Project Chuck '71 Scarab
Project: Chuck Norris
1971 240Z Scarab Kit
13934867_1234761569876549_1090616379194813907014_1234761593209880_8374454029962414022155_1234761599876546_85520148600739
14051800_1234761659876540_16441345063459
14053992_1234761763209863_33525087284072
14067657_1234761779876528_56787398176614
13938377_1234761736543199_4578547990501713962487_1234761719876534_3997147579232514067688_1234761669876539_78630195151197
13962671_1234761623209877_3173742406023613912716_1234761636543209_33587742138127
What a MESS!
The car consists of some Weld Racing Drag Light wheels, Konig Rewinds, R200 rear end with cardan joint axles, a TH350 Automatic transmission with a shift kit and a stall converter, a 010 4 bolt main 350 sbc with some of the Scarab parts like the Hooker headers, a roll cage with pigeon shit welds, 1 plastic bucket seat, gutted gash with minimal gauges, no sway bars, mismatched springs and shocks, a driveshaft loop, stock brakes, a Northern Radiator with an electric fan, and some old safety harness belts.
First get it to run!
The Accel Distributor hit the trash can first off. I ordered up a cheap Chinese HEI knockoff!
12376219_1096986633654044_75780715283716
Much cleaning!
12400828_1096985973654110_75580925533979
The Alt Belt was having a hard time staying on. But at this point I knew the engine was still good and in fairly good shape. Turned out I had a raelly healthy 5.7 with a Holley 480CFM 4 barrel with vacuum secondaries! It was a fresh carb too!
The original exhaust though was a simple Collector DUMP!
So off I went to get exhaust done.
12540905_1096985986987442_5875939552225912509120_1096985983654109_2619616985472012495178_1096985980320776_5284424225462112509903_1096985976987443_76837417022746
It wasnt ear deafening now!
Change the oil time... Shit that filters a bitch to get to... remove #1 header pipe which slip fits as 2 pieces and the original header has a slip fit  collector as well!.
12439044_1096985280320846_9130245826468712523025_1096985273654180_91642852732036
I purchased a cheap oil filter re-locator kit. What a mistake. That thing was a leaky SOB! I ended up going to CAT and having O-ring faced Parker lines made up, and chasing all the cast aluminum housings before it would seal... It ended up being close to $300 in total for oil line crap!
And then it was time to make it streetable again, as this was setup as a cheap 1/4 mile car, probably because the last time it was registered it had to be smogged and well... there was no BAR label so it went off highway use only.
12438963_1096985270320847_42254932230534
Heres the old converter!
Here comes a 4L60e!
I purchased the Holley carb TPS kit, a TBI ECU wired up as a TCU only, and all the associated sensors including a DRAC module.
12548854_1096984410320933_21982588095741
I also painted components under the car as well as the cleaned and painted the underside of the car!
12508908_1096984406987600_27365623370882
Enjoy the wood props
12548852_1096984403654267_3008898531294012438951_1096984396987601_61856756945635
No stinkin telescoping transmission jack!... and engine held up with 2x6 boards. I man handled the TH350 out... um... well that 4L60e was a bit to much for me to man handle in!
12439017_1096983646987676_28883577030069
12541056_1096983640321010_27975751317959
So I opted to use ratchet straps!
While it was down, I also pulled that 3/8" aluminum hardline dragging on the bottom of the car and installed a GM hardline with GM filter from a 94 Burban!
944088_1096983643654343_873694266353523812549114_1096983636987677_90397879507283
968985_1096982746987766_1330500783187463
1935500_1096982740321100_835618520771497
Oh Yeah, I did!
12507259_1096982750321099_54281763725217
Once in I had to make a new mount!
12400897_1096982743654433_12966339150590
Turns out old Bronco Spare tire holder parts make good scrap for mounts
12510299_1096982000321174_59477446887520
12573868_1096982006987840_83412380473142
12573076_1096982010321173_19208546662884
12417845_1096982013654506_59080010067022
Note that I added a Full Boar Single Chamber muffler in the center as well as a flex coupler!
I also installed GM horns, and a brand new XENON air dam.
The Exhaust required modifications after this though
12573090_1096979526988088_14670429125370
With the 4L60E I also changed out the rear drums for disc brakes
12540800_1096982736987767_37858637783323
12508679_1096980220321352_18383115302652
And some Toyota 4 piston calipers
11140038_1096980213654686_59530786846118
Wiring up a 4L60e
12400624_1096981156987925_65614128823037
Also the engine bay was sprayed with flat black!
