Rb25 oil pan
JamesRB25280zx
I cut parallel to the bottom of the pan, not the flange. That way with the tilt of the engine, the bottom is still flat. That is, however, provided you've mounted the engine with a tilt to it.
The baffling/windage tray will have to all be modded and/or cut. I went as far as to rebend all the louvers to face the other direction so the windage action was still protected. It's a fair bit of work, and I had to add in some filler pieces to patch it all together, but it was fun.
In hindsight, I'd do Less welding with the pan strapped to the engine :o . I didn't have any problems with slag getting into critical parts, but i could have.
