Sign in to follow this
KidandhisCar
82 280zx Project W/tons of parts
Needing to downsize significantly,Car is an 1982 280zx,
Rough interior/exterior. 17in enkie rims.(with custom Z centers that need to be finished and installed)
runs and drives but the brake system has a minor leak somewhere.
Car has a new master cylinder, brakes bias valve, and the silvermine stage 4 setup up front
with stainless lines.
(4 pistons calipers with gt500 drilled and slotted rotors)
Non borg warner 5 speed,unsure of rearend ratio.
I have a bunch of parts i want to go with this,
Parts:
Pallnet fuel rail,
ls1 injectors for the pallnet rail
pallnet TB spacer,
aluminum intake flange,
spare set of tails lights of a turbo 82
third "turbo" break light off a 82,
4 good condition marker lights,
A red center dash piece (where the radio mounts)
a red center console,and 2 red good condition fuel cards.
Borg warner T5
Short shifter out of a fox body mustang that fits the T5
a 3.54 rearend  with welded Spiders.
Drivershaft and axles-came out of the same car as the T5 and rearend.
Clean arizona title
Full set of rear brake lines,and msa rear rotors drilled/slotted.
Included is a completely rebuilt engine
Engine specs:
F54 block/P90 head turbo engine out of an 82
Block has been hot tanked,honed and decked 10thou
Head has been shaved 20thou,
30 thou shims installed under cam towers
and has 3 angle valve job.
Crank/rod/pistons all stock
ARP rod bolts.
has a brand new alternator on it.
includes,a turbo intake manifold with factory injectors,
turbo exhaust manifold,and down pipe.
no sensors currently on engine.
no thermostat installed.
has 82 optical dizzy.
new water pump,
High volume oil pump,
new timing set,
probably more i cant think of.
I do not have a flywheel for this engine
and rear crank seal is not installed as i cant put it in while its on the stand.
no ecu, nor harness.
also includes: random old bolts/parts from prior zs if wanted.
probably some things ive failed to mention,
but i believe this is a great deal.
I invite anyone interested to come by and look at the lot.
Any questions feel free to ask on here or I can be reached via txt or phone at 813 nine nine nine 55 two 7,located in tampa florida,pickup only!
Asking 2500$ for all of it,i believe that is below fair,i need this car/stuff gone!!
Ill post the pics as replies,thank you much
Edited by KidandhisCar
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