12509613_1096981160321258_80800610835096
1917603_1096981153654592_774259066362966
12507671_1096980216988019_91007107124392
Very busy in there now.
And then it was time to install Autometer Sports Comp Gauges.
12439262_1096980223654685_31331399364350
Not all of these were electric, and it took me some time to switch them all over to electric.
The Hood had to go!
I found a nice cowl hood! Then I was off to the HybridZ BBQ put on by Gollum at San Pablo Dam Recreation Area and found another Scarab!
12400788_1096979056988135_84626405445387
You know, one with a number plate and the "special package parts"
12507448_1096979050321469_24193593471390
No sooner than I have the whole 4L60e in and running well than a T56 plops in my lap for $125!
12573733_1096978333654874_73936471760978
CLEAN IT!
12552782_1096978346988206_22072057400947
I mean do I really have a choice? I pose it that I do not!
1929818_1096978343654873_760983971178953
Parts gathering phase initiated!
12376381_1096978336988207_40335457828144
Tilton Clutch Master, Tilton Starter, Centerforce Flywheel, MacLoed Clutch disc, GM pressure plate, 3AN SS braided hydraulic line with all the related fittings, and a stock LT1 Slave.
12439335_1096977546988286_14117679795895
Out with the old!
12552638_1096977543654953_63101624102067
Using wood again... super janky I know
12509287_1096977550321619_62803429745430
12510391_1096977540321620_71505453430788
Man that is close!
12509892_1096977553654952_14715334309043
More Bronco Spare tire carrier scrap put to use!
Fords are good for something... hehehehe
12510434_1096976870321687_90165160594661
12510378_1096976883655019_14435778351042
12522923_1096976236988417_68677896514181
12540621_1096976230321751_78297793190699
12439235_1096975673655140_42342410571996
It was time for seats!
12509544_1096976226988418_94317349149318
BMW Recaro with Thigh Bolsters. I love these seats!
12573176_1096975676988473_31920725088508
5406_1096975666988474_155159261335510883
946136_1096974553655252_1734538766955546
12592305_1096975680321806_44872485056056
Back to the Exhaust Shop
12522998_1096975670321807_43625585977559
12573197_1096976240321750_50296207173127
12553047_1096976233655084_59627650085594
12417947_1096974550321919_1818481054908612573119_1096974110321963_26243041292679
Ready for Marina AutoX! One of the last few UFO AutoX meetups.
12510517_1096974103655297_64519205452291
It was my first ever AutoX driving. It was a BLAST! I spun out on the 3rd run after greasing the tires up... man... the car was called "The White Pig" by TonyD!
Chuck Norris AutoX Run 1
Chuck Norris AutoX Run 2
Chuck Norris AutoX Run 3
The Next phase was obvious... Deal with the Body.
The paint was rapidly peeling and rust bubbles forming!
So the engine came out!
12508941_1096973423655365_71187470366077
12507195_1096973420322032_193340544297038149_1096973416988699_648091880355684634
12509113_1096972773655430_61327984101891
I purchased a rear sill plate from Motorsports Auto!
12512810_1096972786988762_28985122887515
12439336_1096972053655502_37029942822028
I knew I should have removed those front fenders.... what a mistake! Always clean these out!
12439266_1096972783655429_68727398510371
12565339_1096972776988763_15166384204063
12400513_1096972043655503_1016271634198412508991_1096972780322096_81502894328692
12572981_1096972046988836_18430915211654
12548943_1096972040322170_76013765098209
1935307_1096971353655572_31440149448907411140277_1096971350322239_1821448366689612509241_1096971343655573_91218561552044
12592558_1096969996989041_82935526039253
And then stuff started going off to the body shop!
12510293_1096970623655645_74120895817222
12512316_1096971356988905_37774500207933
12509765_1096971346988906_81128464180213
12417714_1096970620322312_7838780383954412540748_1096970616988979_6643622312009712592326_1096970613655646_330796681994119147_1096970610322313_73300864841345262112401022_1096970003655707_78260749560889
12509061_1096969990322375_59260673699299
12523911_1096969360322438_4229590122355912548837_1096969356989105_88444796698092
over a year later... I picked it back up!
12418089_1096969363655771_49026277817948
12573955_1096969353655772_1520097916325312552688_1096969350322439_2816572753612212565338_1096968136989227_78589992138928
And I slowly put it back together!
12565533_1096968133655894_70748865202210
12417702_1096968130322561_4833238090421612552593_1096968126989228_3714562813201212439085_1096968123655895_76029690874846
12510295_1096967430322631_75415431381632
I sold the 96 Burb and got a 01 Yukon XL... mistakes...
