Mig welding stainless steel
I know how to mig weld carbon steels and my gas tank is 75% Argon 25% CO2 but I thought I would try my hand at welding together a new SS exhaust system for the Z. I have the ER308L stainless steel wire already, do I have to change the tank over to 98% Argon/2% CO2 or can I get by with the 75/25 ?
Share this post
Link to post
My understanding was that not using tri-gas would end up with a weld joint that would eventually rust. If the piece isn't going to detriment from a little rust then no problem, but if you want the stainless property of rust resistance then tri-gas was the way to go.
Definitely different, I believe we had to play with the settings on the welder which we were using to do a couple mild pieces further down on the exhaust, different intensity and speed needed.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
