Sign in to follow this
FS: 2003 Nissan 350Z Enthusiast Jackson, MS
Hello everyone I know this forum is more for classic Zs, but I thought there might be some interest here. I need to try to reduce some of my car count. I have a 350Z that I'm putting up for sale. I bought this car as a fixer upper with the intent of making it a track car but have not gone super far in the build. The car was not driven from October 2014 to October 2016 due to an engine misfire issue. I have owned the car since August 2015. The misfire is now fixed. It turned out to be a bad ECU.
Vehicle Details
2003 Nissan 350Z Enthusiast 6 M/T
Price: $4200 obo
Mileage: 102,550
Vehicle Location: Jackson, MS
Vehicle Title: Yes (MS Title in my name)
Seller Name: Sergio B.
Seller Contact Email: Undiaf1 at yahoo dot com
Vehicle Condition:
-The vehicle has two accidents in Autocheck/Carfax history (One listed as Front RH, and a second accident listed as rear impact)
-Panel gaps are visible in front and rear most likely due to previous accidents
-The car drives well enough to be a daily driver. I have put ~4k miles on it since October 2016.
-The stock suspension still feels tight
-The clutch still grabs well to allow for good acceleration
-Old Toyo Proxes TPT tires in stock sizes with plenty of tread but build date in 2009
Known Issues that will have to be addressed:
-Cracked Windshield
-Oil Pans could use a re-seal.
-Liquid filled differential bushing has ruptured.
-Front suspension ball joint boots are showing signs of age cracking. They will open up at some point.
-Rear suspension creaking. Most likely old sway bar links
-Synchro grind has been detected on quicker upshifts (4th to 5th, 5th to 6th)
-Synchro grind has been detected on quicker downshifts (6th to 5th, 5th to 4th)
-Headlights have a good amount of haze
-Cracked windshield washer reservoir
-Front bumper has dent, and crack damage. Emblem is missing.
-Power steering fluid could use a flush and refill. (It looks old)
-Brake/Clutch Fluid could use a flush and refill. (It is probably old)
-Drivers seat has torn cloth
-A/C does not blow cold. The system will need to be serviced.
-Right rear axle clicks when starting from a stop. Known 350Z issue.
Recent Parts and Service:
-4 Wheel Alignment
-New rear differential gear oil (Valvoline 80W-90 Synthetic Blend)
-New Copper Spark Plugs (All 6)
-New Hitachi Replacement Coilpacks (All 6)
-Stock fuel injectors cleaned by Deatschwerks
-New transmission gear oil (Redline MT-85)
-New vacuum and water hoses that attach to intake manifold
-New Nissan Valvecovers
-New Valve Cover Gaskets
-New fuel rail O-Rings
-New NTK O2 Sensors (All 4)
If you're interested best way to reach me is via email. Thanks for looking.
Edited by B13Guy
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
