Turbo Meister's TT SBC 240 Z
  • Please log in to reply
40 replies to this topic
#21 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
  • LocationMurrieta, Ca
Posted 09 January 2017 - 03:49 PM
Wow, glad you are okay. The Z looks like it will be better than ever!
 Thanks Bart...yes, I hope so!
#22 calZ
calZ
    Regular
  • Members
  • PipPipPip
  • 94 posts
  • LocationCalifornia
Posted 09 January 2017 - 04:07 PM
That paint looks nice, and it seemed to get done quickly despite it being done as fill-in work. Mind PMing me the location or a website for the shop? I'll be needing paint eventually and I'm in the LA area.
#23 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 09 January 2017 - 07:58 PM
Don't evaluate the time between primer and paint as realistic. I'm just now recently posting pics that were taken some time ago. The Z was in paint jail for 9 months before I got it back. Tom is backed up with paint jobs and won't do anything for a while.
#24 calZ
calZ
    Regular
  • Members
  • PipPipPip
  • 94 posts
Posted 10 January 2017 - 12:26 AM
Ah, that makes more sense. I'd still take that tradeoff if it came at a very good price. Not sure if you mind sharing what he charged or not.
#25 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 10 January 2017 - 07:49 PM
The Z is at home but needs everything to be re-assembled.
Big 12" drilled and vented Wilwood 4-piston front brakes have been installed. It was a close fit but with custom off-set spacers the 15" Weld Drag-Light wheels fit.
The pic also shows the Techno-Toy-Tuning Tension Control Rod. This rod is much stronger than the stock Datsun unit and eases caster adjustment.
Attached File  21.JPG   94.33KB   0 downloads
The 9" Ford differential received 11 1/4" Strange 4-piston disc brakes. The 9" is a Currie "Plus" unit with 31 spline axles and 5/8" wheel studs. The gears are 3.50's with a Strange spool.
Attached File  22.JPG   82.72KB   0 downloads
#26 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 13 January 2017 - 01:54 PM
Two Aeromotive A 1000, #11101, fuel pumps have their AN-10 outlet fuel lines joined by a Y to a single AN-10 fuel line. This line connects to an Aeromotive A 2000, #13202, Bypass Fuel Pressure Regulator. An Aeromotive,#15107, One-Way AN-10 check valve prevents reverse fuel flow through the inactive fuel pump when only one pump is running for street driving. However, both pumps are activated during racing. Two Aeromotive, #12304, 100 Micron fuel filters are plumbed between the fuel cell and the pumps.
The pics also show the Hal coilover shocks and 150 lbs. springs.
The 9" Ford has been painted Rustoleum satin black with a brush.
Brush streak marks add Character.....
Attached File  26.JPG   122.63KB   0 downloads
Attached File  25.JPG   107.73KB   0 downloads
#27 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 17 January 2017 - 04:22 PM
I have been working on rewiring the Z and preparing the engine compartment for engine installation. The first pic shows the Motorsports Auto type 3 air-dam with fog lights, which I wired to act as turn signals.
Attached File  27.JPG   102.16KB   0 downloads
The other pics show the Design Engineering Inc, #010399, heat screen with adhesive backing that can withstand 1200 F direct heat. The heat screen was applied to the areas where there was minimal header and down-pipe clearance.
Attached File  28.JPG   106.22KB   0 downloads
Attached File  29.JPG   106.15KB   0 downloads
#28 RebekahsZ
RebekahsZ
    Life Member
  • Donating Members
  • PipPipPipPipPipPipPipPip
  • 5354 posts
  • LocationFlorence, Alabama
Posted 17 January 2017 - 05:19 PM
It never ceases to amaze me how much of a unibody S30 can be cut away without affecting it structurally! Your car is awesome-maybe better than before. Makes me wanna go run my car into some pea gravel and a safety net!
1972 240z, purchased in 1991 for $900. Bone stock LS2/T56/DBW from 2006 GTO, swap completed in 2011. 400rwhp/435 rwtq. 2400# minus driver. JCI swap, Mantic ER2 clutch kit, JTR headers, single exhaust, Borla muffler, MGW shifter, M2 Differentials shortened Z31 CV axles, Z31 CLSD R200, Chequered Flag Racing billet stubs and companion flanges. MSD 2-step, Hurst roll control, both operated from switches on clutch pedal. 9" Hoosier drag slicks on Weld Draglites, 245/45/16 Hoosier A6/R6 on 16X8+10 Rota RBR. 225/250 sectioned coilovers, Koni 8610-1437RACE shocks, DP and EMI camber plates, MM shortened rear control arms, TTT front control arms, poly and aluminum bushings. Top speeds: Ohio Mile 174mph, C/GMS class record holder, best 1/8 mile 6.96 at 100mph, best 1/4-mile 11.0 at 126mph, best 60' 1.43, best 1/2-mile 148mph at GA 1/2-mile. Home Track-Jake's Dragway, Moulton, AL. SCCA autocross club - TVR, Huntsville, AL. Lets race!
#29 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 18 January 2017 - 01:35 PM
Well....I'm cautiously optimistic that the body will be structurally sound! We will find out at the next race. HaHa...pea gravel and a safety net are an expensive modification.
#30 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 20 January 2017 - 12:36 PM
Engine and transmission is going in.
Attached File  30.JPG   118.18KB   0 downloads
Despite the modified cross-member, the Milodon Drag Race oil pan, #31145, would not clear.
