Engine build: L28 crank + L24 rods + KA24 pistons
lauko
Yes it may be good for a turbo, but I am building a NA engine. I bought then a LD28 crank which changes the compression ratio from cca 8.5 to cca 10.5. I will be using a 2mm head gasket - else the CR would be even higher!
I hope that with CR ~10.5 I'll be able to get some more power from the engine. 8.5 sounds a bit too low, and I could find no one with that combo...so I have no idea what power could be achieved with that.
