1975 280z New ZX Alternator Won't Charge
  • Please log in to reply
40 replies to this topic
#21 NewZed
NewZed
    Clandestine Moderator
  • Donating Members
  • PipPipPipPipPipPipPipPip
  • 5361 posts
  • LocationWashington County, Oregon
Posted 10 February 2017 - 02:08 PM
Are you sure that there is continuity to the battery positive post from the alternator's charging wire, the BAT terminal?  Follow the path.  You can test if it's charging by measuring between the BAT terminal and ground, directly from the back of the alternator.
You can test continuity by measuring battery voltage at the BAT terminal directly with the engine not running and key off.  The BAT terminal is always connected to the battery positive post, normally.  Did you check those fusible links yet?
You might just stop, now that you've been working on this problem for a while, and think about how the system works, and what should be connected to what.  Could be that you've been assuming that the charge wire is connected to the battery, but it's not.
#22 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
  • LocationUnited States, Louisiana, Cottonport
Posted 10 February 2017 - 03:13 PM
Okay so I just went out to check with the meter with my dad and we found out that the earth on the alternator is getting 12v from the positive on the battery.
The BAT terminal is getting 0v from positive, and 12v from negative.
Somehow this got switched up and my dad says he can't believe it hasn't fried anything.
How the hell did this happen? I checked my fusible links and they're both fine, along with all the fuses in the cabin.
Am I screwed?
Edited by JTCN, 10 February 2017 - 04:06 PM.
#23 softopz
softopz
    Member
  • Donating Members
  • PipPipPipPip
  • 427 posts
  • LocationOntario Canada
Posted 10 February 2017 - 05:11 PM
Well turn it on and see! hold one before you do hopefully you didnt do any serious damage.
So you had the positive that suppose to go to (battery ) I think through starter on the earth (ground) of alternator? I am surprised you were running. THE POS terminal on the alternator should have plastic/rubber between the housing and its labeled BAT.
Secondly are you sure your multi-meter is on the correct probes I know it sound silly but double check your colours . Rather you switch them now than really fry sh*t up. The only possible way I I can think of that you didn't burn fusible links/charging wire is if your BAT on alternator isnt hooked up to POS on starter OR your BAT POS isnt hooked up HOT ( POS ) on starter. Make sense?
Thirdly if you checked multi-meter and confirmed it isnt the probes simply by testing them on battery or alternator. Are you getting -12v reading on the multimeter on BAT on alternator with it connected to the RED probe and black connected to earth?!?!?!
Check voltage at battery terminals. Also keep your + probe on + battery and switch - to engine / alternator just to see if its a ground issue.
Check voltage at starter + (hot) terminal on starter and - use the starter body, and switch the ground probe to the - on battery see if there is any difference. YOU SHOULD READ SAME AS YOUR BATTERY VOLTAGE if not then you got a + or - from bat to starter is not connected properly , BUT I highly doubt that cause your car starts!
With the car off Check voltage at alternator using the BAT for + and body of alternator as - , then keep + lead of multimeter on BAT and switch - to neg battery YOU SHOULD READ SAME AS YOUR BATTERY VOLTAGE if not you need to connect that thick ass wire from BAT to + of starter.
Start engine. do the same last test you should be at least charging 13.5-14.2v at your alternator. If your not rev it up a lil doesnt need much.
You either have a bad alternator, loose belt, or wiring .
If its your wiring pull out the T connector and you should start overcharging non regulating and will spike up to 14.7-17v .
If you are charging but not getting it to the battery then do same first 2 checks in reverse order and work back. Good luck
Edited by softopz, 10 February 2017 - 05:41 PM.
Official AMP EFI megasquirt retailer.ms3 pro lifetime warranty!
Plug and Play Megasquirt 1/2/3 harness pre configured ms systems.
http://forums.hybrid...ss-sensors-etc/
#24 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 10 February 2017 - 05:37 PM
Thirdly if you checked multi-meter and confirmed it isnt the probes simply by testing them on battery.
Check voltage at starter pos using body of starter and the + (hot) terminal on starter, and switch the ground probe to the - on battery see if there is any difference. (also checking your grounds while your at it)
With the car off Check voltage at alternator using the BAT and body of alternator and keeping the pos lead of multimeter on BAT and switching neg to neg batter you
Start engine. do the same last test you should be at least charging 13.5-14.2v if your not rev it up a lil doesnt need much.
If its wiring pull out the T connector and you should start overcharging non regulating and will spike up to 14-17v .
First, thank you so much for the long write-up.
I didn't mess up any connections to the alternator itself, the charging wire goes to BAT, earth to earth, and the "T" connector to its connector.
Yes, the BAT terminal has the plastic around it.