The pan comes with a windage tray and double trap doors. The tapered sump measures 6" in front and 7 5/8" in rear.
Attached File  31.JPG   110.56KB   0 downloads
I removed the interference portion of the pan at the front to allow cross-member clearance.
Mack, then expertly welded  a piece of metal to the pan to seal the front end.
This modification provided the necessary clearance.
Attached File  32.JPG   74.13KB   0 downloads
#31 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 24 January 2017 - 01:14 PM
The block is a 4.125 bore Motown ll.
The rotating assembly is a Speed-O-Motive crankshaft kit consisting of:
    3.75" stroke 4340 crankshaft,
    H-beam 6.00" Eagle rods,
    and 8.8 compression JE  ...2618 forged pistons.
The Edelbrock Victor jr. cylinder heads contain:
    2.08" intake and 1.60" exhaust valves,
    1.55" double valve springs,
    and Competition Cams Magnum 1.5 roller rocker arms.
Attached File  33.JPG   113.23KB   0 downloads
The Chet Herbert solid roller cam has the following specifications:
    Intake duration is 242 @.050 and .580" lift,
    Exhaust duration is 248 @ .050 and .600" lift,
    Lobe separation angle is 114 degrees,
    and installed centerline is 110 degrees ( 4 advanced ),
    Valve lash is .018 intake and .020 exhaust.
The Edelbrock Victor jr. intake manifold has had the thermostat housing removed
and two AN-16 bungs were welded in place to route coolant to the radiator
via stainless steel braided hoses.
Attached File  34.JPG   99.9KB   0 downloads
#32 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 27 January 2017 - 01:32 PM
The carburetor is a Pro-Form 750 double pumper with Pro-Series, dual needle and seat, float bowls.
CSU handled all the "blow through" modifications and installed Boost Referenced Power Valves in both metering blocks.
The following MSD components provide ignition:
    Billet distributor, #85551,
    6-BTM ignition box, #6462,
    and Blaster coil-2, #8203
Attached File  35.JPG   125.15KB   0 downloads
The electric water pump is a Meziere, #WP 301 S, 55 gph unit and the one-wire alternator is rated at 140 amps.
Attached File  36.JPG   134.13KB   0 downloads
#33 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 29 January 2017 - 04:36 PM
The turbos, with Evolution Turbonetics waste-gates, have been attached to the headers and to the air-to-water inter-cooler.
Attached File  38.JPG   117.8KB   0 downloads
Attached File  39.JPG   115.56KB   0 downloads
The 3 1/2" inter-cooler outlet is now connected to the Extreme Velocity carburetor hat. A Greddy blow-off-valve vents pressurized air when the throttle slams shut.
Attached File  40.JPG   124.07KB   1 downloads
#34 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 02 February 2017 - 04:42 PM
Here is the installed CBR Performance radiator and Earl's Transmission cooler.
I made the front panels, on both sides of the radiator, through which the turbo intakes are protruding.
It appears Rustoleum's Automotive Enamel #252459 Cherry Red spray can paint, on the side panels, is a good match to the Z's body paint.
Attached File  45.JPG   122.61KB   0 downloads
These pics show the other side of the turbo air intake tubes.
And, how the Spal fan and intake manifold coolant hoses are attached to the radiator.
Attached File  47.JPG   121.5KB   0 downloads
Attached File  48.JPG   110.58KB   0 downloads
#35 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 09 February 2017 - 04:18 PM
These pics show the Quick Time Pro Hoosier street tires
and also the Dynomax, #24222 Race Bullet Mufflers.
Attached File  51.JPG   102.89KB   0 downloads
Attached File  52.JPG   83.17KB   0 downloads
Attached File  53.JPG   94.04KB   0 downloads
Attached File  54.JPG   115.48KB   0 downloads
#36 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 17 February 2017 - 02:32 PM
I designed and Mack fabricated this electric water-pump and 6 gallon ice-water combination tank for the air to water inter-cooler.
 Attached File  55.JPG   60.48KB   0 downloads
A kitchen sink stainless steel screen strainer blocks the larger ice particles from entering the 25 gpm Meziere pump.
 Attached File  56.JPG   57.85KB   0 downloads
The tank fits securely and snugly between the Z's wheel tubs.
Attached File  57.JPG   99.18KB   0 downloads
#37 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 4 weeks ago
The interior shows stock 240 Z seats and G-Force racing harness.
Attached File  58.JPG   128.33KB   0 downloads
The B&M shifter housing was recessed into the transmission tunnel.
Attached File  59.JPG   120.16KB   0 downloads
The gauges and electrical switches were installed into a custom dash panel.
Attached File  60.JPG   62.25KB   0 downloads
#38 Ryan Merrill
Ryan Merrill
    Always Here
  • Members
  • PipPipPipPip
  • 352 posts
  • LocationNewcastle Ontario
Posted 4 weeks ago
Woohoo! Glad to see it back and looking better than ever
#39 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 4 weeks ago
Thank You... also hope it runs as well or better!
#40 Turbo Meister
Turbo Meister
    Compensator
  • Donating Members
  • PipPipPipPipPip
  • 539 posts
Posted 4 weeks ago
The Z has been repaired and is ready for action.
Since changes have been made, some tuning will be required.
Start-Up
https://youtu.be/EoDj0McCyQs
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
