boosted300's RB 240Z
rb25det 240z
  • Please log in to reply
70 replies to this topic
#21 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
  • LocationSouth Florida
Posted A week ago
As always, modifications to the modification were necessary...
The mounting brackets were not quite right, they were a little too big in spots, so there I put in some serious elbow grease filing them down to the right size...
Attached File  IMG_6799_zps34f34ad0.jpg   78.33KB   0 downloads
Attached File  IMG_6800_zps9b0d968c.jpg   76.5KB   0 downloads
I also had to oval out some of the mounting holes to get the whole thing to mount up just right...
Attached File  IMG_6801_zps4a74bb3d.jpg   69.01KB   0 downloads
#22 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Took some work, but got the alignment just right...
Attached File  IMG_6488_zpse923bf8a.jpg   127.52KB   0 downloads
Attached File  IMG_6490_zps8c79b497.jpg   77.76KB   0 downloads
#23 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
I then ordered an array of 1 3/8” aluminum tubes in straight and 45 degrees, along with an array of HPS silicone hoses in straight, 45, and 90 degrees.
I experimented with these items in different combinations to fabricate custom coolant piping.
Once I cut the pieces to the desired length I had to use a bead roller to make a lip for the hose clamps to grab
Attached File  IMG_6736_zps0d0d0425.jpg   38.75KB   0 downloads
Here I marked the spot where the bung for the temp sensor for fan controller
Attached File  IMG_6735_zpsa24abbcb.jpg   40.71KB   0 downloads
Attached File  IMG_6737_zpsbaf2cc72.jpg   81.19KB   0 downloads
Attached File  IMG_6738_zps36d30060.jpg   88.7KB   0 downloads
#24 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
When I pulled the McKinney out, I discovered the oil cooler then car came with...
Attached File  IMG_6374.JPG   116.35KB   0 downloads
Naturally while I was in there already and the radiator was out of the car, might as well upgrade the oil cooler of course.
I went with a larger Mishimoto unit...
Attached File  IMG_6397.JPG   103.19KB   0 downloads
Attached File  IMG_6398.JPG   100.32KB   0 downloads
#25 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Also had to weld a bung on the radiator itself for the in dash Autometer temp gauge
Attached File  IMG_7028.JPG   107.47KB   0 downloads
#26 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
The end result was very satisfying, both functionally as well as aesthetically.
Attached File  DSC04117.JPG   135.53KB   0 downloads
Attached File  DSC04123.JPG   139.48KB   0 downloads
Attached File  DSC04125.JPG   96.63KB   0 downloads
Attached File  DSC04132.JPG   89.12KB   0 downloads
Attached File  DSC04143.JPG   62.19KB   0 downloads
Attached File  DSC04144.JPG   71.62KB   0 downloads
The setup looks fantastic, the fans are very quiet, and the radiator cools so well that, depending on the ambient temperature, the water temp on the highway hovers around 150-160 degrees…meaning the fans never even have to kick on as they are set to come on at 180 and shut off at 170.
#27 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Also added a Sparco steering wheel...
Attached File  DSC04147.JPG   118.18KB   0 downloads
Attached File  DSC04150.JPG   101.53KB   0 downloads
#28 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
The actual project of installing the AC system was a hefty task to say the least, including removal of the dash, so I decided to put that off for a while so I could actually enjoy the car.
With everything in place and running well, I was able to enjoy the car as much as I could for a bit, but after a while I craved really putting all of the power to use.
That spawned my next project…getting the power to the ground.
I did a separate write up on that here:
http://forums.hybrid...d/#entry1144553
#29 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
That project worked out perfectly and I’m really happy with the results.
But of course, as luck would have it, I was only able to enjoy it for one measly day.
On my very first drive with the new setup, after about an hour or two of driving around town, I began to smell something acrid. Next thing you know, I see smoke starting to emanate from my glovebox/dash area.
I pulled over immediately, panicked that the car was about to catch fire. But as soon as I turned the car off, the smoke stopped. I inspected around the source of the smoke and discovered that the wiring harness that runs behind the dash had almost melted through.
I traced the melted wire to the factory fuel and amp gauge which had been poorly placed in the glove compartment as the factory location was occupied by an Autometer oil temp gauge. The gauge had shifted around in the glove box and it appeared it was grounding out on some metal towards the back. I carefully moved the gauge into a position that appeared not to be touching anything and attempted to start the car…
Attached File  20150503_194407.jpg   78.5KB   0 downloads
Attached File  20150503_194428.jpg   197KB   0 downloads
Attached File  20150503_194436.jpg   61.72KB   0 downloads
It fired right up and luckily drove fine. It appeared no critical components were affected by the melted wires. I gingerly drove it home.