I definitely didn't get the probes mixed up.
Heres a pic of the back of my alternator just to confirm: http://i.imgur.com/fRSOvqZ.jpg
The only wiring I did on this car was splicing the voltage regulator harness... Maybe it's just me but I don't see how that could screw this up so bad
How can I check if my charging wire is connected to positive on the starter? Do I have to rip open the harness and chase it back?
I don't understand how this is happening because to my knowledge everything is connected and wired correctly.
Here's an album of some other pics I took of my wiring and the alternator. http://imgur.com/a/gM5pj
One last thing, the condenser's wire on my alternator is connected to BAT terminal, is that correct? It's what it was connected to when I got it.
Edit: I've also been getting small sparks when connecting the negative cable to battery negative terminal.
Edited by JTCN, 10 February 2017 - 05:44 PM.
#25 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 10 February 2017 - 06:12 PM
Just did some of the tests you suggested.
Battery voltage is 12.58
Battery POS to Alternator earth is 12.58
Starter POS to starter case is 12.58
Starter POS to BATTERY NEG is 12.58
Alternator BAT to alternator case is 12.58
Alternator BAT to BATTERY NEG is 12.58
I did all these tests with the car off.
I havent started the car since I found out about the car getting to ground, but it was running just fine. Just wasnt charging.
#26 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 10 February 2017 - 06:17 PM
I'm going to undo my splices right now and see if i stop getting power to ground.
#27 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 10 February 2017 - 06:46 PM
If anyone else has ideas or tests for me to do please let me know and post them in the thread.
#28 softopz
softopz
    Member
  • Donating Members
  • PipPipPipPip
  • 427 posts
Posted 10 February 2017 - 07:46 PM
Dont undo your wires. Now start the car and see what the alternator is charging at pos and earth. then unplug T connector see if it changes. I took the the time to write a step by step process to fully diagnose your charging system you only did half of it and your asking for suggestions " ideas or tests"
 Search how to use resistance on multimeter watch a video on youtube to see some functions of a multi meter. While your at it search how to diagnose alternator, and charging system I give up spoon feeding  for today.
#29 NewZed
NewZed
  • Donating Members
  • 5361 posts
Posted 10 February 2017 - 08:04 PM
It seems to me, based on the way you're writing, that you might not really understand how to measure voltage.  No offense.  But your word usage is not the way a person experienced in these things would write.
Voltage is not gotten.  It just exists across points in a potential circuit.  " earth on the alternator is getting 12v from the positive on the battery".
It looks like you put one probe on E and the other on the battery positive terminal and saw 12.  That would be a correct reading for proper wiring.
#30 NewZed
NewZed
  • Donating Members
  • 5361 posts
Posted 10 February 2017 - 08:08 PM
And all of your measurements in Post #25 look correct.  Your comment in #26 doesn't fit what you saw.  Everything looks fine.  BUT.  You didn't show the measurements at the T plug.
#31 NewZed
NewZed
  • Donating Members
  • 5361 posts
Posted 10 February 2017 - 08:18 PM
Since you did say earlier that you saw battery voltage at the bottom leg of the T plug and everything else looks good here's something that happened to me a few years ago - the T plug connector was loose and dirty.  It wasn't making electrical contact.  I found that I could wiggle it to a new spot and the alternator would start charging again.  It was an odd thing.  A quick squeeze with some needle-nose pliers fixed it.
Make sure the T plug is making good contact with the alternator terminals.
#32 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 11 February 2017 - 12:05 PM
Alright sorry I stayed at a friend's house last night and didn't get to try anything.
Just tested with the car running, alternator is only charging 11.8v. (I put + on BAT and - on negative battery) Pulled the T connector and nothing changed.
I wanted to compile a bunch of tests and suggestions to try out while I wasn't home, only had time to do half of your suggestions, my bad.
I'll do that. Thanks anyway
You're absolutely right I'm not experienced in electrics lmao.
My dad talked to an electrician friend and he explained it. Pretty embarrassing lol
Just tested with the key on, Top of the T was getting 12.4 and the bottom was getting 11.8
Key off the top of the T was getting 12.4, bottom was getting 0
Yeah funny thing, I was trying to test the bottom of the T plug and I had to seriously get the probe in there to get a reading.
I've already sprayed contact cleaner on the T plug yesterday but maybe it wasn't enough.
And don't worry I think I'm testing voltage the right way now lol...
So we're still where we left off, alternator isn't charging (or at least not charging enough).
I guess I'm going to charge my battery and look into what else to try.
Edit: I also soldered all my connections this time.
Edited by JTCN, 11 February 2017 - 12:09 PM.
#33 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 11 February 2017 - 12:14 PM
Something else I wanted to bring up.
