76 280z, low idle, low vaccum
  • Please log in to reply
29 replies to this topic
#1 Turbo_the_world
Turbo_the_world
    Newbie
  • Members
  • Pip
  • 24 posts
  • LocationArizona
Posted 11 July 2016 - 02:56 PM
I have a 76 280z l28. A little about the issue, car does have a slightly larger cam .450 lift, 270 duration. Pallnet fuel rail, 210cc injectors, deleted most of the emissions items and made sure to cap off all vaccum lines. Timing is right athere 15 degrees, any lower and it will die out. I'm only getting 5in of vaccum at idle, and wot I'm getting about 10-12. Idle stays are 500rpm cold or hot. Running a little better when warmed up but not much. Fuel pressure is at 35psi and I have the stock rising rate regulator. Engine stumbles at first when the intake is opened. Could use some help if anyone has some ideas.
#2 Turbo_the_world
Turbo_the_world
    Newbie
  • Members
  • Pip
  • 24 posts
  • LocationArizona
Posted 11 July 2016 - 02:59 PM
Engine bay
Edited by Turbo_the_world, 11 July 2016 - 03:00 PM.
#3 NewZed
NewZed
    Clandestine Moderator
  • Donating Members
  • PipPipPipPipPipPipPipPip
  • 5385 posts
  • LocationWashington County, Oregon
Posted 11 July 2016 - 03:06 PM
What kind of throttle body (TB) is that?  The 76 TB has a screw to adjust idle RPM,letting air past the TB.  You might need to add a ZX TB bypass hose/valve setup.
#4 jthom5147
jthom5147
    Always Here
  • Donating Members
  • PipPipPipPip
  • 109 posts
  • LocationSan Diego, CA
Posted 11 July 2016 - 03:15 PM
Throttle position sensor: dirty contacts, poor ground?
Vacuum leak: on or around intake manifold, afm, at head-intake gasket surface?
AFM contacts dirty, loose, poor ground?
Too lean at idle? What are your AFRs like?
Distributor: vacuum leak at vacuum advance or damaged advance diaphragm, distributor cap/ rotor worn or corroded?
ORANGE BULLET - RIP
BLACK 260Z in progress, done right this time.
#5 Chickenman
Chickenman
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 669 posts
  • LocationCanada
Posted 11 July 2016 - 03:20 PM
Looks like he blocked off the Idle air adjustment with a bolt. That isn't going to help. I have my 280Z pulling 12 in with a 480 lift 280 degree cam.
WOT should be  zero inches of vacuum. Not 10 or 12. You should be measuring the manifold vacuum reading at the manifold port fitting beside the brake booster fitting. Not the " Ported Vacuum " fitting on the Throttle body.
#6 Turbo_the_world
Turbo_the_world
    Newbie
  • Members
  • Pip
  • 24 posts
  • LocationArizona
Posted 11 July 2016 - 03:23 PM
This is an MSA 60mm throttle body.
#7 Turbo_the_world
Turbo_the_world
    Newbie
  • Members
  • Pip
  • 24 posts
  • LocationArizona
Posted 11 July 2016 - 03:26 PM
Intake gasket is brand new, afm has already been tested and is fine. The tps though doesn't seem to change anything when adjusted, how would I test the tps? Distributor cap and rotor are brand new asite
well.
#8 Turbo_the_world
Turbo_the_world
    Newbie
  • Members
  • Pip
  • 24 posts
  • LocationArizona
Posted 11 July 2016 - 03:29 PM
I also have the idle air adjustment screw back.
#9 NewZed
NewZed
  • Donating Members
  • 5385 posts
Posted 11 July 2016 - 03:31 PM
Regardless, without ECU controlled idle speed, he needs a throttle body or blade bypass.  The 280Z's had the bypass in the TB, the ZX's went to a hose bypass with an inline valve.
Hard to get a good vacuum reading if the engine is about to die.  He needs idle speed control.  Set the idle speed then tune the engine.
#10 jthom5147
jthom5147
    Always Here
  • Donating Members
  • PipPipPipPip
  • 109 posts
If the intake manifold gasket is brand new, did it exhibit the problem before installing the new gasket?
A quick way to check for intake manifold leaks is to use some vacuum tube. Put one end to your ear and the other along the sealing surfaces (at bolt holes, gaskets, capped vacuum lines, etc). You'll hear a distinct "whistling" when the tip of the tube is near the leak.
ORANGE BULLET - RIP
#11 NewZed
NewZed
  • Donating Members
  • 5385 posts
Posted 11 July 2016 - 03:32 PM
What does that mean?  "Back".
