Sign in to follow this
SH4DY
'77 280z aka Project Tetanus
SH4DY    0
First of all, hello! I'm a newb here but not to modding. I've lived on the norotors forum for the past few years after building a couple of LS swapped RX-7's. I still have my FC (Solid axle, 4-link, LS1, 88mm turbo, TH400) and I'm trying to sell it to fund this project.
Anyway, I came across a '77 280z that had been sitting for 20+ years. From what I can tell it was silver from the factory, then red, then silver again. Lots of piss poor bondo work and rust. Lots of rust. But, for the price I got it for, I can't complain. I've already started cutting the floor pans out.
I have a torn down LS6 that'll be worked into an 11.0:1 382 with a custom BTR cam and a T56 waiting once I get the body sorted. I've had good luck with MS3Pro on my RX-7 so I'll probably go with that on this one as well.
I'll get some pictures up soon.
Share this post
Link to post
SH4DY    0
On to the pictures:
The Z as she arrived in all her glory/ misery. I'm pretty sure the car was used for practice by a highschool body shop class
IMG 20170603 134229349
IMG 20170603 134222274
IMG 20170603 134211504
IMG 20170704 150404913
Who needs metal for a floor board?
IMG 20170708 133558456
IMG 20170708 133608350
and the rust... ohhh the rust:
IMG 20170708 165546835
IMG 20170708 165539991
IMG 20170708 165524566
IMG 20170704 163820447
IMG 20170704 134409194
IMG 20170704 134358135
After some cutting/ sanding and priming:
IMG 20170711 183358474
IMG 20170711 191057463
IMG 20170708 133628587
I'm also redoing the steering wheel. Took off the old gross rubber, attached some MDF and started shaping. It'll eventually be wrapped in carbon.
IMG 20170609 211103594
IMG 20170611 113814840
IMG 20170613 195957824
Lots and lots of hours to go with the media blaster and sander.
Share this post
Link to post
SH4DY    0
I was able to get a little more done last weekend.
I cut out the horrible patch job on the outside of the drivers side frame rail, blasted, primed/painted and boxed in with 16 ga (I think? may have been thicker) sheet. I still need to do the small portion in front of the cross member mount.
7 19 17B
7 19 17C
7 19 17D
7 19 17E
After spending a couple of hours fighting with all the spot welds trying to remove the brackets in the engine bay I gave up after seeing how weak/ think the metal was. It also became pretty clear how flimsy the shock tower support must be. So, I cut a healthy chunk of it out (pretty close to the perimeter spot welds) and added new sheet (22 ga) along with some 3/4" tube. Once I get around to the fixing/ replacing sections of the firewall I'll add bracing to the back of the towers to the firewall.
7 19 17F
7 19 17G
7 19 17H
Also shaved the drip rail. Still very much a work in progress
7 19 17A
Share this post
Link to post
SH4DY    0
More welding for the drip rail: Trying to make this car as solid as possible with minimal bondo. Huge pain in the ass.
IMG 20170810 202604527
Added some angle iron to help strengthen the front frame rails:
IMG 20170730 150049422
After boxing in the lower portion of the rails I added a tubular piece to replace the factory frame rails. It is attached to the rear subframe.
IMG 20170730 132214067
IMG 20170730 130947468
Mocking up the motor and the new subframe for the LS swap.
IMG 20170818 142749299
IMG 20170818 142759933
IMG 20170818 142735514
IMG 20170818 142814785
IMG 20170818 174825157
IMG 20170818 174835700
I had some extra paint in the gun and wanted to see what it would look like on the car:
IMG 20170818 171547512
Rustoleum Satin black mixed @ 15% with Acetone. Single coat. I like it. I think it'll compliment the carbon fiber well.
Now that I have the motor in I can figure out the transmission mount and then start building the floors and tunnel.
Share this post
Link to post
SH4DY    0
Started boxing in the former battery tray area:
large.IMG_20170905_171148684.jpg.f14a68883072a826ec8135f863d4f558.jpglarge.IMG_20170905_171117864.jpg.3f3021c7ed3580819929547e090db350.jpg
Trans is in! Going to have to redo the majority of the trans tunnel.
Next step is to get a bead roller and start on the floors and finish the firewall.
I think I might wind up going SLA ford 8.8": I started pricing out 5 lug conversions, brakes, suspension, LSD, axles, etc and its pretty cost prohibitive to keep the IRS. Pretty sure with a good 4 link and watts setup I can get this thing to handle pretty well... at least for any auto-x or back road driving I may do.
Share this post
Link to post
Ironhead    0
Great work....I have huge respect for your bringing that shell back...I honestly think I would have run screaming from that one.
BTW...I like the larger pictures.  The earlier ones in the thread were too small to really see what you were doing.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
