 posts
  • LocationDurham, NC
Posted 05 February 2017 - 07:09 PM
spitsnaugle I'm very glad to see you doing this. I saw ZCD kit with the idiotic mount that bolts outside the cover requiring a new one and was wanting to make something exactly like you describe that sandwiches. Are you making a suspension upright too? I think that is the main thing to make the swap easy/cheap. I was wanting to do something like Will did but have it just use the explorer front hubs and not some Franken-dodge dealio.That way you could grab everything from a junkyard from one car, and then you can use the stock explorer CVs with just a shortened axle. Should be super easy and affordable.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
