softopz
14Point7 Wideband o2 controllers Megaspartan and iDash
I just became a dealer for 14point7 products. They are a fairly smaller company than the big 2 like AEM and innovate however they do offer better price points and carry a 2 year warranty and 60 day money back gaurentee behind their products. I personally went through two Innovate wideband controllers before getting the Spartan 2 and I am very satisfied with it. I am also adding them to my Megasquirt 2 harness kits as an option as well. They use the Bosch LSU 4.9 Sensor in all the controllers which are used in practically all o2 aftermarket widebands. Also they are available at any local store however its better to purchase the o2 sensor with controller and save some money.  Also the prices are the exact as the website however sales made through HBZ I will donate 5% of sale. Thank you here are some of 3 key products I will sell.
Spartan_Controller_2_Product_Logo_medium
Spartan Lambda Controller 2
w/o sensor $75
with sensor $125
with sensor and gauge $175
Spartan 2 is a purebred Wideband Oxygen Controller for the Bosch LSU 4.9 Wideband sensor with no excess.
Spartan 2 is crafted with all automotive grade extended temperature components, this means Spartan 2 offers automotive OEM reliability over the widest operating temperature range possible; -40[C] to 125[C]. 14Point7 stands behind this product with a warranty that is twice as long as any competing product, 2 years
Spartan 2 is equipped with both an analog Linear Output and Simulated Narrowband Output that is compatible with most gauges, ECUs, dataloggers, etc…
The advanced design, highest quality components, and extensive factory calibration means 0.01 Lambda accuracy — without the need for any calibration.
Spartan 2 is designed with MegaSquirt in mind, Spartan 2’s Output Sequencer feature provides MegaSquirt with calibration signals to achieve the highest Lambda accuracy possible over the analog Linear Output
Features:
LSU_4_9_compact.jpg?12005369282206728058 Spartan 2 utilizes the Bosch LSU 4.9 Wideband O2 Sensor - a cost efficient Wideband O2 sensor providing 0.01 Lambda accuracy, fast response, and rated life of 100,000 km
Feature_Lambda_144x100_b3c0773d-f32a-4072-a821-c37a924d0d0c_small.jpg?1839 Compatible with all fuels
AFR/Lambda range, 0.68[Lambda] to 1.36[Lambda], 10[AFR] to 20[AFR] equivalent for gasoline
Feature_Accuracy_315x100_compact.jpg?1839 0.01 Lambda accuracy without the need for any calibration
Feature_Binary_Drive_compact.png?1853 Utilizes our patent pending Binary Drive technology; no other system is more digital
Feature_Linear_Output_263x100_compact.jpg?1776 Linear Output allows easy interfacing with gauges, fuel management systems, and data-loggers
Linear Output: 0[V] @ 0.68[Lambda] linear to 5[V] @ 1.36[Lambda], 10[AFR] linear to 20[AFR] equivalent for gasoline
22_Output_Sequencer-01_compact.png?1877 Our innovative Output Sequencer feature means our Wideband O2 Controllers to have the most accurate Linear Output on the market. You can be sure that any device connected to the Linear Output will receive the most accurate AFR/Lambda signal possible
The Output Sequencer provides a dual level precision voltage signal to the Linear Output. This allows you to easily check that the AFR/Lambda seen by any device connected to the Linear Output is accurate, and if not, to generate a 2 point calibration to achieve perfect accuracy
MegaSquirt users, check out how to use the Output Sequencer for maximum AFR accuracy here
Feature_Narrowband_Output_281x100_compact.jpg?1777 Simulated Narrowband Output allows you to install a Wideband O2 Sensor in place of your Narrowband O2 sensor
Simulated Narrowband switch point @ 1[Lambda], 14.7[AFR] equivalent for gasoline
6_Easy_Install_compact.jpg?1881 Easy 4-wire installation for most setups
Feature_2year_warranty_238x100_compact.jpg?1789 A Two-Year Warranty that is twice as long as any competing product
2_Money_Back_Guarantee_compact.jpg?1881 60 day money back guarantee
59f685627910b_spartan2a.thumb.jpg.383c74a9b554ba02e1ee9e8921fbbe70.jpg59f68563b8d5f_spartan2.jpg.278f264230a20dbb7a8978e2c5b73de5.jpg
iDash_Product_Logo_medium.jpg?1937
iDash Basic $199
iDash Single o2 controller *built in* $299
iDash Dual o2 controller *built in* $399
A virtual dashboard on your phone, tablet, or PC. iDash leverages the latest web and Wi-Fi technology to allow your engine to speak directly to you through your web browser. iDash virtual dashboards are touch enabled - adding and changing gauges, plotting, graphing, and data-logging is a mere touch away.
Optimised for iPhone, iPad, Android, BlackBerry, Windows, and Linux. iDash not only speaks all those languages, but can also speak them all at once. Create your own custom virtual dashboard on just one device, or across several devices simultaneously.
Have the latest phone or tablet? Run the modern HTML5 or Adobe Flash interface for a graphically rich experience.
Have an early generation phone or tablet? Run our efficient HTML interface for a streamlined experience.
