Replacing fuel pump
Switching out noisy pump. I have braided fuel line with AN fittings. I don't feel like draining the tank so my question is can I clamp off the line from the tank as
I normally would with rubber fuel hose. I did test clamping of a spare piece of braided line and I couldn't see that any damage was done to the inner lining.
The clamping did disform the ss braiding but I was able to reshape it. Any one done this. Thanks
I wouldn't clamp a fuel line with a steel-braided cover.  The hose inside is not rubber, it's a plastic.  Plastics will be damaged and not recover like rubber if they are compressed too far.  It might be okay in its damaged state but the damaged area will be a stress riser for future fatigue, like a kinked drinking straw.  Once it's kinked it will always bend in that spot.
http://www.russellperformance.com/mc/hose/
Just work fast.
