Sign in to follow this
softopz
240z 280z 280zxt 88300zxt oem and aftermarket
Now that both my cars are done, it is time to sell everything off. All parts are in good functioning order or in decent cosmetic condition. Please view the high resolution pics below there will be a link to my photobucket only some are attached to this thread.
derale 16516 tornado 16" electric fan 2175 cfm MADE IN USA $50
s12+8 4x4 left front caliper rebuilt loaded w/pads $50
240z 260z 280z 280zx lseries or s30
ACT pressure plate/ 6 puck ACT clutch dis non spring hub/ Fidanza aluminum flywheel holds up to 500hp easy. all parts less than 1000km clutch + flywheel $480 buy these separately your easily looking at double
l series arias forged aluminum flat top pistons .5mm over with a set of rods that have material removed and balanced pins/ rings included. Very clean set ! $300
rear disc swap 83 280zx calipers-caliper brand new in box loaded with pads and hardware. the other is a clean used part. Rotors are also new. just need brackets to make it a complete swap kit or replace for late 280zx brakes. $190 why buy the $500+ rear disc swap kit
early 240z 4spd shifter $20
240z brake master cylinder (vertical flange) 7/8 bore with caps $20
240z fan blower assembly $40
240z clutch cylinder (non adjustable) $15
240z gas tank reservoir overflow / vapour tank $25
240z dash light $15
240z alternator external regulator $15
280z strut insulator front and rear (front are in ok shape the rear are very good) all four $50
280z middle console $40 *very clean has middle switches area cut out of radio
280zxt head bolt set 1 missing will throw in an arp headstud. $10
280zxt afm $40
280zxt afm to turbo boot $10
280zxt jpipe . cut at throttle body to fit 240sx Tb $15
280zxt intake manfiold heat shield $10
280zxt distributor (cas) plug $10
280zxt idle air valve IAC $20
280zxt differential / driveshaft pinion flange (for borgwarner t5) $20
280zxt fuel pressure regulator 2x one has a kink on line other i cut the extra metal around for cleaner look $25 both function fine check pics
280zxt t3 turbo in pieces was going to rebuild and add t4 compressor housing and wheel *$80 w/ to4e housing and compressor wheel $160
280zx 3 groove crank pulley With timing indicator $15
280zx ac compressor with bracket and tensioner pulley $50
280z /zx 5 spd shifter $10
280zx manual black shift boot $10
280zx 79-81 rear LEFT CALIPER $20
s30 front backing plates very clean $25 pair
s30 headlight sugar scoops very clean $30 pair
s30 wiper motor + linkage $45
s30 door handle (painted black kinda peeling) $10
s30 front pair calipers $30
s30 horn $5
s30 dog leg carriers pair $10
l series engine mounts L / R $15
l series coolant elbow to radiator $5
l series clutch and fan assembly $20
l series flywheel NA 220 mm i believe could use a resurface $25
l series oil dipstick $10
l series transmission/flywheel plate $20
l series oil pick up very clean $10
l series alternator bracket bottom to block $5
e12 ignition module $10
300zx 88 turbo 5spd (all parts listed from this model but may fit other models I know the calipers are bigger and used an upgrade to early 300zx)
compressor alternator and starter all oem nissan hitachi not rebuilt crap
300zxt compressor with bracket clutch and pulley spin freely $60
300zxt alternator $50
300zxt starter $50
300zxt boost sensor $5
300zxt blower fan assembly $25
300zxt front right caliper $30
300zxt rear left caliper $30
300zxt horn ring gear $5
300zxt horn $5
300zxt front wiper motor $15
300zxt water pump pulley $5
300zxt burgandy sun visor pair $15
300zxt middle console switch/ mirror panel $10
300zxt rear tail ligh middle panel $20
84 4 bolt 300zx rotor vented and cross drilled mounted on vehicle drove less than 100 km before changing to different setup $40
PICTURES HERE -->http://s516.photobucket.com/user/maf...s%20for%20Sale
please email me for fastest response blizzyblahblah2@hotmail.com
Edited by softopz
Share this post
Link to post
headlight sugar scoops sold
also adding
280zxt turbo ignitor w/ coil and bracket $30each I got two of these
late 240z middle console in great shape NO CRACKS chrome is perfect with shift boot, all buttons/switches and ashtrays included! $250
300zx ecu na auto great for nistune $50
Edited by softopz
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