What is the possibility of this just being a bad alternator? I took it to autozone to get tested and it passed but I'm not sure if I can really trust that right now.
When I switched from my old alternator+voltage regulator the only thing I did was splice the harness together the right way and hook up this new alternator.
Should I just send this thing back and try another? I'm conflicted because it passed the autozone tests.
#34 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 12 February 2017 - 02:12 PM
Boxed up the alternator and getting ready to exchange it for another.
Edited by JTCN, 13 February 2017 - 06:30 PM.
#35 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 13 February 2017 - 06:34 PM
I haven't updated this thread but here is whats happened so far.
Im gonna send this alternator back to the seller and while I was waiting I went ahead and ordered one from autozone.
I got the new alternator (still a remanufactured one) and installed it.
It's doing the same shit as the other alternator. 11.8v output from it.
But I discovered something after doing more tests with the voltmeter.
KEY OFF:
12.4v at car battery
12.4v at top of "T" connector. (also known as "Sense" connection)
0v at bottom of "T" connector. (also known as "Lamp" connection)
12.4v at alternator BAT terminal.
KEY ON:
12.2v at battery
12.2v at top of "T" connector ("S" connection)
11.7v at bottom of "T" connector ("L" connection)
12.2 at alternator BAT terminal.
So in the swap guide I mentioned it says this:
"1. An "L" connection which goes to a "switched" 12V supply. By this I mean a 12V source that is active only when the ignition switch is in the ON position. I use the mnemonic "L" for "lamp", the alternator warning lamp (if used) is in series with this connection. This terminal also supplies the "excitation" current to the alternator field winding at engine turn on, allowing the alternator to begin producing voltage as the engine is ramping up to idle speed. Once the alternator rotor is turning fast enough, it generates it's own supply for the field winding and the current in the "L" connection stops flowing. The warning lamp (if used) goes out."
So when the key is on, the "L" connection gets 12 volts, which gets the alternator to charge.
My connection is only getting 11.7v. Could that be why it's not charging? I have the car battery on a charger right now in case it's not charged enough to supply the right voltage to this connection.
But everything else is getting 12.2v when the key is on... What's the first place I should look to find out why it isn't getting 12v?
#36 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 13 February 2017 - 10:13 PM
I charged my battery up fully and I started getting 12v at the "L" connection.
But when I ran the car it still didn't charge the battery.
#37 NewZed
NewZed
  • Donating Members
  • 5361 posts
Posted 14 February 2017 - 08:36 AM
Everything in 35 looks right. You didn't show that you have a good grounding of the case though. And you didn't show the values with the engine running. But the measurements shown look correct.Not sure what's happening.
#38 Miles
Miles
    Miles ahead!
  • Donating Members
  • 1888 posts
  • LocationSacramento, CA
Posted 14 February 2017 - 09:20 AM
I just searched HybridZ for the ZX alternator which returned 356 results. On the the first two pages were threads with the answers to your problem. Some of the threads include references to other Z websites detailing the ZX alternator swap. Included in the threads are pictures, schematics and tables showing the correct wiring.
Persistent searching pays off.  Listen to what this guy does:
Edited by Miles, 14 February 2017 - 09:24 AM.
“Life is like arriving late for a movie, having to figure out what was going on without bothering everybody with a lot of questions, and then being unexpectedly called away before you find out how it ends.”    -Joseph Campbell
#39 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 14 February 2017 - 11:29 AM
Someone in another forum showed me a thread on testing IR alternators and I think I'll try that next.
Here's the link: http://community.rat...ted-alternator/
But first I'll need a test light.
In the meantime I'll go check the ground on the case and do voltage tests with the car running
Edit: By the way, I read from a guy that has the same year and build date as me that you can't trust the wire diagrams.
He said datsun switched up their wiring colors and the placement of which wires constantly and that I should check and verify what each wire does before splicing.
I was planning on doing that but I figured if I'm getting the correct voltage with key off and key on, wouldn't that mean my wiring is fine?
Edited by JTCN, 14 February 2017 - 11:32 AM.
#40 JTCN
JTCN
    Moving Up
  • Members
  • PipPip
  • 40 posts
Posted 14 February 2017 - 12:07 PM
GOOD NEWS EVERYONE!
I started the car just a minute ago and checked voltage at some areas and after I finished I decided to leave it for a few minutes for it to warm up.
After I got back it was fully warmed up and I tried revving it to 4K rpm and I saw the ammeter jump up!!!
I jumped out the car and checked the battery its getting 13.5v consistently at idle! Even with a bunch of accessories on!
I have no idea why it finally started charging. I guess it needed a jump start.
I tried revving it up before but this time it decided to work.
Thank y'all for helpin!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
