Stronger motor mounts
  • Please log in to reply
28 replies to this topic
#21 hansonsaid
hansonsaid
    Newbie
  • Members
  • Pip
  • 5 posts
  • Locationtx
Posted 19 April 2017 - 07:51 AM
So I Bought them already and installed these light night. They make a very noticeable difference in how the car drives. The power from the car is much more responsive and smooth. It really reduced the drivetrain play, so when you press the throttle, it reduced some of the "clunk" these cars have common issues with. This difference could be seen when giving the car power and letting go of the throttle. so power transfer each way feels tighter .
Overall, much more fun.
As far as noise goes. You can feel a harsh vibration when turning the starter(no big deal). Also when the engine was idling(about 800rpm) the whole car has a pretty noisy and felt like the dash was vibrating. its not over the top noisy, but if you car is a DD or built to be comfortable I would consider it to loud. When it came to driving though, I couldn't tell any difference significantly in noise level!
I HAVE TO KEEP DRIVING ON THEM TO SEE HOW I WILL FEEL IN THE LONG RUN because I do drive my Z regularly. The vibration at idle was non existent when the engine was warming up(1,200-1,300rpm). So I will try raising my idle to 900-950rpm to see if that solves the idle vibration issue.
Some extra info:
I was running new oem mounts and they were already showing alot of wear after about six months, they were running fine for DD but disappointing for spirited driving. And Now I have a 3.0 too.
New transmission insulator
Poly transmission crossmember bushing
New oem diff mount
Poly mustache bar bushing
how's the feel after a few months?
#22 gnosez
gnosez
    HybridZ Supporter
  • Donating Members
  • PipPipPipPip
  • 360 posts
  • LocationMassachusetts
Posted 19 April 2017 - 06:01 PM
My question as well. The idea that the OEM mounts were going bad after 6 months is hard to believe. The ones in the race car are 3 years old and are checked often. The ones in the street Z are even older and they're fine.
How the mounts are at idle or at 3000 rpm aren't a concern, I'd like to know what it's like going up to 7000 rpm, down to 3000 and back to 7000 in a matter of seconds at WOT.
"you're only young once, but you can stay immature indefinitely"
#23 Flexicoker
Flexicoker
    Member
  • Members
  • PipPipPipPip
  • 301 posts
  • LocationDetroit
Posted 25 April 2017 - 08:23 AM
I just installed a set of these. Unfortunately it's been years since I've driven my Z so I can't give you a great comparison. I lost 2 radiators in the past due to fan contact during aggressive braking and downshifting with stock mounts, and was always unhappy that nothing stiffer and captured was available off the shelf.
The parts are nice quality, but I had to clearance my drivers side mount a little to avoid contact with the steering shaft. Driving around with the hood off it definitely appears that there is almost no movement of the engine. Can't really comment on responsiveness or NVH... The car was a loud, rattly, POS before the mounts so I don't think they made much difference there =)
I'm happy with my purchase.
Unlike women, a racecar is an inanimate object. Therefore it must, eventually, respond to reason.
#24 NewZed
NewZed
    Clandestine Moderator
  • Donating Members
  • PipPipPipPipPipPipPipPip
  • 5385 posts
  • LocationWashington County, Oregon
Posted 25 April 2017 - 08:51 AM
The transmission mount is the third engine mount.  It's also designed to reduce fore and aft movement.  Something to consider if you're trying to reduce engine movement.
#25 gnosez
gnosez
    HybridZ Supporter
  • Donating Members
  • PipPipPipPip
  • 360 posts
Posted 28 April 2017 - 05:04 PM
Two radiators due to the fan hitting them? Maybe it's time to switch to an electric fan. Frees up some HP and space.
I'd love to hear from other folks who race as to whether they see motor mount movement so drastic that the fan goes into the radiator under heavy braking.
#26 z mouse
z mouse
    Newbie
  • Members
  • Pip
  • 22 posts
  • Locationnew brunswick canada
Posted 29 April 2017 - 01:50 PM
Seems to me,there was an article on here about using poly jeep motor mounts similar in dimensions to Datsun mounts?
#27 Grim
Grim
    Member
  • Donating Members
  • PipPipPipPipPip
  • 657 posts
  • LocationMountain Home AR, 72653
Posted 03 May 2017 - 03:53 PM
I don't have a stock motor mount anymore to compare to, but I am using poly Jeep motor mounts to hold a 7M-GE in my Z. I took some measurements off it, if it helps.
Attached File  Untitled.png   12.68KB   0 downloads
The bottom stud is centered pretty good and about 1/2" diameter. And the slots are for 3/8" bolts.
This is the mount I have. https://www.summitra...1102r/overview/
When I got them I knew I was making my own parts so I literally just went through the entire list of motor mounts and picked the ones that I felt would allow the easiest disassembly. I wanted to make the car easy to work on, which is why I built a bracket to use a poly GM transmission mount on the back of the R154 transmission.
Edited by Grim, 03 May 2017 - 03:54 PM.
"We're all a bunch of mugs! We work twenty-four hours a day, don't eat; we don't sleep and we spend all of our money just so we can go out again next Sunday and break the damned car." - Horst Kwech, circa 1970
#28 Curtball
Curtball
    Regular
  • Members
  • PipPipPip
  • 72 posts
  • LocationDallas
Posted 10 May 2017 - 05:08 PM
Different product out there can be cast to what ever you want and cure to a nice product you can replace dam near every bushing in your car with. Some 2 parts can even be poured they are so thin before they cure. Flexane is a popular one ive seen, 2 part box liners, windshield urethane.... The shore ratings are different for them all, some even available in multiple strengths. The possibilities are endless.
I didnt know a product like this existed packaged/advertised towards the car crowd. Thanks for the link!
Not nessessarly stronger than rubber, but depending on the rating it could be stiffer. When OP says he wants stronger mounts i assume he means stiffer. Id bet most of us are not putting down the kinda power that makes engines leap from the bay.
Thank you
Edited by Curtball, 10 May 2017 - 05:09 PM.
#29 stravi757
stravi757
    HybridZ Supporter
  • Donating Members
  • PipPipPipPip
  • 430 posts
  • LocationDanville CA
Posted 17 May 2017 - 08:53 AM
My car hasn't been running for a while now, so I cant say.
But the oem mounts weren't bad. They were worn from when they were new. And I could feel noticeable play in the drivetrain causing a drag/and clunk feeling between up and downshifting. Most Z people probably wouldn't think much of it  since these cars are prone to having really severe "Clunk" issues. But I daily drive mine, and it is really noticeable to me, even if its slight.
You can see on the stock mounts the rubber separates from the side on the metal quite quick, causing more engine movement.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