#12 Chickenman
Chickenman
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 669 posts
  • LocationCanada
Posted 11 July 2016 - 03:34 PM
Do make sure that your PCV hose is hooked up and operating properly. The hoses often split on the underside. Do NOT remove the PCV system and run Vent to Atmosphere from the block breather. That will adversely affect drive-ability and cause acids and other contaminants to build up rapidly in the oil. PCV " deletes" are one of the worst thing you can do to a street driven engine.
The AFM also has an idle  mixture adjustment hidden down low. It is sometimes blocked off with a removable plug. Even with 76 models, which the FSM says does not have an adjustable idle mixture. ( The FSM plugs the adjustment screw to meet EPA standards. And then states that the idle mixture is non adjustable. Not true. )  ) You can fine tune the idle AFR mixture with this air bypass screw. Really helps with big cam shafts.
#13 Chickenman
Chickenman
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 669 posts
  • LocationCanada
Posted 11 July 2016 - 03:35 PM
That's what I run. Where's your large Idle air adjustment screw? You have it blocked off with a bolt.That's no good and is part of your problem.
Edit:
 Please post only current pictures. Other wise you confuse the issue.
Edited by Chickenman, 11 July 2016 - 03:37 PM.
#14 Chickenman
Chickenman
    Can Charge Rent
  • Members
  • PipPipPipPipPip
  • 669 posts
  • LocationCanada
Posted 11 July 2016 - 03:54 PM
larger cam shafts also require a LOT more static ignition timing. They will tolerate extra timing because the mixture density, and thus effective " Dynamic Compression Ratio "is very low at low throttle openings.
Set your static timing to 15 degrees BTDC. Vacuum advance disconnected. Then connect the vacuum advance pot to a manifold vacuum port. The small fitting beside the brake booster fitting. This will add an additional 15 degrees of timing at  or so at idle. So a total of about 30 degrees at idle. Don't worry, because of the low dynamic compression the engine will not be adversely affected. You should see your idle vacuum increase by at least 5 HG Idle should be noticeably smoother. Aim for an idle speed of about 1,000 rpm with your cam.
Do NOT use the vacuum port on the TB . This is Ported vacuum and will be zero vacuum at idle. With a larger camshaft you need MANIFOLD  or Full vacuum at idle for the vacuum pot.
Note you may have to decrease the spring tension on the vacuum diaphragm to make sure the vacuum pot stays " pulled in " at idle. See Jason Grays distributor page to see a How to Do. All Nissan 280Z dizzy's have an adjustable vacuum pot. Both for spring tension and stroke length. While you are at it decrease the stroke length to 15 degrees instead of 20 ( Add 5 degrees of static timing and you should decrease vacuum timing by 5 degrees to bring cruise timing into spec )
Link to Jason Gray's distributor page:
http://newprotest.or...yDistributor.pl
Edited by Chickenman, 11 July 2016 - 03:55 PM.
#15 Turbo_the_world
Turbo_the_world
    Newbie
  • Members
  • Pip
  • 24 posts
  • LocationArizona
Posted 11 July 2016 - 03:57 PM
Here's the current picture
#16 seattlejester
seattlejester
    Never Logs Off
  • Donating Members
  • 2064 posts
  • LocationBellevue, WASHINGTON
Posted 11 July 2016 - 04:02 PM
How are you controlling fuel? Stock ECCS will only do so much.
Also concerned about timing. Are all the TDC indicators in the right spot when engine is at TDC?
#17 NewZed
NewZed
  • Donating Members
  • 5385 posts
Posted 11 July 2016 - 04:06 PM
You were on here before, right, a short while ago?  A whole discussion about PCV systems and vacuum leaks?  Hard to keep track of who does these things.  Did you block the PCV valve on the bottom of the manifold?
If not, the big hole in the valve cover will be a problem.  Stick your thumb over it while the engine's running and see if anything changes.
  • Attached File  pcv.PNG   506.32KB   0 downloads
#18 Turbo_the_world
Turbo_the_world
    Newbie
  • Members
  • Pip
  • 24 posts
  • LocationArizona
Posted 11 July 2016 - 04:23 PM
Still have the pcv system.
#19 NewZed
NewZed
  • Donating Members
  • 5385 posts
Posted 11 July 2016 - 04:30 PM
Apply the thumb.
#20 Turbo_the_world
Turbo_the_world
    Newbie
  • Members
  • Pip
  • 24 posts
  • LocationArizona
Posted 12 July 2016 - 10:41 AM
Alright, I think I may have found the problem. The block breather, the metal part that goes into the block is very loose. Is there supposed to be a seal or is it just supposed to be a tight fit? I can wiggle mine around with ease.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