12508709_1096966116989429_27843027466900
About this time I was moving up to Sacramento... and I finally realized I had all new suspension and could start going through the engine!
12508922_1096967440322630_16333386298987
12494687_1096967436989297_57784653492941
OMG, the OVERSPRAY!
12508939_1096967433655964_62399081209311
12509317_1096967426989298_91515023912529
12509522_1096966866989354_3379978279999212495190_1096966863656021_4606645130081312540760_1096966860322688_70685519246660
At its new home at Fitted Garage in Sacramento!
12508943_1096966856989355_55167793989914
12509903_1096966123656095_36017093187067
12573840_1096966120322762_63908002111741
12523158_1096965386989502_19717490823652
Cleaning the Overspray
12512801_1096965383656169_42567952542339
12494942_1096965380322836_9037067788281412510291_1096965376989503_3222932886964812540968_1096964636989577_1124167551199612552996_1096964633656244_7658280612681112509056_1096964626989578_7044294314417212510384_1096964623656245_75574301328873
One of the significant changes... Yellow Octopus Pioneered this for me.
96 Mustang GT Hydroboost
12573714_1096964120322962_4051992978860112494830_1096964116989629_90722809390419
First Wash
12573758_1096964110322963_31679334921525
12573068_1096963443656363_44529957707242
Techno Toy Tuning parts incoming!
12495226_1096964106989630_73048271724868
12549090_1096963450323029_32210913047482
Look at all this interior
940941_1096962203656487_907824746288691012494877_1096961566989884_80732649694308
Camber plates in!
5433_1096961563656551_817182196441126850
Rear Sway bar! and Ron Tyler Diff mount!
12553084_1096958233656884_83842957270461
12009572_1096958230323551_27506826340053
T3 First Aluminum Drop Bars!
944034_1096958223656885_1722259332381334
12552983_1096961556989885_42447162992887
12376398_1096951876990853_24539880028880
12400828_1096962216989819_29577256288125
12565391_1096963456989695_70278972705166
12541156_1096957540323620_83096708475756
Mess of wires
12507552_1096957530323621_73693718221273
DIY Autotune MicroSquirt going it!
12493513_1096957526990288_73372645353614
12524005_1096956750323699_79763579818431
Bosche 300LPH@5Bar Pump.
12552691_1096956746990366_6452993048870312510363_1096956743657033_8375693768942312495195_1096956196990421_6040290505149912524059_1096955243657183_711632047807291916693_1096955240323850_115988836112012
12510488_1096955233657184_7316054461684612573212_1096955230323851_64597579538825
Engine Building
12548990_1096966853656022_1806451188419612509840_1096966130322761_7082944108130112510462_1096966126989428_34953399828472
12417954_1096961016989939_715570606355881914356_1096959440323430_14219913513829512507287_1096959436990097_4023729400352212573778_1096959433656764_1032303117912112509193_1096958236990217_73764110305263
12512719_1096955236990517_47189843664714
12321225_1096954473657260_78860862389829
12540671_1096954483657259_65149910447844
1937210_1096954470323927_725205552175222
12524212_1096953890323985_44756421589613
12553040_1096952446990796_9170058659530012510473_1096953886990652_3134284498135212509522_1096954480323926_3279635174654912507576_1096954476990593_31206551429017
12507521_1096953300324044_5850974169221512549003_1096953296990711_4545825115813112522975_1096953290324045_9080088445783212523045_1096953286990712_6807823424009512552668_1096952450324129_82901478847594
12573927_1096952436990797_73941542797391
12509444_1096952440324130_56945421161767
12509118_1096952443657463_25093902563689
12509577_1096951103657597_54579982159650
I replaced the Radiator with a nice newer Northern Unit
12509447_1096951110324263_38072030526982
12552779_1096951100324264_35849561545960
15578521_1356607074358664_3286968757782615420850_1356606987692006_5672650148164815542277_1356606944358677_37015953723979
You can see the huge by large oil cooler Im installing below. Pirtex is going to come over and get all my hyrdraulic lines taken care of!
12417585_1096948743657833_4699214968323411140091_1096948733657834_27689443118280
And this needs 2nd gear synch replaced!
12376338_1096953893657318_33976132315500
12573899_1096950676990973_48256882464786
Thats all for now.
I just got my Flex Fuel composition sensor in, and a new power brake pump brackets(PS pump).
I also made a large order from Black Dragon this past Nov and got about half of what I ordered. So there will be slow steady progress here soon.
Transmission is off with a friend getting completely gone through!
