74 260z 4.8 CD009 Transmission
I've been a lurker here for MANY years before I even had my 260z. Several Z31's have been in my fleet but about 4 years ago I found a S30 that I was able to trade for a motorcycle. The car was in good condition and ran but being the gear head I am I wanted more power and a LS motor in it. My build isn't perfect and there are some things I would like to go back and change at this point but... It's a work in progress. I'm to the point were I can just now drive and start tuning.
A lot of things have happened since I started the build. I put up a shop at my house, had a daughter and now have a son coming any day.
Just bringing it home
Then I took it over to my friends grandpas house to start making changes
I removed the dash added a cover and Autometer Gauges. I ended up rewiring all the gauges through a single connector to make future disassembly easier.
006 17217785149 O 34406511015 O
007 17196541307 O 34275887531 O
010 17402023382 O 34275887251 O
009 17217783209 O 34406510805 O
008 17196540397 O 34275887451 O
007a 16781461774 O 34406510895 O
011 17403614531 O 34406510685 O
012 16781459594 O 34275887081 O
012a 17404000655 O 34406510625 O
013 17216416780 O 34275886941 O
013a 16783719553 O 34021623630 O
014 17403999845 O 34275886821 O
015 17378002926 O 34406510455 O
I then moved onto the seats, I chose a Summit Racing seat which I'd advise against due to the amount of cutting involved to make them fit.
020 17216414180 O 34247420192 O
023 17403609191 O 34275886101 O
021 16783716483 O 34275886261 O
022 17378000406 O 34247420002 O
Once the interior was back together I changed front calipers to Toyota truck, replaced ball joints, started installing busing kit, master cylinder, proportioning valve, struts, chevette springs and ST sway bars.  I now am thinking about coil overs.
27245008040 7127c5f698 O
27422831562 6bfae7e782 O
026 17216413100 O 34247419452 O
028 17216192978 O
So I was able to get a shop build and hauled all my junk from my buddies place home so I could hopefully work on it more. I also picked up a Z31 from the original owner to drive around while I worked on the S30.
05 14653549654 O 34275887621 O
18 14655391152 O 34247420262 O
Over the years I was lining up parts for the V8 using Dirty Dingo mounts, CD transmission, block hugger headers, added 3rd joint to steering shaft, I'll just let the pictures do the talking. The gist was to locate all the parts needed the specialty guys were selling and buy them at half the price.. My daughter showed up during this period and really slowed down progress but that's ok...
25740763130 0edcd1c3ca O
19538256440 5e144d3f04 O
19394527191 9920fb6dae O
19089736401 ab2afbd83d O
17941723604 cb32074373 O
25049352924 bb387e9c87 O
32401121855 f2f6d3e836 O
31949919621 17b1ef1f65 O
32360985264 1a5213ae82 O
31558681484 40c9c941b2 O
31226189414 b362ee16a1 O
28783847433 5de5001d6c O
26585109235 b82b8eff37 O
25979909444 831b0d91f5 O
25053144413 ecf8ceba1a O
Then I made a wiring harness, ordered a drive shaft from Fast Shafts, and started tuning.
32985015664 68fd90108f O
32879715573 ced94a2886 O
And it moves, Trying to figure out how to make this thing run right with out paying for a tune.
https://youtu.be/Xyt5OIR9axs
https://youtu.be/4j4QfcOIcK8
https://youtu.be/q1BnFBhNTjA
  • 7 months later...
Gus,
After you had posted I had to stop over and read your build very nice! How is the tune coming? I may have some questions about tuning my 4.8 in the future. Also I have never heard of using chevette springs definitely will research that and you've made me even more excited to get my lift! -Joel
