70 240z swap l28et
petes30
OK as at right now the car run fine without the fuel pump at 0 psi. Max psi is at 50, when it's at 50 psi, It sound like it going to die. Running 440cc injector with stock ecu... also when the car run fine or spitting, when I excelurate the engine dies ever timr... anyone knows what going on. I think it flooding the motor with gas...
So many questions...
Ok first. If you want to stick with the stock ECU here is your new bible:
http://datsunforum.com/datsun-fuel-injection-bible-200sx-280z-280zx-810/
Second. The stock ecu was never meant to run 440cc injectors so unless you know how to tune the Z31 ECU I would stay away from that mashup.
Third. How are you measuring 0psi fuel. its not possible to run with 0 psi so something is wrong.
Edited.
A moderator must have deleted my other post, with its good information, in the other duplicate thread.  So the comment that was here just looked like random rambling.
Context, moderators, context.  Consider all...
Edited by NewZed