Want a unique virtual dashboard that fits with your interior? Upload custom dashboards of your own design, if you can make a webpage you can make your own custom dashboards.
Never worry about iDash being obsolete - with enough onboard memory for storing hundreds of webpages, firmware and webserver upgradeablility over Wi-Fi, as web standards evolve so will iDash.
With its Wi-Fi connectivity, total device compatibility, and more sensor inputs than any comparable product, iDash is the ultimate tuning tool you need to unleash the full potential of your engine.
14Point7 stands behind this product with a warranty that is twice as long as any competing product. With an unrivaled 60 day money back guarantee, you can buy with confidence and know that you are getting the absolute best.
Features:
Wifi_Logo_1_small.jpg?1774 Wi-Fi b/g connectivity for simple and quick connections between iDash and your phone, tablet, or PC
Android_logo_100x100_thumb.jpg?1789ios_logo_100x100_thumb.jpg?1712win8_winRT_logo_100x100_thumb.jpg?1716Microsoft_logo_100x100_thumb.jpg?1718Mac_Logo_76x100_thumb.jpg?1720linux_logo_71x100_thumb.jpg?1722 Compatible with your favorite hardware and OS
IE_logo_100x100_thumb.jpg?1724Chrome_Logo_100x100_thumb.jpg?1726firefox-logo_106x100_thumb.jpg?1728safari_logo_86x100_thumb.jpg?1730 Compatible with your favorite web browser
HTML5_logo_100x100_thumb.gif?1736adobe-flash-logo_100x100_thumb.jpg?1740html_logo_225x100_small.jpg?1740 Chose from 3 interfaces:
  • HTML5 interface for a graphically rich experience
  • Adobe Flash interface for an attractive and smooth experience
  • HTML interface for a streamlined and efficient experience
Feature_Multi_Display_0e378578-0c33-44ce-b503-62e392d92bb1_compact.png?1793 Connect multiple devices simultaneously and mix different devices and browsers to create a custom virtual dashboard across multiple screens
Feature_Upload_244x100_compact.jpg?1768 Upload your own custom HTML and HTML5 webpages for a truly unique virtual dashboard
Feature_32MB_275x100_compact.jpg?1768 32 mb of onboard memory for storing up to 1.5 hours of data-logging
Feature_RPM_275x100_compact.jpg?1778 Built in RPM Pickup - 0[RPM] to 20000[RPM]
Feature_Shaft_RPM_238x100_compact.jpg?1779 Shaft RPM Sensor input - monitor your transmission and wheel slippage, 0[RPM] to 10000[RPM]
Feature_Accelerometer_306x100_compact.jpg?1780 Built in Dual Axis Accelerometer - measures both cornering and acceleration/deceleration G-forces
Feature_EGT_275x100_compact.jpg?1782 8x Exhaust Gas Temperature probe inputs, 0[F] to 2500[F], 0[C] to 1400[C]
Feature_Boost_Vac_219x100_compact.jpg?1783 Dual Boost/Vacuum sensor inputs, 0[PSI] to 44[PSI], -30[Hg] to 88[Hg]
Feature_IAT_244x100_compact.jpg?1784 Dual Intake Air Temperature sensor inputs, 0[F] to 300[F], 0[C] to 150[C]
Feature_Fuel_Pressure_238x100_compact.jpg?1785 Fuel Pressure sensor input, 0[PSI] to 150[PSI], 0[Hg] to 250[Hg]
Feature_Oil_Pressure_238x100_compact.jpg?1786 Oil Pressure sensor input, 0[PSI] to 150[PSI], 0[Hg] to 250[Hg]
Feature_Fuild_Temperature_238x100_compact.jpg?1787 Fluid Temperature sensor input, 0[F] to 300[F], 0[C] to 150[C]
Feature_Analog_319x100_compact.jpg?1788 Dual 0-5 Volt inputs
Feature_2year_warranty_238x100_compact.jpg?1789 A Two-year warranty, twice as long as any competing product
2_Money_Back_Guarantee_compact.jpg?1880 60 day money back guarantee
 Wideband O2 Option Features:
  iDash utilizes the Bosch LSU 4.9 Wideband O2 Sensor - a cost efficient Wideband O2  sensor providing 0.01 Lambda accuracy, fast response, and rated life of 100,000 km
Feature_Lambda_144x100_b3c0773d-f32a-4072-a821-c37a924d0d0c_small.jpg?1774 Upto dual onboard Wideband O2 Controllers
Compatible with all fuel types
Ultra wide AFR/Lambda range, 0.68[Lambda] to 100[Lambda], 10[AFR] to 100[AFR] equivalent for gasoline
Although not required (or recommended), Free Air Calibration is supported
Feature_Lambda_Temperature_313x100_compact.jpg?1789 O2 Sensor Temperature Monitor
Did you know that the most common cause of inaccuracies and premature O2 sensor failure is attributed to the O2 sensor temperature being improperly controlled? Only 14Point7 branded Wideband O2 Controllers are able to monitor O2 sensor temperature
Linear Output: 0[v]@0.68[Lambda] linear to 5[v]@1.36[Lambda], 10[AFR] linear to 20[AFR] equivalent for gasoline
Switch point @ 1[Lambda], 14.7[AFR] equivalent for gasoline
59f6855fd3c19_idashkit.thumb.jpg.fcad083e0e700dc1eeccbb7c94d86734.jpg59f6855dc0322_idashiphone.jpg.a15060f6236feafddbda3b04e8092668.jpg59f6855cf2d8c_idashandroid.thumb.jpg.60087cbe788f25a24e552f1f8f46b652.jpg59f6855bdd440_idashandroid2.thumb.jpg.350a195b1f7079579e2ed069c74652bb.jpg59f6855acfafa_idash(2).jpg.f0958d49e5e5ceef7b8bab3f3d9e6cff.jpg59f6855fd3c19_idashkit.thumb.jpg.fcad083e0e700dc1eeccbb7c94d86734.jpg
Mega_Spartan_Product_Logo_medium.jpg?v=1
MegaSpartan Lambda Controller single channel wideband $249
add $149 per extra channel up to 8x lambda!
