Zmanco
P90 Head, Crossflow Radiator and other Z stuff
Started a new thread here to clean up and include some new stuff.
All prices include Paypal fees.
Weights are estimates.  Final shipping cost will be determined once I pack it up and can weigh it accurately and know your address.  I will ship from Colorado zip code 80108 using UPS or USPS whichever is cheaper.
SOLD P90 Turbo head $525 est shipping weight 42 lbs
Shaved 0.080" and includes spacers for towers as well as longer valves.  Valves unshrouded and chambers cc'd to 44.5cc.  Port matched for Felpro intake/exhaust gasket.  Nipples added for cylinders 5 and 6 to help with cooling under boost.
post-1744-0-67681300-1500667650_thumb.jpg post-1744-0-11886000-1500667677_thumb.jpg post-1744-0-64050500-1500667702_thumb.jpg post-1744-0-26693700-1500667721_thumb.jpg
SOLD L24 9mm Connecting Rods $135 est shipping weight 19 lbs
SOLD R180 4.11 Differential with Cusco clutch LSD $475
The diff started to make noise the day before I replaced it with an R200 so I did not have time to troubleshoot.  Sounded like a bearing. Price is reduced accordingly. Would prefer to not ship this as it's very heavy.
Magnecor Spark Plug set $45 INCLUDES SHIPPING
Will not include the Magnecor box in order to reduce shipping cost.
Wastegate Actuator 18 psi $50 INCLUDES SHIPPING
Purchased from ATP Turbo ATP-WGT-022
Wastegate Actuator 7 psi $50 INCLUDES SHIPPING
Purchased from ATP Turbo ATP-WGT-019
Wastegate Actuator 15 psi $40 INCLUDES SHIPPING
Tokico Lowering Springs $80 est shipping weight 22 lbs
Centerforce Clutch and OEM disc $80 est shipping weight 15 lbs
I ran this with an L28 NA mild build and only replaced when I went turbo and turned the boost up.
Earl's 25 Row Oil Cooler $110 est shipping weight 5 lbs
SOLD Cross Flow Radiator with SPAL Fan and custom shroud $410 est shipping weight 25 lbs
http://www.thezstore.com/page/TZS/PROD/classic15e/16-7017
Has some minor fin damage as shown. Custom aluminum shroud with rubber vents. Came out of my '73 - you may need to make adjustments to install in a different year.
post-1744-0-78554300-1500669011_thumb.jpg post-1744-0-84877600-1500669030_thumb.jpg post-1744-0-18999600-1500669042_thumb.jpg post-1744-0-47482700-1500669059_thumb.jpg
SOLD Toyota 4x4 front brake calipers with solid rotors $110 est shipping weight 48 lbs
Rotors have little wear; brake pads still in calipers.
post-1744-0-28616500-1500669138_thumb.jpg post-1744-0-82539100-1500669152_thumb.jpg
2 Sets of SU Carbs $410 est shipping weight 15 lbs
One set has throttle bodies rebuilt by Z Therapy, the other probably need the throttle bodies rebuilt.
Plastic interior panel rear below hatch $30 est shipping weight 4 lbs
Removed when installing speaker box
Edited by Zmanco
Share this post
Link to post
Can the interior tail light panel be posted to Australia?
It depends on what's involved in shipping via UPS.  I haven't tried Australia before, but Canada was a PITA so wouldn't want to go through that again.  Probably cost more to ship than the item too.  I'll PM you.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