Not exactly the best luck with the car to that point! But in retrospect...what I came to realize is that "bad luck" was really a direct byproduct of poor work...this was just another step in the arduous process of working out the kinks and fixing all the mistakes...
#30 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Further inspection revealed that the melted harness extended into the engine bay…I decided not to drive it anymore and had it trailered once again to Doug’s shop.
We came to the conclusion that the dash would have to be removed and we would have to re-do the harness.
Since the dash had to come out anyway…I figured this might as well be the time to install the AC system.
Removal of the dash revealed a rat’s nest of wiring, nothing wrapped, nothing secured, nothing organized, electrical tape and butt connectors everywhere. It was a very sloppy job to say the least…it was clear this would be another challenging project.
Attached File  20150530_140655.jpg   134.54KB   0 downloads
Attached File  20150530_140717.jpg   105.85KB   0 downloads
Attached File  20150530_142638.jpg   117.4KB   0 downloads
Attached File  20150530_142651.jpg   83.2KB   0 downloads
Attached File  20150530_142657.jpg   82.9KB   0 downloads
#31 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Attached File  20150613_143132.jpg   100.32KB   0 downloads
Attached File  20150613_143142.jpg   98.91KB   0 downloads
#32 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Starting from scratch...
Attached File  20150606_155003.jpg   128.61KB   0 downloads
Deeeeep siiiigh....
on to the AC project...
#33 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
A little research on HybridZ on AC systems revealed a blower fan upgrade utilizing a blower from a KIA.
I followed the write up step by step…thanks to all who contributed to that and made my life easier.
Attached File  20150606_123418.jpg   80.54KB   0 downloads
I scribed the housing, and ground it out to size.
Attached File  20150606_143422.jpg   130.11KB   0 downloads
I had to slot out the bolt holes on the fan to get it to line up right.
I then improvised a little and used a foam gasket from a speaker to seal the blower to the diverter assembly, it fit perfectly.
Attached File  20150607_170312.jpg   109.3KB   0 downloads
Attached File  20150607_170316.jpg   100.38KB   0 downloads
Attached File  20150607_171902.jpg   99.86KB   0 downloads
#34 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
I also decided to improve the firewall a little by adding some Dynamat, followed by a replica firewall from the Z store, and then dressed the whole thing up with some fancy fasteners just because.
Before
Attached File  20150620_143004.jpg   145.23KB   0 downloads
After
Attached File  20150703_151305.jpg   148.29KB   0 downloads
#35 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
The AC unit that I received with the car happened to be the unit that is sold by the Nissan dealer as a retrofit kit. It's a draw-through system that is designed to bolt up to the air inlet of the factory blower.
As such it mounts under the glove compartment. While not the easiest system to install, you dance with the girl you brung...so I went full steam ahead with it.
Here is the draw-through evaporator unit test fitted...
Attached File  20150711_155014.jpg   133.68KB   0 downloads
#36 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
The AC system is by no means "bolt on"...
So brackets had to be fabricated to hold everything in place...
Attached File  20150725_143539.jpg   117.47KB   0 downloads
Attached File  20150725_143556.jpg   117.53KB   0 downloads
Attached File  20150725_143452.jpg   91.06KB   0 downloads
#37 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Attached File  20150725_143615.jpg   134.42KB   0 downloads
Even though no one will ever see them, I used some fancy fittings for the heck of it...
Attached File  20150725_143625.jpg   105.3KB   0 downloads
Attached File  20150725_143630.jpg   88.35KB   0 downloads
Attached File  20150725_151712.jpg   115.47KB   0 downloads
#38 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Here's a better look at the draw through evaporator...
Attached File  20150725_154853.jpg   122.55KB   0 downloads
#39 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
So while in the engine bay moving everything around and cleaning everything up…
Attached File  20150620_141011.jpg   173.46KB   0 downloads
why not get rid of cumbersome, unsightly factory oil cooler adapter and replace with a shiny, new Greddy unit with thermostat?
Attached File  20150718_123433.jpg   54.83KB   0 downloads
Attached File  20150718_124411.jpg   87.09KB   0 downloads
Attached File  20150718_124422.jpg   165.69KB   0 downloads
#40 boosted300
boosted300
    Always Here
  • Donating Members
  • PipPipPipPip
  • 130 posts
Posted A week ago
Pausing here for the night...much more to come.
Also tagged with one or more of these keywords: rb25det 240z
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