Adding one or more Wideband Oxygen Controllers to your MegaSquirt ECU has never been this easy or accurate. MegaSpartan is the first Wideband O2 Controller that communicates directly with your MegasSquirt 2 or MegaSquirt 3 ECU over digital CAN bus.
Tune with the confidence that your AFRs are accurate, that noise and ground offsets are a thing of the past.
Upgradability from a single Wideband O2 Controller to eight Wideband O2 Controllers means MegaSpartan will grow with your needs.
MegaSpartan is crafted with all automotive grade extended temperature components; -40[C] to 125[C], and is backed up with a warranty that is twice as long as any competing product, 2 years.
Features:
CAN_bus_compact.jpg?v=1473049143 CAN bus communications directly with Megasquirt 2 and MegaSquirt 3 ECU
LSU_4_9_compact.jpg?12005369282206728058 MegaSpartan utilizes the Bosch LSU 4.9 Wideband O2 Sensor - a cost efficient Wideband O2  sensor providing 0.01 Lambda accuracy, fast response, and rated life of 100,000 km
Feature_8x_144x100_small.jpg?v=146967708Feature_Lambda_144x100_b3c0773d-f32a-4072-a821-c37a924d0d0c_small.jpg?1774 Upto eight onboard Wideband O2 Controllers
Ultra wide AFR/Lambda range, 0.5[Lambda] to 1.52[Lambda], 7.35[AFR] to 22.39[AFR] equivalent for gasoline
Share this post
Link to post
4 hours ago, Derek said:
I've been running a Spartan for a while and have had zero issues. I had nothing but headaches with my Inovate LC-1. Probably killed 3 or 4 O2 sensors.
Derek
I killed one lc1 and 1 lc2 so far so you got me beat. Hoping Summit will take this last one didn't even last a year! Really like the spartan its nice supporting the smaller guys especially when they make a better product than the big boys.
P.S> Got the speaker pods awhile back they are super nice fit and quality ! I'll show some pics with my android double din hooked up via bluetooth. GPS, Media, engine parameters all in one!
Share this post
Link to post
I have also moved over to Spartan thanks to some advice from the Chickenman. I went thru 2 sensors with Innovate. In all fairness though I have learned more about sensors and how NOT to shock them . Also running EFI now is easier on the sensor I bet. I like the blue light that lets you know the sensor is located in the right place. My sensor is further out then recommended but blue light says it’s good
Share this post
Link to post
30 minutes ago, softopz said:
OK here is official reply from the maker " there is two general purpose voltage inputs that can be connect to it will display as voltage"
I replied to see if it can be converted it to afr value within program .
Thanks!  It would seem like a pretty straightforward conversion from voltage to afr.
Share this post
Link to post
Yes the conversion is straight forward. However different controllers have different outputs and some of them have configurable outputs per lambda.  I just wanted to see if the idash basic software has something in the software to convert that signal and put it in in lambda or afr.
Share this post
Link to post
1 hour ago, rossman said:
I have another question sorta related to the first one.  Since my Speedhut gauge is set up for innovate lambda controller output, will a Spartan lambda controller work with my gauge?
The spartan 2 outputs 0volts10[AFR] to 5volts20[AFR] Is your speed hut gauge programmable? i know innovate outputs could be programmable and thats where we see lots of fried controllers and sensors. To answer your question I would have to know which output you are using on your LC1 and the voltages... there are many gauges out there setup for 0-5v / 10-20 afr. Hope that answer your question if you have any more let me know
Hussein
Share this post
Link to post
The gauge came calibrated for innovate.  I'm not sure if it's user configurable.  From the manual:  Your wide band gauge is calibrated to work with Innovates 10-18 AF (.880-3.54volts).  I'm not married to the gauge or controller but it'd be nice to have options.
Share this post
Link to post
Oh i misunderstood what you said from the manual as in Spartan2 I was looking and im like HUH? OK so I am no expert but your gauge looks like it was calibrated for innovate 10-18af .880-3.54 volts this is most likely linear so if the spartan is giving 0volts *Which is supposed to be 10afr yours will read differently on the gauge and not accurately to real AFR . I would contact speed hut to see if it could be re-calibrated.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
